Discuss
Freezer is fine, refrigerator is too warm.
 in
Refrigerator & Freezer Repair
Thanks for the explanation . After several hours it started working normally . Originally Posted by Gene rkpatt, The ice maker a
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer is fine, refrigerator is too warm.
  #121 (permalink)
Old 08-11-2008, 07:54 AM
rkpatt rkpatt is offline
Junior Member
rkpatt is on a distinguished road
Default
Quote:
Originally Posted by Gene View Post
rkpatt,
The ice maker a thermostat inside and you have to wait a few hours until the ice maker cools down.
What kind of ice maker is in your fridge? Old style with the shut off arm on the left side or a newer electronic ice maker with the green LED?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #122 (permalink)
Old 08-15-2008, 04:12 PM
trojans trojans is offline
Junior Member
trojans is on a distinguished road
Default amana fridge model no. abb2223dew
appear to have faulty defrost system. what can I do? Thank you
  #123 (permalink)
Old 08-16-2008, 06:06 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
trojans,
Remove the rear cover in the freezer and check the defrost heater and the defrost thermostat for continuity. The defrost thermostat should be cold at the test time.
The defrost heater
If there is nothing wrong then the control board has to be replaced.
- The part number for the control board is AP4318990
- The part number for the defrost heater is AP3502547
- The part number for the defrost thermostat is AP3475238
__________________
Professional appliance repair in Los Angeles, California.
  #124 (permalink)
Old 08-17-2008, 06:46 PM
ktkhill ktkhill is offline
Junior Member
ktkhill is on a distinguished road
Default GE Profile PSS26SGRD-SS Refrigerator & Freezer getting warmer
GE Arctica PSS26S GRD SS
I'm having a problem with my refigerator and freezer warming up. I have unplugged it and replugged it in. The temp would then go down but now its back up again. Current temp freezer 13 refrig 42. Help?
  #125 (permalink)
Old 08-18-2008, 12:39 AM
abadfish66's Avatar
abadfish66 abadfish66 is offline
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
KTK. Please post serial#. Also check if the freezer fan is running, also is the center divider of the box hot to the touch, if it is, yake off the back access cover and veriify if the condensor fan is running, or if you have a very dirty condensor.
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!!
Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up.
  #126 (permalink)
Old 08-28-2008, 08:24 PM
GLL GLL is offline
Junior Member
GLL is on a distinguished road
Default
I have the same issue. I have a GE (Ser# LD308303; Model# GTS22UBMBRCC). The freezer is very cold and warm in the frig.
I removed the back panel and yes there was ice all over the evp coil. After reading this post, I decided to replace the defrost heater and thermostat.
I had the frig on for 24 hours and the frig is still not cold. The evp coil has ice on it.
I can't seem to locate the defrost timer also. Not sure if this model has a defrost timer.
Now, I'm starting to think that I have a bad board.
Can anyone confirm? Any help would be great.
Thanks all
This is an awesome board.
GLL
  #127 (permalink)
Old 08-29-2008, 09:41 PM
edgar edgar is offline
Junior Member
edgar is on a distinguished road
Default ref too warm
check evap & condenser fan ok,no air blockage but i do not have enough cold air coming out to the ref side . Is the evap fan a multi speed maybe it is on the low speed.thanks
  #128 (permalink)
Old 09-02-2008, 02:46 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Edgar,
What is the complete model number of the refrigerator?
__________________
  #129 (permalink)
Old 09-02-2008, 03:13 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
GLL,
Does the fan inside the freezer work properly?
__________________
  #130 (permalink)
Old 09-03-2008, 07:22 AM
devsam2@yahoo.com devsam2@yahoo.com is offline
Junior Member
devsam2@yahoo.com is on a distinguished road
Default Help
I have a GE Model# GTS22WCMARWW.
The freezer is freezing but the frig is not cold. I replaced the Evaporator Motor and it does not turn on. I had the mother board replaced about 4 years ago.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Refrigerator & Freezer warm GaryS Refrigerator & Freezer Repair 1 11-14-2007 12:34 PM
Warm Refrigerator and Freezer chuckmielke Refrigerator & Freezer Repair 0 11-10-2007 12:36 PM
Freezer works fine but refrigerator does not hold temperature mikel500 Refrigerator & Freezer Repair 0 10-16-2007 06:57 AM
freezer fine, refrigerator compartment not michael dykstra Refrigerator & Freezer Repair 0 08-20-2007 11:23 AM
freezer fine, refrigerator not cold fargnoli Refrigerator & Freezer Repair 0 08-08-2007 10:24 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
