| » Runs, Stops and won't restart... |
Model Number: ED25LFXGW00 Brand: Whirlpool Age: 5 - 10 years
Hi, I have a Whirlpool Imperial Model ED25LFXGW00. It runs fine sometimes for a day or two, sometimes less, but once it stops cooling, I have to turn the thermostat switch to off, I hear it click, and then turn it back on and the unit starts back up. It gets nice and cold and within a few hours or sometimes a day or two, it stops again. The only way to restart is to turn the thermostat switch to off and then back on. I was looking at a parts web site and thought it might be one of the following parts (I don't know much about this, but just took a shot):
Thermostat assembly Overload and relay assembly Capacitor Parts are expensive, I am currently unemployed and I was hoping to get your thoughts on what might be the problem. Thank you so much for your time. Ads By Google Related Models |
Seems like a bad cold control AP3037004 You can try a non-residue contact cleaner available at Wall Mart. Just spray it while turning it off and on. You can also use WD-40 on it, the slight oil residue it leaves behind should not harm the electrical contacts. Just spray it into any slight opening in the control.
__________________
Hi Richappy. Tried the contract cleaner but still acting the same. Do you feel that the next best bet would be to replace that thermostat switch? I appreciate your thoughts on any other things I might try before replacing the part. Thanks, Russ
| Display Modes | |
| GE refrig stops cooling and will not restart | gary-b | Refrigerator & Freezer Repair | 11 | 01-27-2011 01:20 PM |
| dryer stops midcycle but will restart | sjc17blue | Dryer Repair | 0 | 06-16-2010 11:04 AM |
| Stops & won't Restart | dickward | Dryer Repair | 0 | 12-04-2009 10:24 AM |
| Dryer runs for 15 seconds, stops, & then won't restart | alohajbw | Dryer Repair | 1 | 03-18-2009 10:51 AM |
| Electric dryer Stops, then will restart | croberts | Dryer Repair | 3 | 01-04-2008 01:21 AM |
