Discuss
Freezer is fine, refrigerator is too warm.
 in
Refrigerator & Freezer Repair
devsam2@yahoo.com, In such GE refrigerators when the evaporator fan goes bad it causing damage to the main control
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer is fine, refrigerator is too warm.
  #131 (permalink)
Old 09-03-2008, 03:04 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
devsam2@yahoo.com,
In such GE refrigerators when the evaporator fan goes bad it causing damage to the main control board. Both of these parts should be replaced together.
Here are the break down diagrams for the GE refrigerator Model GTS22WCMARWW
__________________
Professional appliance repair in Los Angeles, California.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #132 (permalink)
Old 09-03-2008, 06:37 PM
devsam2@yahoo.com devsam2@yahoo.com is offline
Junior Member
devsam2@yahoo.com is on a distinguished road
Thumbs up Thanx...
...for quick response!
I just placed an order for the board.
Johnnie
Is there anything I need to know when replacing it?
  #133 (permalink)
Old 09-03-2008, 06:48 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Not much. Keep us posted.
__________________
  #134 (permalink)
Old 09-08-2008, 05:24 PM
Keith Leslie Keith Leslie is offline
Junior Member
Keith Leslie is on a distinguished road
Default
So, I went into the parts diagram and there is no defrost timer for my GE refrigerator. now what?
  #135 (permalink)
Old 09-08-2008, 05:29 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Keith,
What is the complete model number of the refrigerator?
What is wrong?
__________________
  #136 (permalink)
Old 09-09-2008, 04:07 AM
Junior Member
Default
Gene,
GE model #GSS25UFMC-BB. The the refrigerator is too warm. There is no air coming thru the port window and some frost on the back of the freezer. The motor run continuously. I checked the parts diagram for a defrost timer and apparently it does not have one. Now what?
  #137 (permalink)
Old 09-09-2008, 05:43 AM
pz7rx8 pz7rx8 is offline
Junior Member
pz7rx8 is on a distinguished road
Default Maytag fridge similar problem
I have a Maytag MSD2756GE with a similar problem. However, I have not noticed any frost build up of any kind. I normally keep the refrigerator temp control in the middle. I noticed the fridge getting warm and set the control all the way up. This seems to be working for now. I've checked for air flow and can feel cool air coming in at the top.
Joe
  #138 (permalink)
Old 09-09-2008, 11:48 AM
gnuage gnuage is offline
Junior Member
gnuage is on a distinguished road
Post Model MSD2756DE refrigerator warm
Hi Gene,
My MayTag MSD2756DE refrigerator is getting warm, the freezer is working fine without any frost. I have visually inspect the evap fan behind the panel in the freezer, everything seems to be normal. No frost build up. All air vents are cleared as well. I have read your previous posting, look like it could be a bad damper control? If so what part do I need? Please advise.
Best Regards,
Frank
  #139 (permalink)
Old 09-09-2008, 12:51 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Keith,
Looks like there is a problem with the defrost in your fridge. You can find the complete troubleshooting instructions in one of our previous posts: Freezer is fine, refrigerator is too warm.
Here are the break down diagrams for the GE refrigerator Model GSS25UFMCBB
__________________
  #140 (permalink)
Old 09-09-2008, 12:56 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Joe,
Remove the rear cover in the freezer and check the evaporator coil. Normally it should be completely covered in light snow.
Remove the back cover and clean the condenser coil. Make sure the fan next to the compressor is running.
Post the results.
Here are the break down diagrams for the Maytag refrigerator Model MSD2756GEB
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Refrigerator & Freezer warm GaryS Refrigerator & Freezer Repair 1 11-14-2007 12:34 PM
Warm Refrigerator and Freezer chuckmielke Refrigerator & Freezer Repair 0 11-10-2007 12:36 PM
Freezer works fine but refrigerator does not hold temperature mikel500 Refrigerator & Freezer Repair 0 10-16-2007 06:57 AM
freezer fine, refrigerator compartment not michael dykstra Refrigerator & Freezer Repair 0 08-20-2007 11:23 AM
freezer fine, refrigerator not cold fargnoli Refrigerator & Freezer Repair 0 08-08-2007 10:24 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
