Discuss
Freezer is fine, refrigerator is too warm.
 in
Refrigerator & Freezer Repair
Sorry for not posting it, it is FRS26R4CW0 Just got home and fridge is 20 degrees
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer is fine, refrigerator is too warm.
  #1511 (permalink)
Old 05-04-2012, 04:55 PM
Junior Member
Brac is on a distinguished road
Default
  #1512 (permalink)
Old 05-04-2012, 06:18 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The problem can be a bad cold control, a bad damper control, a bad adaptive defrost control of any combinations of them. Also Frigidaire does not sell the damper control separate. It comes as a part of the control box kit which includes all control parts. It cost a bit more than a single part from the above list but it will make the repair much more reliable.
- The control box kit Part number: 5304482075
Here are the breakdown diagrams and Replacement parts for Frigidaire FRS26R4CW0 Frigidaire/refrigerator | AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #1513 (permalink)
Old 05-05-2012, 02:17 PM
Junior Member
Default
Gene, Somehow when I got this fridge I ended up with a spare Ice maker an Electrolux 240352409. Could I send this as a partial trade? It has never been opened.
  #1514 (permalink)
Old 05-06-2012, 08:58 AM
Junior Member
Default A good smack gets it going.
So, I have found that when it starts to get around 40 degrees if I smack the control box, it starts blowing cold air. Any chance of a bad connection or something on the damper?
  #1515 (permalink)
Old 05-07-2012, 01:30 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Such chance is very small.
__________________
  #1516 (permalink)
Old 05-11-2012, 10:09 AM
Junior Member
Default
Part arrived and was installed, fairly simple job. I have a thermometer in the fridge and I'm on "1" for the fresh food setting and only at 30 degrees. I have the freezer side on "3" and temp in there is 12 below. I'm a bit concerned, as I don't have much more room for adjustment.
Brac
  #1517 (permalink)
Old 05-14-2012, 02:42 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
It is too cold in both compartments. Try to set the freezer control on "2" and check the temperatures after 24 hours. Set it on "1" if it's still too cold.
P.S. Did you load the fridge with food?
__________________
  #1518 (permalink)
Old 05-15-2012, 06:05 AM
Junior Member
Default
I really don't understand. Before I changed the part when the fridge would get too hot or too cold, I would reach in a give the control box a lite smack. As soon as I smacked it I would hear the dampner motor turn on and it would either stop blowing cold air or start blowing cold air which ever was needed.. The control box that was shipped to me acts the exact same way. I got up this morning and it the fridge was 27 degrees, I gave the control box a light tap, and it stopped blowing cold air.
Please advise.
Brac
  #1519 (permalink)
Old 05-15-2012, 09:56 AM
Junior Member
GeneL56 is on a distinguished road
Default
Kenmore 106.74254401: Freezer on top, frige on bottom. The freezer sometimes does not keep ice cream and frozen juices hard, but it does produce ice and keeps everything else frozen. the frige has problems staying above 44 degrees even though i have the thermostats set at maximum. Coils under the fridge are clean. I took off the back panel of the freezer and no frost/ice is present. I located the damper door in the frige portion and it was shut tight so i manually pried it up a little and stuck a popsickle stick in the opening to keep it open a bit. that seems to help the cooling in the frige somewhat--I do feel air flow coming out of the shute. And the popsickle stick remains in place so i don't think the damper door is opening/closing on its own. The fan in the freezer compartment does run and air comes out of the tower. Question: do you think my problem is just with the damper? Just replace the damper control or ?? thanks !
  #1520 (permalink)
Old 05-15-2012, 10:27 AM
Junior Member
Default
I didn't intend to make this my "blog" BUT: so after I posted the last question, I put the back freezer panel back on and while closely observing the damper door, i turned the freezer thermostat down to "1", and the damper door opened! As I turned the freezer therm "up", the damper door began to close. So I am leaving my freezer therm in a lower setting to see if that solves my problem with fridge cooling. If fridge cooling is able to maintain at proper temps, my remaining question will be: why has my freezer not been able to consistently maintain sufficient coldness to keep ice cream/frozen juices hard? My ice cream and frozen juices would turn to "soup" consistency and then refreeze somewhat. Continued thanks !
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Freezer is fine; refrigerator warm LaDonna357 Refrigerator & Freezer Repair 16 06-28-2013 02:56 PM
freezer fine refrigerator too warm cibao67 Refrigerator & Freezer Repair 5 07-10-2012 06:42 PM
Freezer is fine, refrigerator is too warm amnhac81 Refrigerator & Freezer Repair 0 07-10-2009 02:48 PM
Freezer is fine, refrigerator is too warm. allemich Refrigerator & Freezer Repair 3 04-20-2009 07:08 PM
Freezer is fine, refrigerator is too warm. silvia28 Refrigerator & Freezer Repair 0 08-05-2008 10:16 AM
