Discuss
Freezer is fine, refrigerator is too warm.
 in
Refrigerator & Freezer Repair
Originally Posted by Gene Grayelve, What was the original problem? The model number you posted does not come up and
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer is fine, refrigerator is too warm.
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #31 (permalink)
Old 05-01-2008, 01:15 PM
Grayelve Grayelve is offline
Junior Member
Grayelve is on a distinguished road
Smile
Quote:
Originally Posted by Gene View Post
Grayelve,
The model number you posted does not come up and I can not tell you exactly which part where is located. Verify the model number and repost it. Also if this is not American model then we are not able to get any information.
Thanks for your response Gene ... The original problem was water dripping into the frig compartment and collecting in the bottom plus the frig compartment was not very cold. Tag in frig wall says assembled in Mexico and the model # is cr11ffwr. Did a search for the heater with that # and I get an available part number for the heater from a site on the net. No luck finding a parts illustration though. There was a print on the back of the refrigerator that was helpful in trouble shooting. Fan was stopped when I opened things up and the heater was hot. I think a gremlin got into the mix because the fan bench tested OK so I checked for voltage to it and It was not there. Went to the Thermostat control and started to pull the connectors off but walah the hot (orange) lead gave an arc and things started working. Frig compartment is holding at 38 degrees and I open the vent control a notch. Will recheck today and wrap a peice of copper wire around the heater to the drain tube for drain insurance. I will give you my update after rechecking my daughter's frig. Sure would like to find a parts illustration/breakdown for numbers and locations though. Thanks Again
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #32 (permalink)
Old 05-02-2008, 12:55 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Unfortunately there is nothing available for this model on-line.
__________________
Professional appliance repair services in Orange County, California.
  #33 (permalink)
Old 05-02-2008, 02:38 PM
Junior Member
Default
All is well with the frig adventure ... Everything working. Thanks for trying to find the illustration/breakdown. Have a good one
  #34 (permalink)
Old 05-05-2008, 01:42 PM
Southern Southern is offline
Junior Member
Southern is on a distinguished road
Default Roper/Whirlpool Compressor Relay
Before we go further I need the complete model number of the fridge.
How do replace the compressor Relay;
Model Roper: RT18AKXJW00
Series: EK30107011
Year 07-2000
I was told this is a common problem with this model of Whirlpool?
  #35 (permalink)
Old 05-05-2008, 01:54 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Southern,
What is the original problem with your fridge?
__________________
  #36 (permalink)
Old 05-19-2008, 12:39 PM
MaxUs MaxUs is offline
Junior Member
MaxUs is on a distinguished road
Default Problem with Fan in ET18GM
Hello Gene,
I have a problem with Whirlpool refrigerator ET18GM: Freezer is cool, but refrigerator is too warm. I tried to check the problem and found than the fan is never works. I tried to disassembly refrigerator in order to check the fan, but failed. How can I do it? Is there some instruction for it?
Thanks for help, Max
  #37 (permalink)
Old 05-22-2008, 05:33 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Max,
Remove the two screws holding the freezer floor (#25 on the break down diagram) and pull the floor out.
Remove the rear panel and the fan is yours.
- The part number for the evaporator fan motor is AP3139953
Here are the break down diagrams for the Whirlpool refrigerator Model ET18GMXHN00
__________________
  #38 (permalink)
Old 05-23-2008, 01:48 PM
KeithinKY KeithinKY is offline
Junior Member
KeithinKY is on a distinguished road
Default
I have a ge mod GSS201EPD WW SER# GG276416. I have the same problem. I have to remove the back panel in the rear of the freezer and thaw out the evap coil every 7 days. It doesn't have a timer like the old ones , but a defrost board. I haven't checked the defrost tstat yet but I hope that could be the prob as it is the cheepest part. Could this be the defective part? It should check N.O. if warm and N.C. if cold?
  #39 (permalink)
Old 05-23-2008, 02:09 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Keith,
You were right, the defrost cycle controls by the main control board on the back of the fridge.
Unplug the refrigerator, remove the blue wire from the "defrost" terminal J9 on the control board and measure the resistance between this wire and the neutral orange wire (pin 9 on the J7 connector). The freezer must be cold at this time.
If the reading is about 22 Ohms then the main control board has to be replaced. It is recommended to replace the board together with both freezer thermistors.
If the circuit is open then you have to remove the rear panel in the freezer and check the defrost heater (#230 on the break down diagram)and the defrost thermostat (#240 on the break down diagram) for continuity.
If any one of them is open - it has to be replaced.
- The part number for the main control board is AP3950129
- The part number for the defrost heater is AP4355467
- The part number for the defrost thermostat is AP3884317
- The part number for the freezer thermistors (they are identical) is AP3185407
__________________
  #40 (permalink)
Old 05-23-2008, 02:16 PM
Junior Member
Default
Thanks Very Much Gene! I will do this later this evening. Your help is greatly appreciated!
Keith
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Refrigerator & Freezer warm GaryS Refrigerator & Freezer Repair 1 11-14-2007 11:34 AM
Warm Refrigerator and Freezer chuckmielke Refrigerator & Freezer Repair 0 11-10-2007 11:36 AM
Freezer works fine but refrigerator does not hold temperature mikel500 Refrigerator & Freezer Repair 0 10-16-2007 05:57 AM
freezer fine, refrigerator compartment not michael dykstra Refrigerator & Freezer Repair 0 08-20-2007 10:23 AM
freezer fine, refrigerator not cold fargnoli Refrigerator & Freezer Repair 0 08-08-2007 09:24 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
