Discuss
Freezer is fine, refrigerator is too warm.
 in
Refrigerator & Freezer Repair
Mitch, The normal reading should be close to 0 Ohms while it's cold. Gene.
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer is fine, refrigerator is too warm.
  #1651 (permalink)
Old 07-10-2012, 04:53 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Mitch,
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #1652 (permalink)
Old 07-11-2012, 10:53 AM
Junior Member
Hummer is on a distinguished road
Default
Hello,
Model Number: GE TBX18KKB
Symptoms:
  • Freezer was working fine, but fridge got up to 70 degrees. Yikes!
  • Had a guy out and he tested/replaced the defrost things and manually defrosted the coils.
  • Fridge got down the around 50 degrees and occasionally dips to 40, but runs constantly.
  • Doesn't seem to be moving much air into the fridge compartment. Is this a forced air system or is the density gradient the only thing making the air move to the fridge?
  • Freezer is still super cold and keeping my ice cream supply frozen.
  #1653 (permalink)
Old 07-12-2012, 01:39 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
How did you set the temperature controls? If the freezer temperature set on the coldest or "E", move it close to cold or "A" point. Wait about 24 hours and check the temperature in both compartments.
__________________
  #1654 (permalink)
Old 07-16-2012, 06:29 AM
Junior Member
Brannan84 is on a distinguished road
Default Hotpoint fresh food section not keeping cool
I searched but I couldn't find someone with a hotpoint fridge with the same issue and I am limited on time so I only read about 10 pages of this forum (and I'm certain I came to the right place for expert help).
Last night I noticed my fridge section wasn't as cool as it should so I opened the freezer side and noticed there was a glowing coil behind the freezer wall and there was a sizzling noise. I waited for a few minutes and unplugged the fridge since I was worried about the glowing coil since I didn't know at the time it was just the defrost and I was worried. I plugged the fridge up about 10 minutes later and waited for the fan to start running again which it eventually did. And the fridge side still wasn't cooling at all.
I checked and there was no blockages on the top part of the fridge where the cold air comes in. And I only found one small hole at the bottom of the fridge going to the freezer side and that wasn't blocked up either. I noticed after I plugged the fridge up that a little bit of frost was on the back wall of the freezer side. And about the same was on the wall this morning. I think I unplugged and the fridge during the defrost cycle and it hasn't been able to defrost all the way since them (correct me if I'm wrong).
The freezer fan used to make a terrible pulsing sound where it sounded like the fans speed would go up and down making it sound like the fan was struggling to spin. It doesn't do this all of the time so I didn't really worry about it. And when I plugged the fridge back in last night, and when I checked it this morning. The fan sounded normal and was blowing air on the freezer side.
From the looks of the diagrams for my Hotpoint fridge (model: HSS25GFTA WW) I don't think there is a fan dedicated to put air in the fridge side. I only see a little door opening in the "fresh food" side. My next course of action when I get home tonight is to pull the back panel off the freezer side and check things out.
So to recap, I unplugged my fridge when the defrost heater was on (which cut on by itself, so maybe not a faulty defrost timer). This was after I noticed the fridge side wasn't cooling. Fan is blowing cold air on freezer side but no air flow on fridge side.
Thanks so much for your expert advice!!!
EDIT: Maybe it's the temperature thermostat in the section b/t fridge and freezer sides. http://www.appliancepartspros.com/Ap...ap3185407.aspx
Item number: AP3185407
I turned the fridge temp setting down all the way but it still didn't cut on. Would the fridge side not cut on at all if the thermostat is not reading anything?
  #1655 (permalink)
Old 07-16-2012, 11:17 AM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Open the freezer back panel and if needed defrost the coils. Check for 12 hrs if the temperature will be OK. When you'll open the cover see if the coils covered evenly with frost.
Is the freezer temperature OK? Ice cream frozen?
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #1656 (permalink)
Old 07-16-2012, 12:38 PM
Junior Member
Default
Yep, temp in the freezer seems fine. Everything is still frozen solid. The more I read the more I think it's the evaporator fan. I stopped by a local appliance repair shop during lunch today and the guy said the same thing. Or maybe it's the fridge side sensor going bad.
