| » Freezer is fine, refrigerator is too warm. |
I have a Sears Coldspot 106-7660620 and I cannot find the diagrams. The problem is a defrost issue. I took it apart, saw the ice blockage and did the quick thaw with a hair dryer Do you have the diagrams for this particular model? Edit: Woke up this morning and the fridge is still only on 42F, maybe the problem is something else? Edit: Temp continued to fall and the fridge is well within optimum range now. Thanks! Jeff G. Last edited by JeffG. : 07-01-2009 at 01:18 PM. |
I have a similar concern. I have a GE fridge, bottom freezer around 10-20 degrees. fridge works fine. After reading through this thread I got GE to send me a motherboard, wr55x10656 (w/ instructions for wr55x10552, update for that board?) I installed the board, not cutting the thermistor and capacitor wire. The wire were not present on my fridge. Now the freezer is around 7-8 degrees (after 24 hours) and the fridge is about 3 degrees what i set it to be. Any ideas? there were some yellowish liquard/water underneath the condensor? after the new board it's dry. there's a fan blowing on it, so I'm assuming it's a condensor. I expect to see some moisture on an evaporator, but not a condensor? Any help? thank you.
*I understand the concept of automotive a/c systems so I have a question. If there's a freon leak, would it not affect the fridge side? and I'm assuming the freezer would continue to get warmer and not cool down due to low freon levels correct? |
Quote:
The defrost timer is #342 on the diagram. Looks like it's behind the bottom front grill. Gene.
__________________
Professional appliance repair in Orange County, California. |
Quote:
The defrost timer in your refrigerator is incorporated in the ice maker. If the continuity test for the defrost thermostat and the defrost heater would not show anything wrong then the ice maker has to be replaced. - The part number for the ice maker is AP3154714 Gene.
__________________
Quote:
What is the complete model number of the refrigerator? Gene.
__________________
Sam,
The installation instructions for the new main control board says: "Eliminate thermistor wire in pin 2 of J1 connector." Then is says: "This step is only applicable for the following models: All bottom FREEZER models.". According to your post: Quote:
__________________
You are welcome. I hope so. If it would get worse then post a pictures of the plugs.
__________________
| Display Modes | |
| Refrigerator & Freezer warm | GaryS | Refrigerator & Freezer Repair | 1 | 11-14-2007 12:34 PM |
| Warm Refrigerator and Freezer | chuckmielke | Refrigerator & Freezer Repair | 0 | 11-10-2007 12:36 PM |
| Freezer works fine but refrigerator does not hold temperature | mikel500 | Refrigerator & Freezer Repair | 0 | 10-16-2007 06:57 AM |
| freezer fine, refrigerator compartment not | michael dykstra | Refrigerator & Freezer Repair | 0 | 08-20-2007 11:23 AM |
| freezer fine, refrigerator not cold | fargnoli | Refrigerator & Freezer Repair | 0 | 08-08-2007 10:24 PM |
