| » Freezer is fine, refrigerator is too warm. |
Denis,
What is the temperature in the freezer? What was the ambient temperature at the time it happened? Quote:
Gene. P.S. Also, one of possibilities is an intermittent problem with the evaporator fan motor. Ads By Google
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Quote:
Your post here mentions the instructions for fridges that do not have electronics; I have an Amana ABB222ZDEW bottom freezer with the fridge warming and the freezer compartment so cold it is icing inside. We seldom open the freezer as it is a second unit. So far I've several times had to empty the unit to thaw it out when the fridge warms to near 54 degrees. In fact, I am writing this today while waiting for the unit to defrost again. Each time I have extensive icing in the freezer compartment on the ceiling and inside the upper door. How do I check the various components for a defrost cycle failure? Do I read correctly that the timer is built into the control board? I have searched the model number and found a diagram locating the thermistor and the evaporator heater. It also shows a thermostat without any location or number so I 'm lost where to find this part. Do I test each of the other parts to eliminate them to see if the timer control board is the issue? I am not certain what order to test and where all the relavant parts are located for this model. After several times it seems pretty certain the defrost cycle is my problem. Tom H |
Tom,
You can check for continuity the defrost heater (#15 on the diagram) and the defrost heater which is located on top of the evaporator, but most likely the problem is a bad control board (#5 on the diagram) which controls defrost cycle among other functions. - The control board Part number: AP4366538 - The defrost thermostat Part number: AP4009073 - The defrost heater Part number: AP4076588 Here are the breakdown diagrams and Replacement parts for AMANA ABB222ZDEW REF - BOTTOM MOUNTS | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com Last edited by Gene : 10-09-2011 at 09:11 PM. |
Check for 12-15 VDC to the evaporator fan motor. If the reading is correct, replace the motor.
- The evaporator fan motor Part number: AP4502449 Gene.
__________________
I have a Kitchen Aid KBRS36FKX00 that is about ten years old.
When the fridge was under warranty, the evaporator motor and part of the wiring harness was changed as a known problem. I am now having the same problem, the unit runs constantly and the freezer works fine but the refrigerator section temperature has been rising. I found on this forum a post by Gene where he had a link to a service manual for a side by side model. I was wondering if the procedures are the same for the bottom freezer units. Read more: Refrigerator not cooling properly http://forum.appliancepartspros.com |
The first thing I would do is remove the top grille and clean the condenser coils (#16 on the diagram). Make sure the fan next to the compressor is running.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KBRS36FKX00 BUILT-IN REFRIGERATOR | AppliancePartsPros.com Gene.
__________________
Gene,
I cleaned the coils. Now the refrigerator does not cool at all. I replaced the evaporator fan as it flunked the diagnostic test. Now the compressor flunks the test as well as the defroster heater and bimetal. I was wondering if you had a service manual for this model, I am using one for a side by side now. |
| Display Modes | |
| freezer fine refrigerator too warm | cibao67 | Refrigerator & Freezer Repair | 5 | 07-10-2012 06:42 PM |
| Freezer is fine; refrigerator warm | LaDonna357 | Refrigerator & Freezer Repair | 15 | 03-28-2012 04:55 AM |
| Freezer is fine, refrigerator is too warm | amnhac81 | Refrigerator & Freezer Repair | 0 | 07-10-2009 02:48 PM |
| Freezer is fine, refrigerator is too warm. | allemich | Refrigerator & Freezer Repair | 3 | 04-20-2009 07:08 PM |
| Freezer is fine, refrigerator is too warm. | silvia28 | Refrigerator & Freezer Repair | 0 | 08-05-2008 10:16 AM |