Also, something else has been puzzling me. The guy at the shop said the most likely cause is the evap fan, and reading through this thread also leads me to believe that. But it doesn't make sense to me since the fan is still running. Only sometimes it makes a noise, but the fridge side stays at the right temp. How else could the air be circulated to the fridge side since there are no other fans (besides condenser fan) in the fridge. There is a little flap at the top between fridge/freezer sides, and I push that open and close the freezer but still no air comes out the fridge side. I open the freezer side and it seems to be still open.
My plans tonight are to check out the evap fan and see if there are any issues with it. And as for the frost build up you mentioned. I never had any kind of build up before so I'm really hoping my defrost timer/coil are in working order. There was only a slight build up when I first unplugged the fridge. Which is probably why I saw the defrost coil glowing.
The only things that I could see being the issue are (if there isn't frost build up that I haven't seen):
-fridge sensor not letting that flap stay open for a long enough time.
-evap fan not working properly
  #1657 (permalink)
Old 07-16-2012, 04:21 PM
Expert
Default
Hi.
Open the freezer door and check if any air will come through the damper control. If it will - then the air flow is restricted at the evaporator.
Post the results.
Simon.
__________________
  #1658 (permalink)
Old 07-17-2012, 01:41 AM
Junior Member
jason71 is on a distinguished road
Default
you know I had that problem with my samsung it was the fan. I had a Ge before that and I had the tech out and he said it was a temperature gauge fault. It still was not fixed. I finally had enough and worked on it. It was the door on the fridge side it kept lowering to the floor and the light contact switch was not tuerning off so the light was alwasy on and it was casuing all the issues.
  #1659 (permalink)
Old 07-17-2012, 06:16 AM
Junior Member
Default
I think you were right Simon. I finally took the back panel off last night and the coils had a decent amount of ice. Not like a complete block of ice or anything, but more than I would have expected towards the top. I had some food I wanted to save so I took a hair dryer to the coils to save some time defrosting. When I made my first post I thought the 1/2 inch hole at the very bottom was the air return for the fridge side. But once I cleared some ice I noticed another larger hole that was behind the main panel on the freezer side. I never thought about one being there but it makes sense since the panel allows the fan to suck air from the fridge side to recirculate it back at the top. I cleared the ice and the fridge temp dropped right away. I set the temp to the coldest it would go last night and stuck the temperature probe from a meat thermometer at the bottom of the fridge side and this morning it was reading 32* and that's where the thermometer stops. (Not a high quality thermometer so it might not be exact)
I don't know if I have had the fridge running long enough to hear if the fan was making the pulsing noise anymore though. Do you think that the restricted air flow could have made the fan do that?
So now my new plan is to get a replacement fan to have on hand. I also think there might be something wrong with the defrost cycle since there was enough ice build up to block the evap return. Do you think I should go ahead and get the more efficient 9" double heater coil and replace the single coil I have? Or do you think it could be an issue with defrost limiter thermostat(GE WR50X10068 Defrost Limiter Thermostat, AP3884317 | AppliancePartsPros.com), or one of the 2 sensors on the freezer side?
Thanks for the suggestions and all the help!!!
  #1660 (permalink)
Old 07-17-2012, 12:37 PM
Junior Member
sacrivercats is on a distinguished road
Default
Hello,
Just like many others in this thread, my freezer is working fine but the fridge is warm. It seems that the problems stem from the coils so I've attached a couple pictures of the coils. I have a GE and the model number is tfx26kpdaww. Please let me know if you need any additional information from and any guidance/help would be greatly appreciated it.
Thank you,
Norman
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Freezer is fine; refrigerator warm LaDonna357 Refrigerator & Freezer Repair 16 06-28-2013 02:56 PM
freezer fine refrigerator too warm cibao67 Refrigerator & Freezer Repair 5 07-10-2012 06:42 PM
Freezer is fine, refrigerator is too warm amnhac81 Refrigerator & Freezer Repair 0 07-10-2009 02:48 PM
Freezer is fine, refrigerator is too warm. allemich Refrigerator & Freezer Repair 3 04-20-2009 07:08 PM
Freezer is fine, refrigerator is too warm. silvia28 Refrigerator & Freezer Repair 0 08-05-2008 10:16 AM
