Discuss
Amana Refrigerator not working
 in
Refrigerator & Freezer Repair
Hi Martin, Sorry for the delay. Temperature in the freezer looks pretty good, but the refrigerator is too warm. I
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Amana Refrigerator not working
  #11 (permalink)
Old 08-07-2009, 06:26 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Martin,
Temperature in the freezer looks pretty good, but the refrigerator is too warm. I would probably blame the damper control because with such temperature it should be completely open.
- The damper control Part number: AP4077555
Ads By Google
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #12 (permalink)
Old 08-08-2009, 02:24 PM
Junior Member
Martin Fowkes is on a distinguished road
Default Damper control
Hi Gene,
Thank you for your post. In fact the damper IS fully open but no cold air is coming through it. I plan to take of the back of the freezer compartment to see if there is any ice build-up. This is an elimination process, and so far I see three possible causes :
- defrost timer faulty
- thermostat iced up and not working (but not sure if the refrigerator has a separate thermostat from the freezer)
- evap fan motor failure
I guess by the end of this process I will have a fairly good idea how Amana refrigerators work !!!
Best regards Gene and thanks again for the interest you show in this case.
Martin
  #13 (permalink)
Old 08-24-2009, 06:26 AM
Junior Member
millstone is on a distinguished road
Default amana model ARB2107
I have a similar problem, freezer working but frig a bit warm. Did notice that very little cold air is coming out of the damper in the frig, but plenty of cold air in the freezer, so the fan is working. I'm thinking the thermo controlled damper is not working, but hoe do you get the cover off to inspect. It looks like there are tabs on the side and bottom, not sure what I need to do to remove wothout braking it. Your help would be appreciated.
thanks
tom
  #14 (permalink)
Old 12-14-2009, 01:34 PM
Junior Member
Default Hello everyone
Just to let you know it was the thermostat, which I eventually changed via Amana in Belgium after the French distributor went out of business.
It is a pity that US sites wont ship outside the USA, because parts are 3 times more expensive here and take 10 times longer to order.
So thanks to all for their kind advice and all the best to you.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana Refrigerator not working - sort of? dadkins788 Refrigerator & Freezer Repair 1 09-15-2009 02:35 AM
Amana Refrigerator not cooling, freezer working sordna Refrigerator & Freezer Repair 1 08-11-2009 07:44 PM
amana refrigerator not frezzing and refrigerator not cooling didhebiteyou Refrigerator & Freezer Repair 0 08-09-2009 09:43 AM
Amana Refrigerator Freezing in Refrigerator cdodson1 Refrigerator & Freezer Repair 4 05-10-2009 08:12 PM
Amana Refrigerator not working well markbero Refrigerator & Freezer Repair 0 06-08-2008 08:43 AM
