Discuss
Need help with GE mini fridge
 in
Refrigerator & Freezer Repair
Hi everyone, just looking for some help with a GE mini fridge I had picked up from the girlfriends work;
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Need help with GE mini fridge
  #1 (permalink)
Old 07-29-2009, 10:42 PM
Junior Member
Feanux is on a distinguished road
Exclamation Need help with GE mini fridge
Brand: -brand-   Age: Less than 1 year
Hi everyone, just looking for some help with a GE mini fridge I had picked up from the girlfriends work; it stopped getting cold so they decided to trash it, I offered to take it to see what I could do with it.
And that's where my lack of knowledge comes in, and I ask the all knowing for help .
The model # is ax4dnybwh, its the "Y series" I believe.
I know it's kind of vague but if anyone can help it would be greatly appreciated.
Feanux
  #2 (permalink)
Old 07-30-2009, 03:46 PM
Senior Member
applianceman is on a distinguished road
Default
Turn it on and see if the compressor is running or not. If the compressor will not run there are two things that will most likely cause this, the start relay and the cold control. If the compressor tries to runs and then clicks off the start relay is most likely bad. If you donít hear any noise the cold control is most likely the problem.
If the compressor runs but it doesnít get cold you got a sealed system problem.
If the compressor runs and it seems to cool it may have just need defrosting.
Refrigerator repair guide
  #3 (permalink)
Old 07-30-2009, 08:03 PM
Junior Member
Default
When I turn it on, the compressor does kick on and it sounds like water trickling, but it just doesn't get cold. So according to your post, it's a sealed system problem.
  #4 (permalink)
Old 07-31-2009, 06:14 AM
Senior Member
Default
Let it run a while to be sure but that is what I would say. Repairing a sealed system problem would be to costly for that small refrigerator.
  #5 (permalink)
Old 01-04-2010, 04:00 PM
Junior Member
jleonard711 is on a distinguished road
Default
I know this thread is a few months old, but I'm having the exact same problem with my G.E. mini fridge. The other day I noticed that the fridge in my office was making clicking noises, so I opened it up and found that it was losing cold and everything in the freezer was melting. By the end of the day it was not cold at all any more. I unplugged it overnight and then plugged it back in the next day, thinking that might help, but it doesn't sound like the compressor is turning on at all. It makes a clicking sound ever few minutes and the compressor gets warm if I leave it plugged in for a while, but the compressor never fires up. Would this be a faulty compressor? Or could it mabe just be the compressor start relay? Is there any way I can test the compressor by bypassing the start relay?
  #6 (permalink)
Old 01-04-2010, 06:54 PM
Senior Member
Default
It sounds like the start relay is bad. I donít recommend trying to by-pass the start relay. Unplug it and remove the cover off the side of the compressor. Once done you should see the start relay (it will be to black/brown device plugged into the two bottom compressor contacts). Pull the start relay off and shake it, if it rattles it is bad. If it doesnít you can be reasonably sure it is ok.
A bad compressor can cause the relay to go bad. But the best way to know for sure is to replace the relay. If the relay doesnít repair it, the compressor is bad.
I assume since it is a mini it doesnít have a fan by the compressor but if it does make sure it will run.
  #7 (permalink)
Old 02-18-2010, 08:13 PM
Junior Member
thepirate is on a distinguished road
Default
Mini refrigerators don't warrant fixing unless it's a quick process. Check the compressor and anything that's an easy fix. If it's more difficult then that, it's probably not worth the cost price wise.
  #8 (permalink)
Old 10-23-2014, 10:57 PM
Junior Member
trader55 is on a distinguished road
Default Fridge having no power
I have a GE mini fridge and when I plug it in nothing happens. No power....no sound...nothing.
Is there a reset switch or something I can test that is fairly simple in order to see if I can get this fridge to power on.
I get no compressor noise or nothing. If anyone can help and give me some suggestions I'd appreciate it. I'm pretty mechanical and pretty cheap so I'm willing to take this apart if necessary.
thanks
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire Mini Fridge doesn't get cold after Rain and circuit breaker! Duce Refrigerator & Freezer Repair 16 02-27-2012 07:03 PM
Thermostat problem with mini fridge Edogyip Refrigerator & Freezer Repair 4 02-18-2010 08:26 PM
Mini fridge freezer frosting over Insaneman1731 Refrigerator & Freezer Repair 0 08-23-2009 01:27 PM
Montgomery wards mini fridge sambonnie Refrigerator & Freezer Repair 2 08-12-2009 07:10 AM
