Discuss
Freezer is fine, refrigerator is too warm.
 in
Refrigerator & Freezer Repair
control panel location?perhaps in the back near the compressor.the fridge has only min-max turn knob inside.or
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer is fine, refrigerator is too warm.
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #81 (permalink)
Old 06-24-2008, 01:20 AM
chlear909 chlear909 is offline
Junior Member
chlear909 is on a distinguished road
Default
control panel location?perhaps in the back near the compressor.the fridge has only min-max turn knob inside.or maybe in the freezer near the defrost switch?
what does the defrost heater look like?
thanks for your help
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #82 (permalink)
Old 06-24-2008, 12:46 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
I'm not able to tell you where the defrost timer is located because I do not have break down diagrams for this model. You have to search your refrigerator for a part looks similar to the picture I posted earlier.
The defrost heater is a tube in the evaporator area with two wires attached to it.
__________________
Professional appliance repair services in Orange County, California.
  #83 (permalink)
Old 06-27-2008, 12:28 AM
tyang54 tyang54 is offline
Junior Member
tyang54 is on a distinguished road
Default
Quote:
Originally Posted by abadfish66 View Post
Cut the defrost thermistat out and connect the 2 wires together and see if the heater comes on, just leave enough wire so you can reconnect it after testing.
So I did this and the heater is not really running. I tried checking voltage across the circuit and I am getting 2.4V AC Is this enough to drive the circuit? I tested my circuit all the way to the input for the freezer compartment which also reads 2.4 V.
My question is
1. is 2.4V the correct voltage going across the heating element and
2. if not, where can I be checking upstream for the proper voltage?
I am definitely not getting enough current across the heating element when the freezer is in defrost mode.
  #84 (permalink)
Old 07-04-2008, 11:13 AM
jszczypien jszczypien is offline
Junior Member
jszczypien is on a distinguished road
Default GE Fridge TFX26ZPDABB 60degrees in the Fridge...
Hello appliance wizards, freezer cold fridge not...I pulled the back freezer panel no excessive frost, no blockage in the bottom vent, (the dial one) freezer fan is blowing good, coils are clean and compressor is hot...there isnt allot of airflow from inside the top fridge....Any ideas
  #85 (permalink)
Old 07-04-2008, 01:25 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
How the coils in the freezer are covered with frost - partialy or all coils?
__________________
  #86 (permalink)
Old 07-04-2008, 01:27 PM
Junior Member
Default
nice overall light snow...
  #87 (permalink)
Old 07-08-2008, 04:51 PM
ROCK4200 ROCK4200 is offline
Junior Member
ROCK4200 is on a distinguished road
Default
Hello,
I am having a similar problem with my GE model # GTS22WCMARBB my freezer works but my fridge doesn't. I understand how this fridge works it has a 3 speed evap fan to push air into the fridge duct. I replaced the evap fan back in April of this year do to the motor making noise. Now i opened up to where the circuit board is found out where my fan pins are. We are getting voltage about 12.80 - 13.00V but, when I plug the Evap fan in the fan spinns about 2 -3 revolutions and stops , we also tested out the fan and the fan reads good also I saved my old fan the one that was making noise swap that and it does the same thing. Please help do you think it is the circuit board? Wanted to know before I purchase the part.
Thanks,
Jeff
  #88 (permalink)
Old 07-08-2008, 05:30 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
jszczypien,
Check the damper control (#428 on the break down diagram) and the duct air return (# 434 on the break down diagram) for any blockages.
Here are the break down diagrams for the GE refrigerator Model TFX26ZPDABB
__________________
  #89 (permalink)
Old 07-08-2008, 05:58 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
ROCK4200,
At the fan motor connector, check for 13VDC from the red to white wire and 8-13VDC from the white to yellow wire.
If the voltage is correct then the fan motor is bad.
If the voltage is wrong then unplug the J-2 connector on the main control board. Check for 13VDC between pins J2-3 and J2-8 8-13VDC between pins J2-3 and J2-4.
If the voltage is wrong replace the main control board.
If the voltage is correct then the problem is a bad wiring harness.
If there is less than 1 K ohm between white to red or white to yellow wires on the evaporator fan motor, the motor is bad and has to be replaced together with the main control board.
- The part number for the main control board is AP3950129
- The part number for the evaporator fan motor&thermistor assembly is AP3191003
Here are the break down diagrams for the GE refrigerator Model GTS22WCMARBB
__________________
  #90 (permalink)
Old 07-09-2008, 02:57 PM
Junior Member
Default
Hey Gene, i didn't see any blockage in the damper...do you think it could be part #257 ? Check the pics of the coil. one was on 7-4 about 15mins with the door open. Check the one from today july9, taken immediately...let me know what you think...
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Refrigerator & Freezer warm GaryS Refrigerator & Freezer Repair 1 11-14-2007 11:34 AM
Warm Refrigerator and Freezer chuckmielke Refrigerator & Freezer Repair 0 11-10-2007 11:36 AM
Freezer works fine but refrigerator does not hold temperature mikel500 Refrigerator & Freezer Repair 0 10-16-2007 05:57 AM
freezer fine, refrigerator compartment not michael dykstra Refrigerator & Freezer Repair 0 08-20-2007 10:23 AM
freezer fine, refrigerator not cold fargnoli Refrigerator & Freezer Repair 0 08-08-2007 09:24 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
