How do I replace eletronic defrost control in refrig. Side. Thank you very much.
Groups: APP Team
To replace the defrost control first unplug the refrigerator then pull 2 control knobs off. Using the flat screw driver pry off the plastic insert, take out 4 quoter inch screws. When you drop down the cover, you will see the control in the right corner held by 2 screws. The control board Part number: AP4356969
