Discuss
Freezer is fine, refrigerator is too warm.
 in
Refrigerator & Freezer Repair
Is your refrigerator less than a year old? If this is correct, don't do anything and call Frigidaire for service.
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer is fine, refrigerator is too warm.
  #1771 (permalink)
Old 09-22-2012, 01:16 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
If this is correct, don't do anything and call Frigidaire for service. Otherwise it can void the warranty.
Ads By Google
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #1772 (permalink)
Old 09-24-2012, 03:16 PM
Junior Member
ment2b is on a distinguished road
Default
Quote:
Originally Posted by ment2b View Post
GE model GSS22KGPCWW. ~9 years old.
snipped
Gene, I'm picking up the replacement defrost heater tomorrow (fortunately I bought a lifetime warranty, when I replaced the heater 5 years ago)
There is now a 2 tube heater available for my model. In your experience, is this a better option vs the single tube ? I've now replaced the heater twice in 9 years.
  #1773 (permalink)
Old 09-24-2012, 03:27 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Yes, the double tube kit is much better. It provides better defrost for shorter time.
__________________
  #1774 (permalink)
Old 09-24-2012, 03:37 PM
Junior Member
Default
Quote:
Thanks again Gene ! Hopefully the shorter time translates to Longer Life.
Apparently this is a common failure part.
  #1775 (permalink)
Old 10-03-2012, 06:25 PM
Junior Member
Philips is on a distinguished road
Default
Quote:
Originally Posted by Philips View Post
I have changed the settings and will post results tomorrow. What is the exact method of blowing air through the drain line? Is the drain hose on the back the vertical plastic tube?
Sorry for the delay, but the setting change helped with the cooling of the refrigerator section, and a thermometer did show temperatures in the correct range. I tried to tweak the settings a little bit, and that seemed to get the freezer operating very cold again. The dial thermostat control does not feel right for the freezer section, it does not rotate smoothly, like the one for the refrigerator section. So I am not sure that the setting is what the dial shows. The freezer section temperature is at -15, and seems to be running constantly.
  #1776 (permalink)
Old 10-04-2012, 01:58 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
What are the current temperature settings?
-15°F for the freezer is too low. The normal temperature us about 0°F.
__________________
  #1777 (permalink)
Old 10-04-2012, 02:02 PM
Junior Member
Default
Warmest for freezer, 4 for refrigerator. It was working okay for a few days, freezer was warmer with no frost, but started acting up again. The freezer tempearture knob is not easy to operate, takes a lot of force to turn either way.
  #1778 (permalink)
Old 10-04-2012, 02:48 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
...The freezer tempearture knob is not easy to operate, takes a lot of force to turn either way...
Take it apart and check why.
__________________
  #1779 (permalink)
Old 10-04-2012, 06:51 PM
Junior Member
Default
Perhaps I should keep a replacement thermostat ready when I check? Are there two thermostats, one for the refrigerator section and one for the freezer section, with the capillary wires routed to different places? Part number comes up as Whirlpool 2198202, is that correct? Thanks for your help.
  #1780 (permalink)
Old 10-05-2012, 11:32 AM
Junior Member
Default
Hi Gene, finally getting around to post the before and after pics. The new double tube heater came with an extra length of wire, which wasn't needed for my GE SbS. The blue wire on the left was more than long enough to reach the heater, so it was an easy install.
Took about an 1 1/2 hr to empty the freezer, disassemble all, defrost w/a hair dryer, install new heater, reassemble all and restock food.
Thanks again for all your help!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
freezer fine refrigerator too warm cibao67 Refrigerator & Freezer Repair 5 07-10-2012 06:42 PM
Freezer is fine; refrigerator warm LaDonna357 Refrigerator & Freezer Repair 15 03-28-2012 04:55 AM
Freezer is fine, refrigerator is too warm amnhac81 Refrigerator & Freezer Repair 0 07-10-2009 02:48 PM
Freezer is fine, refrigerator is too warm. allemich Refrigerator & Freezer Repair 3 04-20-2009 07:08 PM
Freezer is fine, refrigerator is too warm. silvia28 Refrigerator & Freezer Repair 0 08-05-2008 10:16 AM
