Discuss
Freezer is fine, refrigerator is too warm.
 in
Refrigerator & Freezer Repair
Originally Posted by Sworddylan ...Hello all! I just picked up this Maytag french door fridge, model number MFI2568AES... Hello. Is
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer is fine, refrigerator is too warm.
  #2031 (permalink)
Old 10-12-2017, 07:28 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Hello.
Is your refrigerator new or used?
How long it's been running at your place?
What are the set temperatures? It supposes to be between 0F to -2F for the freezer and about 38F for the refrigerator. Let it run for about 10-12 hours before checking the temperature.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #2032 (permalink)
Old 10-13-2017, 09:06 AM
Junior Member
Sworddylan is on a distinguished road
Default
Quote:
Originally Posted by Gene View Post
Hello.
It is used. Its been running for 4 days or so. I believe i figured out the issue. I first noticed the ice compartment fan was not running unless i helped it start. I ordered and replaced it and it would spin, but still not cool properly. Air flow was minimal. i finally found the into to put the fridge into service mode and notice when i turned on the fans it was only producing 5 volts on high. after further research i found a post about testing the main board and found it was only outputting 6 volts. Ive ordered a reman board and it should be here on monday. This also explains why the ice maker is not working.
  #2033 (permalink)
Old 10-13-2017, 01:59 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are on the right track. Keep us posted, please.
__________________
  #2034 (permalink)
Old 11-22-2017, 09:07 PM
Junior Member
Rudy S is on a distinguished road
Default Model Unknown
Good evening,
Unfortunately, the refrigerator door was left open for two consecutive nights and now the refrigeration portion of the unit is malfunctioning. It took a few days, but eventually the temperature increased to a point where all the food spoiled. I unplugged the fridge for over 12 hours and upon giving it power once again, it worked fine for a day or two and then it started to warm again.
What do you think the problem is?
Thanks!
  #2035 (permalink)
Junior Member
Good evening,
Thanks!
  #2036 (permalink)
Old 11-23-2017, 12:46 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Try to find the model number. Otherwise, it's just guessing.
__________________
  #2037 (permalink)
Old 11-30-2017, 06:47 AM
Junior Member
sheilam512 is on a distinguished road
Default Whirlpool GX5FHTXVY06 evaporator fan slow
Hi
I am having issues with a warm fridge. Whirlpool model # GX5FHTXVY06. Maybe 6 years old? This is a french door/bottom freezer model. The evaporator fan is running slow. Sort of pulses and is barely pushing air.
A few weeks ago my the fridge temp control started to move by itself up to 7. I would move it back down and it would stay for a few days then repeat. Then last week the controls were no longer responsive and I could not move up or down. The fridge and freezer were both working.
I replaced the jazz board and the temp controls worked again but the next day noticed that the fridge was warm. Freezer was still cold.
Noticed that the fan was not moving correctly. Replaced the fan. Still moving slowly-sort of pulsating. Did the fan diagnostic test and no response from fan.
Obtained a new jazz board and the fan does respond to the diagnostic test but still moves too slow to move air.
Not sure what I should try next. Any suggestions would be appreciated
  #2038 (permalink)
Old 12-20-2017, 09:18 AM
Junior Member
imref is on a distinguished road
Default
Hi, I have a Whirlpool GI7FVCXXY00 french door refrigerator/freezer. It is about 6 years old and has worked fine until recently when I noticed that the freezer was cold but the refrigerator had warmed up to about 52 degrees. The compressor fan was running but not the evaporator fan. I inspected the coils and they looked fine. I unplugged the fridge, waited a few minutes, plugged it back in, and everything appeared to be working again. This has now happened several more times. Each time I unplug the fridge, wait a minute or so, then plug it back in and it works again for a week or two. I've replaced the main control board on the advice of another repair forum (at a cost of nearly $300) and that hasn't had any impact. Any advice is appreciated.
  #2039 (permalink)
Old 02-10-2018, 05:30 PM
Junior Member
michael52 is on a distinguished road
Default Kenmore/LG French Door freezer too warm.
moved to different topic.
  #2040 (permalink)
Old 04-28-2018, 03:08 AM
Junior Member
markdisouza is on a distinguished road
Smile Re - Freezer is fine, refrigerator is too warm
Refrigerator is one of those home appliances that run day and night. Broken refrigerators are never welcomed no matter what is the level of mercury. Whenever you face some problem with your refrigerator call the same day service of refrigerator repair San Jose. They guarantee to fix the problem with your fridge within few hours of registering complaint.
Appliance Repairs Service San Jose CA | Fix It Right
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Freezer is fine; refrigerator warm LaDonna357 Refrigerator & Freezer Repair 16 06-28-2013 02:56 PM
freezer fine refrigerator too warm cibao67 Refrigerator & Freezer Repair 5 07-10-2012 06:42 PM
Freezer is fine, refrigerator is too warm amnhac81 Refrigerator & Freezer Repair 0 07-10-2009 02:48 PM
Freezer is fine, refrigerator is too warm. allemich Refrigerator & Freezer Repair 3 04-20-2009 07:08 PM
Freezer is fine, refrigerator is too warm. silvia28 Refrigerator & Freezer Repair 0 08-05-2008 10:16 AM
