Discuss
Freezer is fine, refrigerator is too warm.
 in
Refrigerator & Freezer Repair
My model is Maytag #MSD2756GEW I can't see the defost time on beark down diagram, it had Adptive Defrost,
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer is fine, refrigerator is too warm.
  #361 (permalink)
Old 04-22-2009, 08:43 AM
An Dang An Dang is offline
Junior Member
An Dang is on a distinguished road
Default I can't find defrost time on diagram
My model is Maytag #MSD2756GEW I can't see the defost time on beark down diagram, it had Adptive Defrost, Defrost Heater, Defrost Thermostat so how do I find the Defrost Timer on this model.
  #362 (permalink)
Old 04-22-2009, 04:33 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by An Dang View Post
...it had Adptive Defrost...so how do I find the Defrost Timer on this model...
There is no any timers because the defrost cycle controls by the adaptive defrost control which is most likely the culprit.
Here are the breakdown diagrams and Replacement parts for MAYTAG MSD2756GEW | AppliancePartsPros.com
__________________
  #363 (permalink)
Old 04-23-2009, 09:50 AM
JKarger JKarger is offline
Junior Member
JKarger is on a distinguished road
Default
Hello Gene
Thanks for all your help got it fixed. One thing I'm not sure of, there is a looks like a sensor in a clear tube that is below the water file line it comes from the fresh food side does that come out the motor cover plate like the fill line does for the ice maker or does it stay in back of the cover plate? There is a hole for it but I can't remember. Model # GE tps24bpdabs
Thanks Jason
  #364 (permalink)
Old 04-23-2009, 01:30 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome, Jason. I'm afraid I did not get clear your last question. Can you refer to the numbers on the diagram?
__________________
  #365 (permalink)
Old 04-23-2009, 04:55 PM
LAWRENCE5 LAWRENCE5 is offline
Junior Member
LAWRENCE5 is on a distinguished road
Default
gene
i am trying to find the defrost thing on the back of the refrigerator. i looked at the disgram but dont know what to look for. the model number is gss201epaww.
thanks
linda
  #366 (permalink)
Old 04-23-2009, 05:10 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Linda,
What exactly is wrong with your refrigerator?
Here are the breakdown diagrams and Replacement parts for GE GSS20IEPAWW | AppliancePartsPros.com
__________________
  #367 (permalink)
Old 04-23-2009, 10:26 PM
tjl tjl is offline
Junior Member
tjl is on a distinguished road
Default
My replacement heater kit has just arrived. I read from the instructions that I may need RTV102 to seal the bell connector if I need to cut the wire. Will regular caulk for home repairs work?
Quote:
Originally Posted by tjl View Post
I removed the back panel today as instructed by Gene. The continuity test on the heater turned out to be open. The thermostat showed a low resistance (<1, freezer cold). I am pretty sure now the defrost heater is burned. I remember in another post somebody said both thermostat and the heater need to be changed. Do I have to change both?
  #368 (permalink)
Old 04-23-2009, 10:50 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
It has to be waterproof.
__________________
  #369 (permalink)
Old 04-24-2009, 09:19 AM
Jaime Perez Jaime Perez is offline
Junior Member
Jaime Perez is on a distinguished road
Default frost build up
hi Gene
i have maytag ref. mod. # MZD2766GED AND i have frost buid up back of my freezer panel,fan is blowing good and can't find defrost timmer on break down diagram. did change the heater& therm. assy. part # ap4069923 and still no cool ref. any help thanks jaime
  #370 (permalink)
Old 04-24-2009, 09:47 AM
Junior Member
Default
gene,
my freezer has been defrosting the food, not making ice and has build up of frost on the back panel of the freezer, the refrdge part has been cool but not cold like it has been.
thanks
linda
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Refrigerator & Freezer warm GaryS Refrigerator & Freezer Repair 1 11-14-2007 12:34 PM
Warm Refrigerator and Freezer chuckmielke Refrigerator & Freezer Repair 0 11-10-2007 12:36 PM
Freezer works fine but refrigerator does not hold temperature mikel500 Refrigerator & Freezer Repair 0 10-16-2007 06:57 AM
freezer fine, refrigerator compartment not michael dykstra Refrigerator & Freezer Repair 0 08-20-2007 11:23 AM
freezer fine, refrigerator not cold fargnoli Refrigerator & Freezer Repair 0 08-08-2007 10:24 PM
