| » Avanti Wine Chiller - Does not get cold |
Model Number: WC42 / 54 / 66 Brand: -other- Age: 1 - 5 years
Got an Avanti Wine Chiller as a gift 2 years ago, which has a digital readout , light, temperature display etc. all electronics seem to work but the fridge does not get cold (outside temp is 80's-90, inside will not get below 79) Compressor is very hot to the touch, tried blowing a fan on the compressor which lowered the temperature a few degrees in some cases but still never got below 79). I used a refridgerator thermometer to confirm the temp guage is correct but when you lower the temp, the unit never gets cold, the compressor and everything appears to 'turn on'. Not much there to observe working.
I called the manufacturer, Avanti only offers 1 year warranty, but will replace the compressor if that is the problem, of course the labor to install is not covered only the part. Looking for ideas / ways to diagnose and eventually fix or determine its useful life. Reviewed other refridgerator diagnostic suggestions but with no freezer, fans etc. not sure where to look and start, Any help is appreciated? also a central NJ based repair place, it is small enough to fit in truck and I can deliver. Thanks Ads By Google Related Models Last edited by emgconsulting : 08-06-2009 at 05:23 AM. Reason: Adding more info |
When posting a question in hopes of a precise and accurate answer. That process starts with YOU. I read your question. And noticed I got more info from the title then the text.
The thing even has a digital readout. And a second thermometer was also used. But you for some unknown reason expected someone to diagnose you chiller with the info you provided. "Cold" What TEMPERATURE is that. You might as well of said "Strange" or "over there". They would have both done as much justice. 2 thermometers. And not one time did you mention a TEMPERATURE. Cold. I live is AZ and 80 degrees is cold. The answer is. It is a Wine "Chiller". Not a Freezer or Refrigerator. Wine, Is specified to be served 46 - 63 Degrees F selvol Mugfind.com |
Did you ever get it fixed and if so, may I ask what the repair man told you? We just bought a used one and the it gets too cold. What ever we set it on, the thermometer that we placed inside will go UP and DOWN from 34 F to 48 F (without any further setting adjustments). The DISPLAY digi read out also doesn't register. It just give us " - - ". The Set button will set to what ever we tell it to, but there is a missing link from the set button process to the actual inside temp along with the readout. Did you learn anything that may help me out? thanks! jj |
Couldnot find a refridgerator guy to even look at it, all said buy another one. Did find a handyman that took it on as a pet project, after several days found several leaks (said soldering was not very good) weeks later, same problem, he fixed more leaks. Thi time it lasted months before failing again, this time it is garbage.
All the lectronics are contained within and not alot you can do to justify the cost, be sure to use a good thermometer to read the actual temperature. Sorry cant be more help. |
Hmmm...I have a Samsung 52" that keeps having a repeat problem. One repair guy said that he sees it alot in the model that I bought.
If your repair guy said that there was bad soldering, I wonder if Avanti just has bad units. At least we can keep drinks cold in it, it just can't be used for red wines. Thanks again for the quick reply. jj |
Quote:
marv |
Found a handyman that actually took it on as a pet project, short version, got fixed said soldering was inferior, held freon for about another two montsh before another pinhole leak, lost freon. He fixed that one (different place) and installed a cooling fan. (like i said apet project) after the third time, he told me forget it, probably wont get more than a few months at a time so got rid of it. Good luck, no avanti anymore |
I have an Avanti wine chiller model no. WC330DZB which became too noisy after a few months of usage. The compressor stopped running and now I hear clicking every 2 minutes, but couldn't hear the compressor noise anymore. Before it quit working, the left side (outer panel) of the chiller was getting warm. Is this problem repairable at a reasonable cost - way less than the cost of a new chiller? Even if I'm able to fix this, can the compressor be silenced?
| Display Modes | |
| Avanti Thermoelectric Wine Cooler | tmprobst | Refrigerator & Freezer Repair | 6 | 05-02-2013 08:26 PM |
| Wine Chiller/cooler: light works, fan and compressor do not | lothian.mcadam | Refrigerator & Freezer Repair | 2 | 12-04-2009 01:05 PM |
| GE Wine Chiller | andover | Refrigerator & Freezer Repair | 0 | 09-01-2009 10:50 AM |
| Oster Wine Chiller | waustinjr | General Talk | 1 | 12-14-2008 02:43 PM |
