Discuss
Freezer is fine, refrigerator is too warm.
 in
Refrigerator & Freezer Repair
My Model is a GE GBS22HBPACC. I have read posts in this thread and elsewhere in the fourm, and have
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer is fine, refrigerator is too warm.
  #2001 (permalink)
Old 05-30-2017, 11:36 PM
Junior Member
walt0132 is on a distinguished road
Default GE GBS22HBPACC - Freezer Fine, Fridge Warm - *No Ice* or Blockage on Evaporator Coils
I have read posts in this thread and elsewhere in the fourm, and have tried troubleshooting a few things already.
(I got continuity on the thermodisc and defrost heating element. I check resistance on the heating coil thermister and got an expected reading. I had encountered these problems before and replaced a thermister and that fixed it).
The difference between the posts I've found here (and my last problem) was the coils were freezing over and blocked.
In my current situation that is not the case. There is no blockage on the evaporator coils. Also the fan is running fine.
I suspect the fridge / fresh food themistor could be bad and causing the problem. Also I suspect the damper assembly between the freezer and fridge.
I don't know how to test to verify these. Can anyone offer suggestions? The damper cover didn't seem like it wanted to come off, and I didn't want to pry too hard and break it.
Should I just order new thermisters and replace the fridge one (or all 3)? Or should I test them and test the damper? Can anyone help with this?
Thanks!
-Tim
  #2002 (permalink)
Old 06-05-2017, 10:36 PM
Junior Member
McGear10 is on a distinguished road
Unhappy
I experience the same thing with my Kelvinator fridge.
  #2003 (permalink)
Old 06-15-2017, 09:21 AM
Junior Member
Murphy3143 is on a distinguished road
Default Warm Fridge
The sticky here seems to be leading me in the right direction. After defrosting the coil the compressor on the refrigerator is running all the time. Both the freezer and fridge are cold now. Would either a defective defrost thermostat, heating coil or control timer on a Maytag model MBF2254HEQ cause the unit to run like this?
  #2004 (permalink)
Old 06-15-2017, 07:12 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Before ordering any parts you may want to check for continuity the defrost heater and the defrost thermostat. If any of them defective (no continuity), the part would need to be replaced.
If they both are in good condition, the electronic control board (#5 on the diagram) would need to be replaced.
The defrost heater Part number: AP6010293
The defrost thermostat Part number: AP6010356
The control board Part number: AP6022400
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #2005 (permalink)
Old 06-17-2017, 11:54 AM
Junior Member
BrownsFan42 is on a distinguished road
Default Installed New Def Heater...Now It's Worse
Kenmore Side-By-Side; Model # 363.9542683.
Refrigerator was warm and freezer was still cold. I removed the freezer back panel and saw the evap coil was encased in ice. No air flow. I melted the ice with a hair dryer, and for a few days the refrigerator was working at 36+/- degrees in the fridge; freezer < 0 degrees F.
Evap coils froze over again, and I bought/installed a new defrost assembly with heating elements and thermostat (part number WR 51X442...it was the right one). Tested the old one and it was bad. The new one appears to be working fine...elements lit up and it was sizzling when compresser and fans were off.
It's been almost a day, and the fridge temp is 50 F. Is this a "bad part" problem? Replacing the def system was abnormally easy and I didn't hit/loosen anything up.
Thanks in advance.
  #2006 (permalink)
Junior Member
Duplicate post.
  #2007 (permalink)
Old 06-19-2017, 06:04 AM
Junior Member
Default
Thanks in advance.
Crisis averted. Seems the real problem was I didn't give the fridge enough time to cool off. It's been over 90 degrees with high humidity here, and with all the opening/closing of fridge and freezer doors, that probably caused the slow cooling. The new part and fridge/freezer are working as designed (knock on wood).
Before I figured it out, I was concerned that both the heating elements AND the compressor were running at the same time. After watching both, i saw that was not the case.
  #2008 (permalink)
Old 06-22-2017, 02:37 AM
Junior Member
erica33 is on a distinguished road
Default
Hello. I cant locate the defrost timer in the GF6NFEXRQ00 whirlpool diagrams can you please help me locate it. We've replaced defrost thermostat and defrost heater but my freezer is still not defrosting at all.
  #2009 (permalink)
Old 06-22-2017, 12:09 PM
Junior Member
Default
"Hello. I cant locate the defrost timer in the GF6NFEXRQ00 whirlpool diagrams can you please help me locate it. We've replaced defrost thermostat and defrost heater but my freezer is still not defrosting at all."
I googled ge refrigerator GF6NFEXRQ00 defrost timer, and there are some links that may point you in the right direction. (whirlpool refrigerator gf6nfexrq00 gave less specific info)
  #2010 (permalink)
Old 06-22-2017, 03:05 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hello, Erica.
There is no defrost timer in this refrigerator. The defrost cycle, as well as all other main cycles, operated by the main control board. This control board is located in the compressor compartment (#18 on the diagram).
The electronic control board Part number: AP6015557
This part is on special order. You can find the ETA via the live chat.
Here are the diagrams for Model GF6NFEXRQ00
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Freezer is fine; refrigerator warm LaDonna357 Refrigerator & Freezer Repair 16 06-28-2013 02:56 PM
freezer fine refrigerator too warm cibao67 Refrigerator & Freezer Repair 5 07-10-2012 06:42 PM
Freezer is fine, refrigerator is too warm amnhac81 Refrigerator & Freezer Repair 0 07-10-2009 02:48 PM
Freezer is fine, refrigerator is too warm. allemich Refrigerator & Freezer Repair 3 04-20-2009 07:08 PM
Freezer is fine, refrigerator is too warm. silvia28 Refrigerator & Freezer Repair 0 08-05-2008 10:16 AM
