| » Freezer is fine, refrigerator is too warm. |
Quote:
In regards of the problem with the drain from the freezer try to blow some air through the drain line after you defrosted it. Make sure the other end of the drain hose (on the back of the refrigerator) is clean as well. Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Quote:
__________________
OK, success in attaching the photo. Here's the evaporator coils, when panel first removed :
Did you take this picture before or after repair?
__________________
That's some bunch of frosty ! Last edited by ment2b : 09-21-2012 at 02:40 PM. Reason: spelling |
Quote:
Quote:
__________________
Quote:
2. Probably. It should come out of the refrigerator body. Gene.
__________________
Hi all,
I think I having the same problem as this thread: Frigidaire Gallery: LGUI1849LF2 Less than a year old Freezer on top, refrigerator on bottom Perviously the freezer had frost everywhere and the refrigerator was really warm. So I thought I packed the freezer too much. I put all the food out and manually defrosted the unit for a day. I put all the food back in, turned the fridge back on and everything worked fine for a few weeks. But recently frost has been building up on the back panel of the freezer again, and the ice cream is frozen solid. The refrigerator section seems ok for now though, but I think eventually I'm going to have the same problem as before. I tried trouble shooting with the instructions on the first page: Using a flat screwdriver, slowly turn the shaft in the middle of the defrost timer clock wise until it clicks to switch from the cooling cycle to the defrost cycle. But looking at the diagram, how do I access the defrost control to test the defrost cycle? Do I have to remove any covering to access it? Thanks in advance. |
| Display Modes | |
| freezer fine refrigerator too warm | cibao67 | Refrigerator & Freezer Repair | 5 | 07-10-2012 06:42 PM |
| Freezer is fine; refrigerator warm | LaDonna357 | Refrigerator & Freezer Repair | 15 | 03-28-2012 04:55 AM |
| Freezer is fine, refrigerator is too warm | amnhac81 | Refrigerator & Freezer Repair | 0 | 07-10-2009 02:48 PM |
| Freezer is fine, refrigerator is too warm. | allemich | Refrigerator & Freezer Repair | 3 | 04-20-2009 07:08 PM |
| Freezer is fine, refrigerator is too warm. | silvia28 | Refrigerator & Freezer Repair | 0 | 08-05-2008 10:16 AM |
