Discuss
GE Profile Refrigerator Ice/water dispenser not working
 in
Refrigerator & Freezer Repair
Do you have any reference that I can refer to on how to install the interface display? I just ordered
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » GE Profile Refrigerator Ice/water dispenser not working
  #11 (permalink)
Old 06-15-2011, 12:00 AM
Junior Member
TechBang! is on a distinguished road
Default
Do you have any reference that I can refer to on how to install the interface display? I just ordered it. I appreciate your time.
  #12 (permalink)
Old 06-15-2011, 03:14 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Sure. The instructions are attached to the reply.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #13 (permalink)
Old 06-15-2011, 03:18 PM
Junior Member
Default Thanks :)
Those instructions show a different model but I will check when I get home if the removing instructions just may be the same with my model. I appreciate all your help! Thank you very much
  #14 (permalink)
Old 06-15-2011, 03:35 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome.
These instructions are from the Service manual for a few different models including yours. It should work.
Keep us posted.
__________________
  #15 (permalink)
Old 06-15-2011, 03:36 PM
Junior Member
Default
Will do! Thanks again
  #16 (permalink)
Old 06-15-2011, 03:55 PM
Junior Member
Tatersalad is on a distinguished road
Default Try this
Quote:
Originally Posted by TechBang! View Post
It was just replaced a month ago.
Open and close the water supply valve a couple times, then check water flow thru the door.
Whirlpool ice maker won't make ice.
  #17 (permalink)
Old 06-22-2011, 06:14 PM
Junior Member
Default I tried this and it did not work.
Quote:
Originally Posted by Gene View Post
You are welcome.
Keep us posted.
Gene,
I purchased a new and replaced the interface and the problem persisted. I replaced the interface then the interface was still not lighting up until around 5 minutes later the lights on the display come on then about 5 minutes later after the lights turn off again. Is there another possibility what this can be? Your help is appreciated.
  #18 (permalink)
Old 06-22-2011, 07:47 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
All power to the LCD board supplied by the main control board (#801 on the diagram) through the J4 connector (in the upper right corner on the following picture).
So, if there is nothing wrong with the wires between the main control board and the LCD board (the wires can be checked for continuity), then the problem is a bad main control board. If it will not fix the problem, then you can return the LCD board (if it's not needed and ordered from APP).
- The main control board kit (the instructions are included) Part number: AP3957581
P.S. This refrigerator has been designed by GE to use a special Diagnostic Aid Kit to functionally test individual components. This kit cost over $100 and is not returnable. That's why there is an element of guessing in my recommendations.
__________________
  #19 (permalink)
Old 07-15-2011, 01:35 PM
Junior Member
Default
Are you speaking of the water valve from the wall? I am not for certain if that is the only valve that we are speaking of and if there are any other water valves that I am not aware of. How would I check the water flow thru the door? Please advise.
  #20 (permalink)
Old 07-15-2011, 01:40 PM
Junior Member
Default
So, if there is nothing wrong with the wires between the main control board and the LCD board (the wires can be checked for continuity), then the problem is a bad main control board. If it will fix the problem, then you can return the LCD board (if it's not needed and ordered from APP).
Gene,
I replaced the main control board with no such luck, the problem still exists. How would I go about checking the wires for continuity? I'm guessing this is the last thing to check. Again, youre help is greatly appreciated.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Refrigerator Water Dispenser Not Working cdadek Refrigerator & Freezer Repair 10 03-16-2015 06:23 PM
Hot Point Refrigerator Water Dispenser not Working mattsimonmx Refrigerator & Freezer Repair 2 02-11-2010 06:26 AM
Water Dispenser not working on GE Refrigerator DCSurvey Refrigerator & Freezer Repair 0 01-13-2010 09:27 AM
Whirlpool Refrigerator water dispenser not working djharv Refrigerator & Freezer Repair 0 11-12-2009 06:48 AM
GE Profile Refrigerator Ice/Water Dispenser not working steveplak Refrigerator & Freezer Repair 0 10-27-2009 06:26 AM
