hello all, my ice machine is not making ice machine comes on resevoir fills water circulates over plate but plate doesnt get cold in fact feels warm, any help is appreciated.
Bigant I had the same problem. My contol board was bad. Look for my post with the same title. There is a link on the reply with the service manual to your machine. I tried to copy and paste here, but did not work. Hope it helps. Danny
how would i know for sure its the control board, it seams to be going thru the cycles, except for the plate freezing to create ice, is there a sure way to tell why the plate does'nt get cold, Any help appreciated Desperately
Bigant I posted the same question on my post title same as yours. On a reply to my post there was a link to the manual that also covers your machine. I cannot say your fix is the same, just the symptoms are. The manual helped me diagnose my problem, as it will for any problems you have with yours. Read the manual first! Hope it helps
Thanks So Much, I Have The Manual Seems To Be Very Helpful Will Dig In Asap
