Discuss
Freezer is fine, refrigerator is too warm.
 in
Refrigerator & Freezer Repair
Originally Posted by lancer ...So if I can (hear the nosie) the problem is the defrost timer? It seems to
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer is fine, refrigerator is too warm.
  #161 (permalink)
Old 09-25-2008, 04:35 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Quote:
Originally Posted by lancer View Post
...So if I can (hear the nosie) the problem is the defrost timer? It seems to me it's the other way around (if I can not hear the noise then the problem is the defrost timer)...
Dan,
The defrost timer is just a switch, operated by a motor. There are two pairs of contacts, one of them provides power to the compressor and another one - to the heating circuit.
If the motor is bad, it's causing the compressor contacts to get stuck, then it will never switch to the defrost cycle. When you manually turn the shaft that means you manually switched the defrost "on", and sizzling sound proves that the defrost circuit is fine. In your case it looks like the defrost pair of contacts in the defrost timer is bad and the correction is to replace the defrost timer. Also I would recommend to check wires to the defrost timer.
- The part number for the defrost timer is AP98191
P.S. You can check the defrost timer for continuity according to the Wiring diagram.
__________________
Professional appliance repair in Los Angeles, California.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #162 (permalink)
Old 10-02-2008, 12:31 PM
mhf115 mhf115 is offline
Junior Member
mhf115 is on a distinguished road
Default Frigidaire FRT21H7ASB2
Gene,
Thanks for all the good info thus far: here is my situation.
Frigidaire Top Freezer model.
I had the ice build up on the coils in my freezer compartment. I manually defrosted everything (hairdryer) and put everything back together. Same problem arose in about 2 weeks with a warm fridge compartment. (more ice on the coils).
I am looking at the three parts (heater element, defrost timer, and thermostat). I ohm tested the heater element and got infinity (switching the probes around if that mattered).
I did not run any ohm tests on the thermostat as I am not sure where to connect the probes to (should I cut and strip the wire and then reconnect?
Here's the kicker; my defrost timer is one of the electronic ones you mentioned. I read somewhere that on my model (frigidaire FRT21H7ASB2) you need to toggle the light switch 5 times within 7 seconds and it should manually put the refrigerator into defrost mode. It does not do this and continues to run when I toggle the light switch.
The fridge does actually shut off occasionally (is this defrost mode? if so is the timer ok?) If it is defrost mode, I am looking for a glow from my heating element when the fridge is off, but there is no glow, the heating element is not turning on (obviously because of my problem).
This would lead me to believe the thermostat needs to be replaced; however, not being able to manually put my fridge into defrost mode has me concerned it might be the electronic timer. Everything else seems to point to the fact that the timer is working. If you could give me any advice as to which parts to order or further tests to run, I would greatly appreciate it.
Thanks so much.
Mark
  #163 (permalink)
Old 10-03-2008, 01:36 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by mhf115 View Post
...I ohm tested the heater element and got infinity (switching the probes around if that mattered)...
Hi Mark.
The defrost heater is bad. No doubts about it. I would recommend to replace the defrost thermostat too because the part is inexpensive and will make the repair more reliable.
- The part number for the defrost heater is AP2150162
- The part number for the defrost thermostat is AP2150133
__________________
  #164 (permalink)
Old 10-05-2008, 04:00 PM
Charlene De La O Charlene De La O is offline
Junior Member
Charlene De La O is on a distinguished road
Question Leaking Water and ice in freezer
I have a Kenmore refrigerator/freezer, model 106.70192000. It is eight years old.
My problem seems to be related to this thread. There was water in my refrigerator, so I read some posts and fixed it by clearning the drain hose from the freezer. It turned out to have a chunk of ice in the hose. There was also a ton of ice all over the bottom of the freezer, which I cleaned out, melted, and dried. I even left my refrigerator and freezer open and turned off for 72 hours to make sure that everything was melted and dry.
Now the problem has returned. A lot of ice has formed on the bottom of the freezer (under the plastic pan that I removed). It leaks into the refrigerator and forms puddles of water and sections of ice on the shelves. When they fill with water and ice, it runs to the bottom of the fridge, some more ice forms there and eventually water runs out of the bottom of the door and onto the floor.
It seems clear that whatever caused the drain to plug with ice in the first place is still a problem. So, I figure it could be the defrost system. I am starting with Greg's troubleshootings steps. I found the defrost timer; it looks just like the part number AP3110896, shown in this site's pics. But I can't locate a "shaft in the middle" that I can turn with a screwdriver. It's all encased in clear plastic and even under that I don't see any shaft to adjust.
Also, does the fact I can see the parts moving under the clear plastic an indicator that this part is working?
Thanks for any help!
Charlene
  #165 (permalink)
Old 10-06-2008, 01:08 PM
Junior Member
Default
Gene - Thank you. I will replace parts and update.
  #166 (permalink)
Old 10-06-2008, 04:04 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Charlene,
Before replacing any parts I would recommend to remove the rear cover and clean the condenser coil and all around from lint. Be sure the bottom end of the drain hose is open.
__________________
  #167 (permalink)
Old 10-06-2008, 06:23 PM
DaveR DaveR is offline
Junior Member
DaveR is on a distinguished road
Default Thank you Gene, it makes sense now
Thank you Gene, it now makes sense.
  #168 (permalink)
Old 10-18-2008, 10:43 AM
Junior Member
Default Update to problem
Gene-
I diagnosed my problem inproperly to you. My heater element read that I had a closed circuit. On my ohmeter, my bar went to the far right which I thought was infinity. I had the same reading on the new heater element.
So I have a closed circuit with my heater element that is already in the freezer. I took out the defrost thermostat and I checked for continuity. It was closed when cold and open when warm. I ended up replacing that piece anyway.
So where I am now is I have my new defrost thermostat in (the old one should have been good). The old heater element in (also tests good "i believe").
My options now are to replace the heater element or the electric defrost timer. What is your opinion on where to proceed? If you recall, I could not manually put my fridge into defrost mode by toggling the light switch. The fridge was also shutting off periodically. Let me know how I should proceed.
Thank you.
Mark
  #169 (permalink)
Old 10-19-2008, 10:19 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Mark,
If there is nothing wrong with the defrost heater and the defrost thermostat then the problem is a bad adaptive defrost control. No doubts about it.
- The part number for the adaptive defrost control is AP3211551
__________________
  #170 (permalink)
Old 10-20-2008, 07:57 AM
Junior Member
Default
Gene,
Thank you - I ordered that part and last time the shipping was very fast. I will update once installed. I know this is not your department, but should I be able to return that defrost heater element that I did not install?
Thanks again,
Mark
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Refrigerator & Freezer warm GaryS Refrigerator & Freezer Repair 1 11-14-2007 12:34 PM
Warm Refrigerator and Freezer chuckmielke Refrigerator & Freezer Repair 0 11-10-2007 12:36 PM
Freezer works fine but refrigerator does not hold temperature mikel500 Refrigerator & Freezer Repair 0 10-16-2007 06:57 AM
freezer fine, refrigerator compartment not michael dykstra Refrigerator & Freezer Repair 0 08-20-2007 11:23 AM
freezer fine, refrigerator not cold fargnoli Refrigerator & Freezer Repair 0 08-08-2007 10:24 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
