2 Pages12>
mtovar
#1 Posted : Friday, February 24, 2012 3:58:21 PM(UTC)
mtovar
My refrigerator is about 7 years old. About 4 months ago our refrigerator stopped cooling or freezing. A repairman replaced persing valve and recharged the freezer. Two days later it stopped working again and the repairman said it was one of two things; either the motherboard was bad or if we unplugged the refrigerator for about an hour and then restarted the refrigerator it would reset and go back to normal.
The reset seemed to work but now it is doing it again (and I wonder if we need to replace the motherboard. I spoke to someone at work and he told me I should check online before I call the repairman again. He said that his motherboard was part of a recall. Any suggestions?
#2 Posted : Friday, February 24, 2012 7:12:00 PM(UTC)
Does it make any sound or it's completely dead?
mtovar
#3 Posted : Saturday, February 25, 2012 9:38:01 AM(UTC)
mtovar
When you place your head inside the freezer and the refrigerator you can hear fan noise. The temperature still feels cold in the freezer, but the ice cream is still slushy. It is still cool inside the refrigerator.
I tried unplugging the refrigerator for an hour as the repairman suggested 4 months ago and then plugged it back in. It still seems cold in the freezer but the ice cream is still not solid. This was done 8 hours ago.
#4 Posted : Saturday, February 25, 2012 2:05:21 PM(UTC)
Originally Posted by: mtovar Go to Quoted Post
...A repairman replaced persing valve and recharged the freezer...
Do you know what kind of a piercing valve he installed? If it was a saddle (tap-a-line) piercing valve, then he could use it only for temporary access to a sealed system for checking operating pressures. If that valve is still there, it is illegal and it could cause a leak.
Remove the rear panel in the freezer and check how the evaporator coils are covered with frost.
Post the results.
mtovar
#5 Posted : Saturday, February 25, 2012 2:22:36 PM(UTC)
mtovar
I don't know what kind of piercing valve he used. I am just reading from the invoice that he left me.
When I open the freezer door and pull the bottom drawer out I can see the coils and they don't look frosty.
mtovar
#6 Posted : Saturday, February 25, 2012 4:34:53 PM(UTC)
mtovar
I removed the cover on the freezer coils and took a photo. I am sending this photo as an attachement.
mtovar attached the following image(s):
#7 Posted : Sunday, February 26, 2012 2:39:17 AM(UTC)
From the evaporator picture, if that's the most frost you can get after a long time in running, you either have a leaky piercing valve, bad condenser motor,bad compressor, or an evaporator refrigerant leak. This assumes the compressor is running all the time.
mtovar
#8 Posted : Sunday, February 26, 2012 6:52:51 AM(UTC)
mtovar
So is it time to call a repairman?
#9 Posted : Sunday, February 26, 2012 9:00:49 AM(UTC)
If the refrigerator worked fine for several hours, then failed and the compressor was running for the entire period (it should be vibrating and warm), then you have a serious system problem for a pro to look at.The service person probably knew this, just never told you. Considering it's age, probably not worth fixing, just too expensive.
mtovar
#10 Posted : Sunday, February 26, 2012 9:27:08 AM(UTC)
mtovar
Thank you for the honest appraisal. Looks like we'll be hunting down a new unit. Thank you for all your advice.
Kenmore refrigerator/freezer issue (Refrigerator & Freezer Repair)
by rgbradley58 1/30/2024 6:32:20 AM(UTC)
Kenmore Refrigerator Model 111.72695911 Inverter Board (Refrigerator & Freezer Repair)
by jppreble 11/2/2023 2:34:22 PM(UTC)
Kenmore refrigerator model#106.59592992 (Refrigerator & Freezer Repair)
by Guest 5/16/2023 12:53:20 PM(UTC)
795.71073.013 Kenmore Refrigerator - Water leaking in the bottom freezer (Refrigerator & Freezer Repair)
by shreshtluthra 3/16/2023 10:21:43 AM(UTC)
Kenmore Refrigerator trips GFCI (Refrigerator & Freezer Repair)
by A_A_Ron 7/1/2022 11:38:52 AM(UTC)
Kenmore refrigerator breathing (Refrigerator & Freezer Repair)
by Guest 1/3/2022 3:24:07 AM(UTC)
Reading codes from Kenmore Refrigerator (Refrigerator & Freezer Repair)
by caribconsult 11/29/2021 3:18:54 PM(UTC)
Kenmore refrigerator 'ER - dH' code (Refrigerator & Freezer Repair)
by Kanehs 9/22/2020 9:47:19 PM(UTC)
Kenmore Refrigerator Ice Crusher (Refrigerator & Freezer Repair)
by JOSHSKORN 4/27/2020 11:48:08 AM(UTC)
Kenmore refrigerator 3 beeps (Refrigerator & Freezer Repair)
by bluefitness 3/3/2019 5:37:06 AM(UTC)
Kenmore refrigerator: 106.64252402 (Refrigerator & Freezer Repair)
by SGH 1/1/2019 12:39:12 PM(UTC)
Kenmore Refrigerator Pooling Water on Floor (Refrigerator & Freezer Repair)
by vintess 2/17/2017 5:18:47 PM(UTC)
Kenmore Refrigerator not cooling (Refrigerator & Freezer Repair)
by Doug615 5/14/2016 12:27:12 PM(UTC)
Kenmore refrigerator not dispensing water into ice tray (Refrigerator & Freezer Repair)
by Jmfreddy17 1/6/2016 3:10:02 PM(UTC)
Filler tube for Kenmore refrigerator (Refrigerator & Freezer Repair)
by kidcapri73 6/24/2015 2:41:34 PM(UTC)
2 Pages12>
