Discuss
Freezer is fine, refrigerator is too warm.
 in
Refrigerator & Freezer Repair
Hi Deb, The instructions are attached to the post. Gene.
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer is fine, refrigerator is too warm.
  #1861 (permalink)
Old 04-18-2013, 07:35 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Deb,
File Type: doc Bottom mount - PC control board removal.doc (77.0 KB, 5 views)
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #1862 (permalink)
Old 04-20-2013, 08:47 PM
Junior Member
Troy36house is on a distinguished road
Default Kenmore Refrigerator Sometimes Not Cold Enough
I have a Kenmore refrigerator/freezer (model 36350232000) that worked fine until recently. The freezer is working fine but sometimes the refrigerator is not as cold as it should be. It does not get to the point where food goes bad. Sometimes it is fine and other times not. This is occurring during winter/spring months, so it is not related to heat in the house, say during summer months. I have cleaned the coils under the unit which seemed to help some, but not completely.
How can it be determined what component may be faulty between the damper or some electronic control so that the correct part is ordered?
  #1863 (permalink)
Old 04-22-2013, 04:28 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hello,
There are no electronic parts in your refrigerator. Remove the rear panel in the freezer and check how the evaporator coils are covered with frost. Post the results.
__________________
  #1864 (permalink)
Old 04-27-2013, 08:48 PM
Junior Member
Default
I was able to move the rear panel inside the freezer far enough to see the evaporator coils and they do have frost on them. I couldn't remove the panel completely due to the ice maker being in the way.
What is my next step in resolving this issue?
  #1865 (permalink)
Old 04-29-2013, 07:20 AM
Junior Member
salewis1 is on a distinguished road
Default Replaced Heater but there's still frost
Hi Gene,
Thank you so much for this thread. I'm a single mom so it's nice to have expert advice when I find myself doing my own home repairs. My side by side GE Profile fridge: GE Model tfx22crda was having the same problem as what was described in your thread. I found that I had a bad defrost heater, which I replaced. I didn't go any further in investigating the thermostat, because it was clearly burnt out.
I noticed frost build up on the back of my freezer about a week ago, so now I'm wondering if it's the defrost thermostat? Everything seems to be operating fine, with the exception of all that darn frost!!! I scraped it off last night, and it was back again this morning. Could it be that they both were possibly bad and that I need to replace the thermostat as well?
Please help:-)
  #1866 (permalink)
Old 04-29-2013, 11:31 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by Troy36house View Post
...they do have frost on them...
How much frost is there? Are the coils completely blocked?
It's better to remove the ice maker.
__________________
  #1867 (permalink)
Old 04-29-2013, 11:40 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by salewis1 View Post
Hi Gene,
Please help:-)
What is the part number of the heater you installed?
If it was a double glass tube kit, have you installed both heating elements?
The defrost thermostat has to be checked for continuity while it's ice cold.
__________________
  #1868 (permalink)
Old 04-29-2013, 11:56 AM
Junior Member
Default
Hi Gene,
the part number was AP4355467. It had two heating elements, but there was only one heating element originally. So I just took one of the heating elements from the part number referenced and replaced it. Should I have replaced the one heating element with the two that came in the part??
  #1869 (permalink)
Old 04-29-2013, 12:33 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Yes, both heating elements must be installed. They should be connected in series. The installation instruction is included in the kit and have to follow it for proper installation.
Very likely the one you already installed is already damaged because of executive power for one heater. Check it for continuity. If it is damaged then you have to order another kit and install both of heaters according to the instruction.
__________________
  #1870 (permalink)
Old 04-29-2013, 12:41 PM
Junior Member
Default
Shoot.. Hopefully, it's still good. If not, then I'll order another one. It's still a lot cheaper than hiring someone. Thanks!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Freezer is fine; refrigerator warm LaDonna357 Refrigerator & Freezer Repair 16 06-28-2013 02:56 PM
freezer fine refrigerator too warm cibao67 Refrigerator & Freezer Repair 5 07-10-2012 06:42 PM
Freezer is fine, refrigerator is too warm amnhac81 Refrigerator & Freezer Repair 0 07-10-2009 02:48 PM
Freezer is fine, refrigerator is too warm. allemich Refrigerator & Freezer Repair 3 04-20-2009 07:08 PM
Freezer is fine, refrigerator is too warm. silvia28 Refrigerator & Freezer Repair 0 08-05-2008 10:16 AM
