Discuss
Freezer is fine, refrigerator is too warm.
 in
Refrigerator & Freezer Repair
I hope this isn't showing twice but I didn't see my reply when I came back to this
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer is fine, refrigerator is too warm.
  #11 (permalink)
Old 01-15-2008, 01:47 PM
karen54 karen54 is offline
Junior Member
karen54 is on a distinguished road
Default
I hope this isn't showing twice but I didn't see my reply when I came back to this thread. It's a Kenmore model # 59679142990
  #12 (permalink)
Old 01-15-2008, 02:05 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
What was the original problem with your fridge?
__________________
  #13 (permalink)
Old 01-15-2008, 02:32 PM
Junior Member
Default
The original problem was that the refrigerator section was not getting cool.
Freezer section was fine. We replaced the defrost timer, hoping to solve the problem. But the cooled air still isn't blowing through air vents in frig section, in fact just about no air, cooled or otherwise, comes out of the air vent in fridge section unless freezer air vent is covered or freezer door is opened.
  #14 (permalink)
Old 01-15-2008, 03:34 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Did you see frost on the back panel in the freezer?
If you did, then the problem is a faulty defrost system. Go to the first post for the troubleshooting instructions.
If there is no frost, then most likely the problem is a bad damper control.
- The part number for the damper control is AP100860
__________________
  #15 (permalink)
Old 01-15-2008, 03:44 PM
Junior Member
Default
Thank you very much. That's what my husband thought it might be but since he doesn't have an owners manual since it's actually my daughters fridg which came with her house, he wasn't sure. Appreciate all your help. Let you know how it turns out. Thanks again.
  #16 (permalink)
Old 01-15-2008, 05:25 PM
abbie abbie is offline
Senior Expert
APP Volunteer
abbie is on a distinguished road
Default
The evaporator fan DRAWS warm air from the return vents at the top of the fridge section through the evaporator coils from the bottom section of the fridge[warm air rising]. Then the air is cooled going through the evaporator and then blown down to the bottom section through the cold air vent[cold air sinks] this is how the air cycles in a refrigerator.
__________________
  #17 (permalink)
Old 01-15-2008, 05:37 PM
Senior Expert
APP Volunteer
Default
Was the fan ever changed?If so maybe the fan is turning in the wrong direction or the blade was broken and replaced with the wrong one.[different type fins]..
__________________
  #18 (permalink)
Old 01-19-2008, 01:44 AM
redmanf1 redmanf1 is offline
Junior Member
redmanf1 is on a distinguished road
Default
I have a Maytag refrigerator model MSD2756DEW and it is about 5 years old. It is not cooling very well on the frig side but cold on the freezer side. I looked and it is froze (ice) on the back wall. I looked for the screw to trip the defrost cycle but ended up turning the screw on the temp control assy. I tried to turn it back about where I thought it was. Is there a way to trip the defrost cycle?
Also if I check the defrost wire and it seems fine would a safe bet be the adaptive defrost part # 13?
Model MSD2756DEW
Thanks for any help
Nelson
  #19 (permalink)
Old 01-19-2008, 02:47 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Nelson,
A faulty adaptive defrost control is one of the most common problem with all Maytag refrigerators.
In your situation, the first thing I would do is replace the adaptive defrost control. Also you have to defrost whatever already has been built up. Just unplug the fridge for at least 12 hours with the freezer door kept open. Otherwise it will take a few days to automatically defrost it.
- The part number for the adaptive defrost control is AP3160614
__________________
  #20 (permalink)
Old 03-21-2008, 11:22 AM
Thanster Thanster is offline
Junior Member
Thanster is on a distinguished road
Thumbs up
Thanks Gene for making this wonderful guide. Last week my GE profile fringe had this exact problem. I followed the troubleshooting steps and sure enough I found out that my defrost heater had burned out. I ordered the replacement part and it arrived overnight even using the cheap shipping because the part was shipped from Pennsylvania and I live close by in DC. I replaced the part that same evening and now the problem is fixed! Everyone in the house is impressed with my skillz!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Refrigerator & Freezer warm GaryS Refrigerator & Freezer Repair 1 11-14-2007 12:34 PM
Warm Refrigerator and Freezer chuckmielke Refrigerator & Freezer Repair 0 11-10-2007 12:36 PM
Freezer works fine but refrigerator does not hold temperature mikel500 Refrigerator & Freezer Repair 0 10-16-2007 06:57 AM
freezer fine, refrigerator compartment not michael dykstra Refrigerator & Freezer Repair 0 08-20-2007 11:23 AM
freezer fine, refrigerator not cold fargnoli Refrigerator & Freezer Repair 0 08-08-2007 10:24 PM
