| » Freezer is fine, refrigerator is too warm. |
Mike,
Make sure the drain in the freezer (under the evaporator) is completely open. Here are the breakdown diagrams and Replacement parts for General Electric GDS18LBRABB Refrigerator | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Quote:
I first want to say thanks everyone for their quick reply. I have checked the evaporator drain( poured water down and it came out the bottom of the back of the fridge). I also checked Part# 8 and it seems pretty dry. as of right now I have part #2 completely off and I am running the fridge with part# 15 closed up pretty good. Like I said it seems the defrost cycle is doing its job however the evap coils seem to ice over pretty fast(~1hour maybe less) and stop the evap fan. Not sure but I would say this either is poor circulation from the evap fan, or lack of refrigerant but I dont think thats possible. ? Thanks again! Mike |
Quote:
__________________
Check your evaporator fan motor rotation & can you identify where the fan is touching the ice? Is it in the housing or the evaporato coil ice . After 1 hour it should not build up so much ice to block the fan. Put the cover back on & ck air flow in both freezer & ref section. Also is the evaporator fully frosted going down to the SUCTION LINE .
Hello everyone. This is my first post.
I have a model GSH22JFTACC which is freezing up. The main board was changed in January but is still freezing up. After reading a bit. I looked for the thermistors. I think they are original since they don't appear to be spliced. I'll try to test them next. Does anyone know if there's away to get the computer to turn on the defrost cycle besides jumping out the line and defrost terminals? Thanks |
I do not think this model has ability to force defrost cycle.
__________________
Quote:
Hi Gene, Thanks for the reply. I'd think GE would make some kind box which connects to a laptop to run the appliance through a complete diagnostic check and spit out error codes. BTW I cut out the evaporator thermistor and put it in another freezer at -5 Degrees. At first it seemed to work normal and then it would measure about 1.5K ohms Now it's working again measures about 44K. Do these fail in such a way that they work intermittently? Thanks again, Larry Last edited by labjr : 04-22-2010 at 03:06 PM. |
| Display Modes | |
| freezer fine refrigerator too warm | cibao67 | Refrigerator & Freezer Repair | 5 | 07-10-2012 06:42 PM |
| Freezer is fine; refrigerator warm | LaDonna357 | Refrigerator & Freezer Repair | 15 | 03-28-2012 04:55 AM |
| Freezer is fine, refrigerator is too warm | amnhac81 | Refrigerator & Freezer Repair | 0 | 07-10-2009 02:48 PM |
| Freezer is fine, refrigerator is too warm. | allemich | Refrigerator & Freezer Repair | 3 | 04-20-2009 07:08 PM |
| Freezer is fine, refrigerator is too warm. | silvia28 | Refrigerator & Freezer Repair | 0 | 08-05-2008 10:16 AM |
