Discuss
Icemaker
 in
Refrigerator & Freezer Repair
I purchased a water valve kit 67003753 and installed it and replaced the icemaker. No water to icemaker. The instruction
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Icemaker
  #1 (permalink)
Old 03-02-2012, 09:33 AM
Junior Member
david r mccardle is on a distinguished road
Default Icemaker
Model Number: GX5FHDXTS01   Brand: Whirlpool   Age: 1 - 5 years
I purchased a water valve kit 67003753 and installed it and replaced the icemaker. No water to icemaker. The instruction sheet that came with the water valve lists item #6 "Remove spring insert and coupler nut from the outlet at the valve, which goes to Icemaker and discard" This instruction makes no sense to me, I saw not spring anywhere. After explaining this instruction do you have any other trouble shooting instructions. I did open the little in line valve before doing anything to make sure water flowed, it did.
Ads By Google
Related Models
Whirlpool GX5FHTXTB00 Refrigerator
Whirlpool GX5FHTXTQ00 Refrigerator
Whirlpool GX5FHTXTS00 Refrigerator
Whirlpool GX5FHTXTT00 Refrigerator
Whirlpool GX5SHDXTB00 Refrigerator
Whirlpool GX5SHDXTQ00 Refrigerator
Whirlpool GX5SHDXTS00 Refrigerator
Whirlpool GX5SHTXTB00 Refrigerator
Whirlpool GX5SHTXTQ00 Refrigerator
Whirlpool GX5SHTXTS00 Refrigerator
Whirlpool GX5SHTXTT00 Refrigerator
Whirlpool GX900QPGB0
Whirlpool GX900QPGB1
Whirlpool GX900QPGQ0
Whirlpool GX900QPGQ1
Whirlpool GX900QPGS1
Whirlpool GX900QPHB0
Whirlpool GX900QPHQ0
Whirlpool GX900QPHS0
Whirlpool GX900QPHT0
Whirlpool GX900QPKB0
Whirlpool GX900QPKQ0
Whirlpool GX900QPKS0
Whirlpool GX900QPKT0
Whirlpool GX900QPLB0
Whirlpool GX900QPLQ0
Whirlpool GX900QPLS0
Whirlpool GX900QPLT0
Whirlpool GX900QPPB0 Trash Compactor
Whirlpool GX900QPPB1 Trash Compactor
Whirlpool GX900QPPB2 Trash Compactor
Whirlpool GX900QPPQ0 Trash Compactor
Whirlpool GX900QPPQ1 Trash Compactor
Whirlpool GX900QPPQ2 Trash Compactor
Whirlpool GX900QPPS0 Trash Compactor
Whirlpool GX900QPPS1 Trash Compactor
Whirlpool GX900QPPS2 Trash Compactor
Whirlpool GX900QPPT0 Trash Compactor
Whirlpool GX900QPPT1 Trash Compactor
Whirlpool GX900QPPT2 Trash Compactor
General Electric GXCC01D Home cond
General Electric GXCF03E Home cond
General Electric GXCF05D
General Electric GXCF05D02 Inline filtration
General Electric GXCF20E Inline filtration
General Electric GXCF20FBB Home cond
General Electric GXCF25FBS Home cond
General Electric GXCF25HBS Home cond
General Electric GXCF35GBS Home cond
General Electric GXCM55GBU00 Inline filtration
General Electric GXCM55GWW00 Inline filtration
General Electric GXEM01B01 Uc filtration-carbon
General Electric GXEM01Z01 Uc filtration-carbon
General Electric GXES01Z Uc filtration-carbon
General Electric GXFM03C Inline filtration
General Electric GXRM10GBL Wh filt sys
General Electric GXRV10ABL Filtration-rev osmosis
General Electric GXSF18G01 Water softeners
General Electric GXSF18G02 Softners
General Electric GXSF23Z01 Uc filtration-carbon
General Electric GXSF27B00 Water softeners
General Electric GXSF27B01 Water softeners
General Electric GXSF27E01 Water softeners
General Electric GXSF30H01 Softners
General Electric GXSF30H02 Softners
General Electric GXSF31E01 Water softeners
General Electric GXSF35E01 Water softeners
