Discuss
Freezer is fine, refrigerator is too warm.
 in
Refrigerator & Freezer Repair
Originally Posted by jhill Gene, I have a KitchenAid KSSP42QJS00 Remove the upper grill and look for an envelope with
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer is fine, refrigerator is too warm.
  #471 (permalink)
Old 07-13-2009, 03:40 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by jhill View Post
Gene,
Remove the upper grill and look for an envelope with the tech sheets. Perform the teats as described there and post the results.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KSSP42QJS00 | AppliancePartsPros.com
__________________
  #472 (permalink)
Old 07-23-2009, 07:01 PM
Mr_Tantrum Mr_Tantrum is offline
Junior Member
Mr_Tantrum is on a distinguished road
Default Side-by-side still having probs with fridge cooling
Gene,
I appreciate the knowledge you have shared on this topic, and it has been useful to me. However, I'm still experiencing the same problem. I have a GE side-by-side model GSH25JSTA SS. Several months ago, I noticed that the fridge side was 50 degrees + even though the freezer was working properly. After finding your message, I determined that the coils were frozen so I thawed them and hope for the best. To make a long story short, based on continuity tests it seemed as if the motherboard was not working correctly, so I replaced it with a new one from my local GE parts supply. To my surprise, the problem returned within 2 weeks. So, even though I thought they tested okay, I replaced the thermostate and heating element about 10 days ago. Well, today my fridge was 50 degrees + again and the coils in the freezer where heavily frosted over.
The only thing that I noticed this time is a loose grounding wire at the bottom of the freezer. I was aware of one located at the top of the freezer that connects to the dividing panel, but this is the first time I saw the one at the bottom. I connected it, but I don't know if it will make a difference or not.
Given the above, do you have any insight as to what my problem might be now? If I have a second faulty MB, how do I specifically test it to prove that it is faulty so that I can exchange it (I tried to follow your directions as posted, but I may be a little unclear as to exactly which leads I should be testing)?
  #473 (permalink)
Old 07-23-2009, 07:08 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I would suspect the evaporator thermistor (on top of the evaporator).
- The thermistor Part number: AP3185407
Here are the breakdown diagrams and Replacement parts for GE GSH25JSTASS | AppliancePartsPros.com
__________________
  #474 (permalink)
Old 07-24-2009, 06:47 AM
Junior Member
Default
Aren't there 2 of these in the freezer (1 at the top & one at the bottom)? Should I go ahead and replace both (are they the same part #)? BTW, what is a thermistor?
  #475 (permalink)
Old 07-24-2009, 02:16 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I meant the top one. I do not think you have to replace both of them, but it's not going to make it worse if you'll do it. Both of them are identical.
Thermistor is a temperature sensor which changes resistance when temperature changes. The main control board monitors its value and operates with defrost cycle.
__________________
  #476 (permalink)
Old 07-24-2009, 02:23 PM
Junior Member
Default
They were cheap enough so I picked up 2 at lunch today from my local parts supplier. What is the best/easiest way to monitor proper operation apart from waiting until everything freezes over? Should I just visually check manually, or is there any way to force a defrost cycle to observe the system in action?
  #477 (permalink)
Old 07-24-2009, 02:47 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You can force the defrost cycle by bypassing wires at the main control board, but I personally do not like it. I would let it work and just monitor it. As you described in the first post, two weeks should be enough to see how it works.
__________________
  #478 (permalink)
Old 07-27-2009, 08:40 PM
wangsooda wangsooda is offline
Junior Member
wangsooda is on a distinguished road
Default
Hi Gene,
I have a Kenmore side by side refridgerator, 106.53606200.
The problem happend this morning, the fridger is not cold enough. There is no problem with a freezer. There is no food blocking the air vent in both sides, but the cold air doesn't come out into fridger. Can you help me what to do?
Thanks in advance.
  #479 (permalink)
Old 07-27-2009, 09:32 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Check if the fan in the freezer works. If it does then replace the air diffuser (in the upper left corner in the fresh food compartment).
- The air diffuser Part number: AP3084126
__________________
  #480 (permalink)
Old 07-27-2009, 09:42 PM
gakawell gakawell is offline
Junior Member
gakawell is on a distinguished road
Default Same Problem
I have a GE TFX22KRDAWW a few weeks ago the fresh food side got warm. I opened the panel in the freezer section and it was a block of ice on the coils. Defrosted and also did a through cleaning of all dust around fridge. It has worked for several days and now same problem. Looking at the parts list I don't see a listing for a defrost timer for this fridge. There is a listing for a defrost heater assembly. I am thinking of going ahead and getting and replacing this. They also list a redsigned assembly, but not sure if that will fit or not. Any suggestions if I am going in the right direction.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Refrigerator & Freezer warm GaryS Refrigerator & Freezer Repair 1 11-14-2007 12:34 PM
Warm Refrigerator and Freezer chuckmielke Refrigerator & Freezer Repair 0 11-10-2007 12:36 PM
Freezer works fine but refrigerator does not hold temperature mikel500 Refrigerator & Freezer Repair 0 10-16-2007 06:57 AM
freezer fine, refrigerator compartment not michael dykstra Refrigerator & Freezer Repair 0 08-20-2007 11:23 AM
freezer fine, refrigerator not cold fargnoli Refrigerator & Freezer Repair 0 08-08-2007 10:24 PM
