| » Freezer is fine, refrigerator is too warm. |
The defrost timer is shown as #257 on the diagram. Before ordering any parts I would recommend to perform the troubleshooting as described on the first page of this thread.
Here are the breakdown diagrams and Replacement parts for GE TFX22KRDAWW | AppliancePartsPros.com Gene.
__________________
Professional appliance repair in Orange County, California. |
Quote:
Thanks for your response, this is a great website and great place to order parts. Local place said they could get me part in 7-10 days and would cost more money. |
A bad defrost heaters is one of most common problems with GE refrigerators. I hope this repair solved the problem. Thank you for your good words and your feed back. Good luck with your refrigerator.
__________________
Thanks Gene for your excellent explanations. I was able to diagnose a problem with my defrost thermostat. You may want to mention that it is also called a Bimetl - def. It will take a week for my part to arrive.
Is it OK to run the fridge without the metal back panel in the freezer so I can easily run the defrost by bypassing the thermostat? It also seems like the refrigerator runs constantly without stopping - could this be related to leaving the back panel off? I have a Kenmore KBRS22KFWH0 with the freezer on the bottom. Last edited by ackscott : 07-31-2009 at 12:28 PM. |
Quote:
__________________
Quote:
Can you help,me?? Thanks Jack |
My freezer compartment is fine, but refrigerator compartment stays at 60 degrees. The door seals seem hot. There was no frost on the surface of the back panel. I unplugged and completely thawed the unit. I took off the back panel of the freezer and there was no frost, but I suspected I may have thawed it in the process of cleaning. I plugged it back in and it ran overnight. The evaporator fan was running all night. In the morning I took off the back panel and there was no frost, and the refrigerator was 60 degrees, but the freezer compartment was cold -- food was frozen hard. I looked down the tube from the evaporator fan to the refrigerator and the baffle was closed. It does not appear to be a defrost problem, unless the defrost is running constantly. What do you think?
| Display Modes | |
| Refrigerator & Freezer warm | GaryS | Refrigerator & Freezer Repair | 1 | 11-14-2007 12:34 PM |
| Warm Refrigerator and Freezer | chuckmielke | Refrigerator & Freezer Repair | 0 | 11-10-2007 12:36 PM |
| Freezer works fine but refrigerator does not hold temperature | mikel500 | Refrigerator & Freezer Repair | 0 | 10-16-2007 06:57 AM |
| freezer fine, refrigerator compartment not | michael dykstra | Refrigerator & Freezer Repair | 0 | 08-20-2007 11:23 AM |
| freezer fine, refrigerator not cold | fargnoli | Refrigerator & Freezer Repair | 0 | 08-08-2007 10:24 PM |
