fridge runs continuously and doesnt reach required temperature, it has been charged and the capillary tube has been replaced. the problem still exists. compressor was pressurized and reached 500 PSI and then it started dropping down to 350 and below. Is this normal for the compressor is does it need to be replaced? I have a 1991 Frigidaire Model number: FPCI523TFL1