General Electric GXSF35E02 Softners
General Electric GXSF39B00 Water softeners
General Electric GXSF39B01 Water softeners
General Electric GXSF39E01 Water softeners
General Electric GXSF40H01 Softners
General Electric GXSF40H02 Softners
General Electric GXSH39E01 Water softeners
General Electric GXSH39E02 Softners
General Electric GXSH39E03 Softners
General Electric GXSL03C Uc filtration-carbon
General Electric GXSL55F Wh filt sys
General Electric GXSS17Z01 Uc filtration-carbon
General Electric GXSS20B00 Water softeners
General Electric GXSS20H01 Softners
General Electric GXSS20H02 Softners
General Electric GXSV10C Uc filtration-carbon
General Electric GXSV65F Wh filt sys
General Electric GXUL30Z01 Uc filtration-carbon
General Electric GXUT03A Uc filtration-carbon
General Electric GXUT03B01 Uc filtration-carbon
General Electric GXUT05Z01 Uc filtration-carbon
General Electric GXUV10Z01 Uc filtration-carbon
General Electric GXWH01C Uc filtration-carbon
General Electric GXWH04F Uc filtration-carbon
General Electric GXWH08C Uc filtration-carbon
General Electric GXWH20F Uc filtration-carbon
General Electric GXWH30C Uc filtration-carbon
General Electric GXWH35F Softners
Whirlpool GY395LXGB0
Whirlpool GY395LXGB1
Whirlpool GY395LXGB2
Whirlpool GY395LXGB3
Whirlpool GY395LXGB4
Whirlpool GY395LXGQ0
Whirlpool GY395LXGQ1
Whirlpool GY395LXGQ2
Whirlpool GY395LXGQ3
Whirlpool GY395LXGQ4
Whirlpool GY395LXGZ0
Whirlpool GY395LXGZ1
Whirlpool GY395LXGZ2
Whirlpool GY395LXGZ3
Whirlpool GY396LXGB0
Whirlpool GY396LXGB1
Whirlpool GY396LXGB2
Whirlpool GY396LXGB3
Whirlpool GY396LXGB4
Whirlpool GY396LXGB5
Whirlpool GY396LXGQ0
Whirlpool GY396LXGQ1
Whirlpool GY396LXGQ2
Whirlpool GY396LXGQ3
Whirlpool GY396LXGQ4
  #2 (permalink)
Old 03-02-2012, 10:20 AM
Junior Member
Ronsstuff is on a distinguished road
Default
The Spring Being Referred To May Also Be Called A Sleeve Or An Insert. Either Way, The Line Needs To Be Cut Off And Simply Inserted Into The New Style Water Valve Discarding The Old End Pieces. Most Likely Your Unit Did Not Cycle On Its Own, Or There Was Air In The Line And May Need To Be Manually Cycled.the Easiest Way For You To Do This, Would Be To Fill The Icemaker With Water Using A Container. It Will Freeze In A Couple Of Hours, Activating The Process On Its Own. Make Sure You Did Transfer The Shut Off Arm From Your Old Unit To The New One And That It Is The Down Position( Down Is On).
  #3 (permalink)
Old 03-03-2012, 12:09 AM
Junior Member
cristofer is on a distinguished road
Default a home refridgerator
This question is in regards to problems with an icemaker inside a home refridgerator?
__________________
[URL=http://www.mixmelot.com/]wholesale[/URL]
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Icemaker - water continues to dispense when Icemaker shut off arm is activated dpassaro Refrigerator & Freezer Repair 0 07-24-2011 09:57 AM
Icemaker - water continues to dispense when Icemaker shut off arm is activated dpassaro Refrigerator & Freezer Repair 0 07-24-2011 09:49 AM
Icemaker badbears02 Refrigerator & Freezer Repair 0 08-30-2010 08:46 AM
Icemaker not doing anything jmcdtucson Refrigerator & Freezer Repair 3 05-24-2009 06:31 AM
Icemaker Mary2020 Refrigerator & Freezer Repair 1 11-11-2008 09:43 AM
