Discuss
GE Profile Refrigerator Ice/water dispenser not working
 in
Refrigerator & Freezer Repair
There have been a few people, like me, who have had similar problems. I have tried replacing the main control
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » GE Profile Refrigerator Ice/water dispenser not working
  #41 (permalink)
Old 02-16-2012, 04:49 PM
Junior Member
9x94 is on a distinguished road
Default
There have been a few people, like me, who have had similar problems. I have tried replacing the main control board, and then the dispenser display / control board. Neither one has fixed the problem, and I'm still without a water dispenser / ice dispenser. It still makes ice though.
I guess I'll have to call a tech in to fix it.
Quote:
Originally Posted by jeffropcola View Post
I am having the same problem with my refrigerator. When I push the paddle to dispense ice or water the green light will stay on for a second then go out, then come back on. There is some clicking on the mother board but only for a second. Still no water or ice.(the ice maker is making ice) I replaced the door flapper solenoid as instructed by a GE tech and that was not the problem. I also noticed when I depressed the dispenser lever a fan stops running. The filter was changed before i started to troubleshoot the water/ice dispenser. Ayn ideas?
  #42 (permalink)
Old 02-17-2012, 01:28 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Sounds like this is the best solution in such situation. Keep us posted please.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #43 (permalink)
Old 02-23-2012, 01:33 PM
Junior Member
Default
The problem with mine turned out to be a bad connection in the wiring harness which is located just below the freezer door. I guess this wire runs up to the dispenser control board. The small black connector in the harness was all corroded and it looked like it shorted.
After that was repaired it was back to normal. So I had no bad motherboard, valves, frozen lines, or any of that common stuff.
I did end up calling in a pro to fix it.
  #44 (permalink)
Old 02-23-2012, 02:45 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Just wanted to say thank you for the feedback. It is not often we see a failed wire harness connector under the freezer door, so your post was very illuminating and instructive. It will help many other people with the similar problem.
Thanks again, and good luck with your refrigerator.
P.S. If you kept old parts and they are still in working condition, then you probably can return unneeded parts, purchased from APP.
__________________
  #45 (permalink)
Old 02-23-2012, 03:49 PM
Junior Member
Default
Also when I started to describe the problem the first thing the tech said was "bad motherboard." Luckily I had already done a lot of the troubleshooting for him.
I was able to return the parts I didn't need. So all I ended up paying for was the labor today, which was less than the cost of the motherboard anyways.
Thanks for your help on here Gene.
  #46 (permalink)
Old 02-26-2012, 09:42 AM
Junior Member
bonnessei is on a distinguished road
Default
Hello Gene...
My problem is very similar to Ana. I just want to run it past you before I order a board.
Water works, all lights work. When you switch to either ice mode and hit the dispenser the lights go out, night light goes dim, control panel in the fridge goes blank...if the compressor is running it will even kick that off. It also will not dispense water for about 5 mins.
About 30 sec later the display will come back on.
I saw the diagnostic instructions for the LCD display; I have the other non LCD display you posted. Is there a test that can be run from that one?
  #47 (permalink)
Old 02-27-2012, 01:38 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by bonnessei View Post
Hello Gene...
Your problem sounds very different and I don't think you have to run any tests. The new main control board should fix it. If you need to confirm the part number, post the complete model number of the refrigerator.
__________________
  #48 (permalink)
Old 02-28-2012, 09:34 AM
Junior Member
Default
PSI23SGRC SV
Thanks for the help Gene!
  #49 (permalink)
Old 02-28-2012, 04:03 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome.
The main control board Part number: AP4436216
__________________
  #50 (permalink)
Old 03-10-2012, 11:10 AM
Junior Member
Default
That was it...there was blown up electrical parts on the old board. Might be worth taking the cover off and taking a look before you order.
Thanks again Gene.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Refrigerator Water Dispenser Not Working cdadek Refrigerator & Freezer Repair 10 03-16-2015 06:23 PM
Hot Point Refrigerator Water Dispenser not Working mattsimonmx Refrigerator & Freezer Repair 2 02-11-2010 06:26 AM
Water Dispenser not working on GE Refrigerator DCSurvey Refrigerator & Freezer Repair 0 01-13-2010 09:27 AM
Whirlpool Refrigerator water dispenser not working djharv Refrigerator & Freezer Repair 0 11-12-2009 06:48 AM
GE Profile Refrigerator Ice/Water Dispenser not working steveplak Refrigerator & Freezer Repair 0 10-27-2009 06:26 AM
