| » Freezer is fine, refrigerator is too warm. |
Check the defrost thermostat (#3 on the diagram) for continuity.
- The defrost thermostat Part number: AP4136048 Gene. Ads By Google
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Hi, I have a Frigidaire FRT22TSEB5 that has had the back freezer panel frost over with the refrigerator becoming warm 3 times in the past 6 months. After reading through this thread I first checked the defrost timer and didn't notice any change after the 10-15 minutes. After removing the back panel I discovered heavy build up of ice/frost. Checking the continuity of the defrost heater I got a reading of 26. Is it even necessary to test the thermostat at this point or is that all that remains? The other question I have is does the 26 reading on the heater provide any indication of it's remaining life?
Thanks in advance and thank you for providing this wonderful resource which looks like it will be saving us from a much larger bill! Jim Jim |
Gene,
I posted on a seperate thread then saw this and it probably applies here. I have a bad defrost heater element in my GE refrig, tfx22kpdaww. I got the part to replace the bad one but the new part is a double element and the old is a single element. The double element is larger and seems to not fit. From what I understand GE intentionally replaced the single with the double so can you tell me what is the best way to either get the larger one to fit or how to find a single one? Thanks Read more: Problem with replacing defrost heater element http://forum.appliancepartspros.com |
a bit confused now - defrost thermostat out and I'm getting readings of over 240 on it after it has been sitting in ice water. I put it back in and started at step one. Cycled the defrost timer and didn't notice any temp change in the defrost heater. I held an ice cube against it and didn't notice any accelerated melting. It seems like it is the heater despite the readings last night unless I have completely misunderstood something. Leaning towards replacing all three since it is all accesible now.
Quote:
The defrost thermostat is definitely bad (based on the test result). The normal reading suppose to be about 0 Ohms. You had to replace it instead of putting it back. - The defrost thermostat Part number: AP2150024 Here are the breakdown diagrams and Replacement parts for FRIGIDAIRE FRT22TSEB5 Refrigerator | AppliancePartsPros.com Gene.
__________________
Quote:
The old single heating element kit is still available too and you can order it as well. - The defrost heater assembly Part number: AP2071523 Here are the breakdown diagrams and Replacement parts for General Electric TFX22KPDAWW Refrigerator | AppliancePartsPros.com Gene.
__________________
Thanks Gene. I ended up getting the double element one put in. You can get it in with some encouragement but it is very tight. I had received the instructions but they say nothing about getting the larger unit installed due to size issues. They only explain the wiring issues.
Hi my problem was like the standard freezer working but refrgerator warm, but with a added door light problem. the refrigerator light would stay on when the door was shut and with in a few min. would go off and stay off. If I un plugged the refrigerator and re plugged the light would go on and through this cycle. I had a feeling that the light was the problem with the warming (because I checked everything else, transformer, board, and therms.)
I was right, it was the simplest fix and this is what I did, gently pull out door switch light with a screw driver. pull out the wire connection.( when i did this the refrigerator fan started) Ohm the 1 and 2 pins should be open then ohm the 3 and 4 pins (the refrigerator side showed contact reading) I opened up the switch and could see that the pin was on a constant connection so I gently pulled and bent the pin away from the contact( look at the other side of the switch the freezer side for example) put the switch back together and reconnected to the refrigerator . And this fixed the warming problem. It is working great now I have a samsung modelRB1955sw |
| Display Modes | |
| freezer fine refrigerator too warm | cibao67 | Refrigerator & Freezer Repair | 5 | 07-10-2012 06:42 PM |
| Freezer is fine; refrigerator warm | LaDonna357 | Refrigerator & Freezer Repair | 15 | 03-28-2012 04:55 AM |
| Freezer is fine, refrigerator is too warm | amnhac81 | Refrigerator & Freezer Repair | 0 | 07-10-2009 02:48 PM |
| Freezer is fine, refrigerator is too warm. | allemich | Refrigerator & Freezer Repair | 3 | 04-20-2009 07:08 PM |
| Freezer is fine, refrigerator is too warm. | silvia28 | Refrigerator & Freezer Repair | 0 | 08-05-2008 10:16 AM |
