| » Freezer is fine, refrigerator is too warm. |
Quote:
Did you clean the condenser coil on the back of the refrigerator? Here are the breakdown diagrams and Replacement parts for FRIGIDAIRE FRT8G6FMB2 Frigidaire/refrigerator | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Quote:
Thanks, Peter |
Peter,
No, you don't have to do it, but be careful not to touch any moving parts. You will see it. You can not check the fan motor without power. Gene.
__________________
Quote:
Thanks, Peter |
Gene, here are the temperature readings this morning. The freezer side is set for 0 but reading -1 on the digital display. Fridge side is set for 37 but reading 38 on digital display. The mercury therm. reads -1 for freezer and 42 for fridge side. What should I check next?
EDIT: Just got home and took another reading from the mercury therms. Freezer is -4 and Fridge is 37. The fridge's own digital temp. is reading 1 / 38. The compressor is still humming away. Is this normal? EDIT: This morning the mercury therms are showing -4 for freezer and 42 for fridge side. Thanks, Peter Last edited by pc527 : 06-10-2011 at 06:57 AM. |
First post here on the forums. It's refreshing to see how helpful the community is here (especially the participation of Gene).
I'm having the same problem, freezer has excess ice, fridge is warm, and I've narrowed down the culprit to either possibly being my defrost timer or cold control. First thing I did was advance the knob of my fridge to activate the defrost cycle. With the freezer panel off, the heater did it's job for roughly 30 minutes before the cool cycle engaged. Ok, great so far...defrost thermostat is at least closing it's connection (although it might be stuck) to permit power to the heater, and the heater is definitely workin. Second thing was I advanced the knob to just a bit before a full rotation so that I can observe if the timer switches into defrost mode. great so far, the heater element is working. Since i've observed the timer go into cool and defrost cycles automatically, is it safe to say my defrost timer is working fine? Now, what was the reason for the frost to buildup in the first place? Could it be that the cold control has a closed connection for the entire cool cycle and is not switching off and on? What else can be suspect in my situation. BTW, externals appear clean and the evap fan did have a ton of rattling noise that started around the same time of the whole problem. i'm thinking the fan problem is completely unrelated since from my research, if the evap fun was NOT working, then the the freezer temps would actually be higher, not frost-ridden as mine is. Thanks Last edited by oorah762 : 06-09-2011 at 02:42 PM. |
Peter,
The temperature in the fresh food compartment is fluctuating. This model is much more sophisticated than an average refrigerators and you may want to call a certified tech who has an experience with such dual evaporator refrigerators. Gene.
__________________
Quote:
__________________
Quote:
Peter |
| Display Modes | |
| freezer fine refrigerator too warm | cibao67 | Refrigerator & Freezer Repair | 5 | 07-10-2012 06:42 PM |
| Freezer is fine; refrigerator warm | LaDonna357 | Refrigerator & Freezer Repair | 15 | 03-28-2012 04:55 AM |
| Freezer is fine, refrigerator is too warm | amnhac81 | Refrigerator & Freezer Repair | 0 | 07-10-2009 02:48 PM |
| Freezer is fine, refrigerator is too warm. | allemich | Refrigerator & Freezer Repair | 3 | 04-20-2009 07:08 PM |
| Freezer is fine, refrigerator is too warm. | silvia28 | Refrigerator & Freezer Repair | 0 | 08-05-2008 10:16 AM |
