Discuss
Freezer is fine, refrigerator is too warm.
 in
Refrigerator & Freezer Repair
Hey Gene! Thanks very much for the reply! Beggars can't be choosy, but we whine a lot. thanks again, I
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer is fine, refrigerator is too warm.
  #2021 (permalink)
Old 08-23-2017, 05:46 PM
Junior Member
bookooc is on a distinguished road
Default
Hey Gene!
thanks again, I will try this.
Rick
  #2022 (permalink)
Old 08-23-2017, 06:44 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Good luck.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #2023 (permalink)
Old 08-29-2017, 03:17 PM
Junior Member
Default
Gene,
I finally had a chance to try this.I am assuming the thermistor you are referring to on on the evaporator in the bottom of the fridge?
But it appears there are more than one on the box? The video refers to the one in the freezer, you can't find anything specific to this model/ type.
The problem is, there seems that there are two thermistors? There is one in the wall separating the wall between the FF and freezer. see pic. Is there another one on the evaporator per the video?
The big problem is I can't get the plastic cover off the evaporator. I melted the ice, and I can pull it all loose except on the left side in the middle where it abuts the insulation lower left. It will not budge. Is there a trick to this? the plastic is cracking from pulling so hard. What a pain the butt!!
So I guess I am hoping this is being cause by the thermistier in the wall.
Can you advise. If I had the money I would call a technician and end this nightmare.
thanks
Rick
  #2024 (permalink)
Old 08-29-2017, 04:34 PM
Junior Member
Default
Gene,
I went ahead and replaced the one in the picture. So far no change. I would expect to hear the evaporator fan kick on since the temp is 78F.
It always cools to 45f and stops. But never a fan noise like in the good old days.
All the fans worked when I ran the diags you told me to try. I had also checked the voltages on the MB and they were good.
One constant is that ice buildup you see in the pictures, and water in the bottom of the FF section. The ice is only on that left side there. I guess that is because that is where the coil is coming?
Defrost problem? Would keep the fan from running except in diag mode.
This is really frustrating. I will never buy a dual evaporator again. My old style is 6 years older than this one, never a problem.
thanks
Rick
  #2025 (permalink)
Old 08-29-2017, 05:08 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi, Rick.
Attached is the file with instructions on how to get to the FF evaporator.
Also, I found one of the common problems with this refrigerator was an ice ball formed in the FF compartment. In order to correct this problem, GE designed a special ice ball kit. This kit is expensive. In case if you would like to use it I attached the installation instructions too.
The ice ball kit Part number: AP4315424
File Type: pdf WR49X10180 ice ball kit installation instructions.pdf (648.4 KB, 1 views)
File Type: doc How to accesss fresh food evaporator.doc (1.07 MB, 1 views)
__________________
  #2026 (permalink)
Old 08-30-2017, 10:13 AM
Junior Member
Default
Thanks Gene!
So are you saying there is another temperature sensor on the FF evaporator?
I will get another one ordered if so. I will take a look at files you sent.
Amazing how this was the most expensive fridge out there when I bought it, and yet it is a big pile of junk.
Rick
  #2027 (permalink)
Old 08-30-2017, 09:18 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome, Rick.
I still believe you would need this ice ball kit. It is well-known problem for this model.
BTW, an expensive product does not mean reliable in today's world.
__________________
  #2028 (permalink)
Old 08-31-2017, 11:58 AM
Junior Member
Default
Hi Gene,
yes you are right all on all counts. I bought this model because I liked the idea of the dual evaporator. Now not so much. LOL
I have ordered the ice ball kit too. Hoping this and another thermistor will get me back to cold FF section. Thanks for the instructions, I was missing that 3rd screw, You can't really see it on the evaporator cover.
Glad I didn't force it. Should have all my parts by the 6th.
I will report back.
thanks
Rick
  #2029 (permalink)
Old 09-03-2017, 03:12 PM
Junior Member
Default
Hi Gene,
Hope you holiday is going better than mine.
Well I got this thing torn apart, and determined that the evaporator fan is in fact bad. I ran the self test again and the only fan that come on is the beverage center blower. So what I that's what I head before. So Ouch! I guess I need to buy that whole assembly. I will let you know once I get it.
Rick
  #2030 (permalink)
Old 10-08-2017, 08:38 PM
Junior Member
Sworddylan is on a distinguished road
Default
Hello all! I just picked up this Maytag french door fridge, model number MFI2568AES. The freezer works fine, but the fridge is not getting cool. The condenser fan works, as well as the evap fan. No ice buildup, as it was sitting for awhile before we bought it. Any suggestions, or further things to check or test before i go buying parts would be great! Thanks!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Freezer is fine; refrigerator warm LaDonna357 Refrigerator & Freezer Repair 16 06-28-2013 03:56 PM
freezer fine refrigerator too warm cibao67 Refrigerator & Freezer Repair 5 07-10-2012 07:42 PM
Freezer is fine, refrigerator is too warm amnhac81 Refrigerator & Freezer Repair 0 07-10-2009 03:48 PM
Freezer is fine, refrigerator is too warm. allemich Refrigerator & Freezer Repair 3 04-20-2009 08:08 PM
Freezer is fine, refrigerator is too warm. silvia28 Refrigerator & Freezer Repair 0 08-05-2008 11:16 AM
