Discuss
Freezer is fine, refrigerator is too warm.
 in
Refrigerator & Freezer Repair
Originally Posted by Philips ...Are there two thermostats, one for the refrigerator section and one for the freezer section, with
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer is fine, refrigerator is too warm.
  #1781 (permalink)
Old 10-05-2012, 05:03 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by Philips View Post
...Are there two thermostats, one for the refrigerator section and one for the freezer section, with the capillary wires routed to different places?...
You probably did not read carefully my post on the previous post. There is only one thermostat and it reads temperature in the refrigerator. By moving the second knob you adjusting the air flow from the freezer into the refrigerator, mechanically open and close the window between these two sections.
Ads By Google
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #1782 (permalink)
Old 10-05-2012, 05:11 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Looking at the picture I don't see where the second tube is installed. It should be mounted somewhere in a middle of the coils.
The coils are looking pretty shine with no any frost on them. Is this correct?
__________________
  #1783 (permalink)
Old 10-06-2012, 09:34 AM
Junior Member
ment2b is on a distinguished road
Default
Gene, I'm assuming you're responding to my pics. If so, there are 2 tubes, but they are both in one bracket (WR51X10101) and mount the same as the single tube. Not in 2 locations.
There's no frost in the 2nd pic because the freezer is defrosted and not yet plugged in.
Shine is from the camera flash and the little "tinsel" stuff wrapped around the tubes.
  #1784 (permalink)
Old 10-08-2012, 03:12 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by ment2b View Post
...There's no frost in the 2nd pic because the freezer is defrosted and not yet plugged in...
It was a few days since our last conversation. How is the refrigerator working now?
__________________
  #1785 (permalink)
Old 10-08-2012, 04:16 PM
Junior Member
Default
It was a few days since out last conversation. How is the refrigerator working now?
100% working fine. Temps are spot on.
  #1786 (permalink)
Old 10-08-2012, 04:39 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Good news. Hope it will last a few more years.
__________________
  #1787 (permalink)
Old 10-09-2012, 06:45 AM
Junior Member
rockjeep44 is on a distinguished road
Default
Quote:
Originally Posted by rockjeep44 View Post
Samsung "POS" RS265LBBP refrigerator here. POS is not part of the model number, that's my addition based on performance Anyways, freezer is good as gold, refrigerator sits around 56-60 degrees with no air movement that I can see.
Anyways, thanks to all the research here I did a self diagnosis and it returned section 4 (Fan motor system abnormality in R compartment) and section 7 (Abnormality in defrosting system for R compartment). Should I start with the cheapest/easiest fix by ordering the fan motor item #AP4136569, replacing it, and seeing if that cures the section 7 error as well? If it doesn't then I guess move on to plan B which is troubleshooting the section 7 defrost error? Thanks for the advice
Oh, and while I'm here does anyone have the service manual for this fridge? I found one for another model online but it has some differences.
I don't see why not.
Unfortunately I did not find the service manual for this model.
Thanks Gene. I placed the order and will report back with my results.
One month update. Replacing the fan motor seems to have fixed the issue. Refrigerator and freezer are running like a champ. Thanks for the help here on the forum
  #1788 (permalink)
Old 10-09-2012, 01:08 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome. We're glad it's up and running.
Thank you for the feed back.
__________________
  #1789 (permalink)
Old 10-15-2012, 01:02 PM
Junior Member
John A PA is on a distinguished road
Default
Hi Gene. I didn't post my problem, but used some of your excellent work in this and other threads on the Freezer is fine, Refrigerator is warm issue. My box is a GE TBX18JASWH, bought in Jan 1994.
Being who I am, I replaced the defrost thermostat first based on it's easy access.
No solution, so I proceeded to pull the back out of the freezer. Once I melted all the ice and frost off the coil, my problem became obvious. The defrost heater had failed, and when the coating burst, it burnt a small slot in the metal bracket that holds it in place. (circuit breakers are a blessing)
I was shocked at the damage when it failed, and had no hesitation in adding the fusible links to the ends of the replacement heater. If I can get it right, I'll add some pics of the old heater for those who never saw one that failed.
Thanks, again, for the excellent resource, and service you provide.
  #1790 (permalink)
Old 10-15-2012, 01:52 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
John,
Just wanted to thank you for sharing your diagnosis and repair with us. It's not often we see such damage done by a shorted defrost heater, so your post was very illuminating and instructive.
Thanks again and good luck with your refrigerator.
P.S. Make sure you'll seal all electrical connections for the new heater and fusible links to protect them from moister.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
freezer fine refrigerator too warm cibao67 Refrigerator & Freezer Repair 5 07-10-2012 06:42 PM
Freezer is fine; refrigerator warm LaDonna357 Refrigerator & Freezer Repair 15 03-28-2012 04:55 AM
Freezer is fine, refrigerator is too warm amnhac81 Refrigerator & Freezer Repair 0 07-10-2009 02:48 PM
Freezer is fine, refrigerator is too warm. allemich Refrigerator & Freezer Repair 3 04-20-2009 07:08 PM
Freezer is fine, refrigerator is too warm. silvia28 Refrigerator & Freezer Repair 0 08-05-2008 10:16 AM
