Discuss
Freezer is fine, refrigerator is too warm.
 in
Refrigerator & Freezer Repair
Gene, I have a Kenmore bottom freezer refrigerator, model 596.72214200 that has a cold freezer/warm refridgerator and there
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer is fine, refrigerator is too warm.
  #101 (permalink)
Old 07-14-2008, 08:36 PM
drydocked drydocked is offline
Junior Member
drydocked is on a distinguished road
Default
Gene, I have a Kenmore bottom freezer refrigerator, model 596.72214200 that has a cold freezer/warm refridgerator and there is frost on the back panel of the freezer. I'm going to tear into it to see if I can diagnose the problem but would really like a break down diagram for reference and can't seem to find one when I do the model number search. Is there one somewhere you can direct me to? Thanks for all the great advice on this forum.
  #102 (permalink)
Old 07-14-2008, 10:26 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
drydocked,
The defrost timer is located above the light module in the fresh food compartment.
The defrost heater is #15 on the break down diagram and the defrost thermostat is not illustrated.
- The part number for the defrost timer is AP3492964
- The part number for the defrost heater is AP3502547
- The part number for the defrost thermostat is AP3475238
__________________
  #103 (permalink)
Old 07-22-2008, 06:01 PM
eriksena eriksena is offline
Junior Member
eriksena is on a distinguished road
Default Amana ASD262RHRW not defrosting
Our refrigerator, Amana ASD262RHRW, was working fine until something blocked the freezer door open and it froze up completely. The evaporator was frozen solid and even the damper had ice in it. I defrosted it a little and some ice fell in from the freezer side into the damper area. Since it was defroster it worked for about one week then was frozen solid again. This time I defrosted it completely and a week later it was frozen again. I checked the resistance of the defrost heater and it was about 30 ohms so I replaced the defrost time. The compressor and the evaporator fan cycle off and on but the defrost heater does not kick in. Is there any chance that the defrost thermostat is not working (is stuck open)? I thought it the defrost thermostat was open it would never cool down and it does that great until it freezes up and I have to defrost it. Could the ice that fell in the damper between the compartments have damaged the main circuit board, I have no idea where it is located? Thanks in advance.
  #104 (permalink)
Old 07-23-2008, 04:09 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
eriksena,
This is a duplicated post.
Answered here: Amana side by side not defrosting
__________________
  #105 (permalink)
Old 08-01-2008, 07:09 PM
rkpatt rkpatt is offline
Junior Member
rkpatt is on a distinguished road
Default
Same problem here with a GE TBX25PGRWW . The refrigerator temp is about 60 deg F and the Freezer temp is about 10 deg F . Where is the defrost timer for this model located ? - Thanks
  #106 (permalink)
Old 08-02-2008, 07:30 AM
r.rydberg@gmail.com r.rydberg@gmail.com is offline
Junior Member
r.rydberg@gmail.com is on a distinguished road
Default
Quote:
Originally Posted by Gene View Post
In this post we will talk about one of the most common problems with your kitchen refrigerator – the freezer looks fine but the refrigerator part is warm.
Before we go further let me explain the basic performance of the refrigerator.
Your refrigerator could be made by Whirlpool, GE, Frigidaire or Maytag – it does not matter.
The cooling coil (aka evaporator coil) is located in the freezer behind the back panel.
The evaporator fan is distributing the cold air through the cooling coil into the freezer and, through the damper control, into the refrigerator, causing the refrigerator to cool down as well.
If anything goes wrong with the cooling coil in the freezer, wrong temperature in the refrigerator is more visible and gets your attention first due to a very big temperature difference in the freezer (normally -5°F to 6°F) and refrigerator (36°F to 40°F).
So the problem as it looks to you is: the freezer is fine but the refrigerator is warm.
Well, the cause of this problem could be very different and now we will go over the first one – a faulty defrost system.
As the evaporator coil cools down, the frost builds up on the coil.
If it does not defrost periodically then the excess frost will block the air flow though the cooling coil, affecting proper distribution of the cold air and causing an increase in the temperature (the fresh food compartment first).
The classic defrost system (we are not talking now about refrigerators operated by electronic devices) consists of three parts: the defrost timer which calls for defrost on certain time intervals, the defrost heater which should melt the frost and the defrost thermostat which senses the cooling coil temperature and operates with the electric current to the defrost heater.
The first and most important sign of a faulty defrost system is a frost build up on the back panel in the freezer.
How to find out which part of the defrost system is bad?
Based on my own experience, I would recommend the following procedure:
1). Locate the name plate with the model number of the refrigerator.
2). Type the model number in the search box, click the “search” button and you will be directed to the break down diagrams.
3). Using the break down diagrams, locate the defrost timer.
4). Using a flat screwdriver, slowly turn the shaft in the middle of the defrost timer clock wise until it clicks to switch from the cooling cycle to the defrost cycle.
5). Wait about 10 to 15 minutes, open the freezer door and see if you can hear a sizzling noise. If you can, then the problem is the defrost timer which has to be replaced.
If there is no such noise, go to the next step…
DO NOT FORGET TO UNPLUG THE REFRIGERATOR!
6). Remove the back panel in the freezer, unplug at least one wire on the defrost heater (you can locate it using the break down diagram) and check continuity across the defrost heater wires.
If it’s open, the defrost heater is bad and has to be replaced.
If it has some resistance, then the problem is the defrost thermostat.
You can check the defrost thermostat continuity only if it’s frozen because if it’s warm, it should be normally open.
Best regards.
Hi Gene-
I have this exact problem (Frozen freezer and warm fridge) and am having a hard time here locating the defrost timer. I have a GE GSS201EMBWW.
Any suggestions?
  #107 (permalink)
Old 08-03-2008, 05:53 AM
Junior Member
Default
I found the defrost timer in my GE refrigerator to be located in the upper part reg food compartment next to the thermostat ( temp control ) . There was a was a little white plastic plug that could be removed in order to turn it manually . If you want to go ahead and remove that panel cover anyway (power off ) , you will probably find a wiring diagram inside .
Quote:
Originally Posted by r.rydberg@gmail.com View Post
Hi Gene-
Any suggestions?
  #108 (permalink)
Old 08-03-2008, 06:21 AM
Junior Member
Default GE TBX25PAYGRRW warm fridge,cold freezer (defrost heater fuses ?)
This refrigerator has the classic symptoms of defrost circuit problems in the top sticky thread here .Back to the problem with my GETBX25PAYGRWW . I have checked the defrost thermostat (warm and cold ) and defrost heater and both are OK. However I was not getting power to the terminals of the defrost heater and was puzzled until I found the wiring diagram inside the panel that housed the defrost control ( defrost timer ). After looking at the wiring diagram ,I noticed that the wiring pigtals to the defrost heater for this model are fused so now I guess have to cut them and and check for continuity . If fuses (or fusible links )are blown, I guess it is pretty safe to presume that the problem is limited to defrost heater ?
  #109 (permalink)
Old 08-04-2008, 02:03 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
rkpatt,
I do not have the wiring diagram for your refrigerator. If you can post it, it might help to better understand your problem. I never seen a fused defrost circuit.
__________________
  #110 (permalink)
Old 08-04-2008, 02:11 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
r.rydberg@gmail.com,
There is no defrost timer in your refrigerator. It operates by the main control board on the back of the fridge.
You can find the complete troubleshooting instructions in the reply to bohemian question here: Freezer is fine, refrigerator is too warm.
Here are the break down diagrams for the GE refrigerator Model GSS20IEMBWW
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Refrigerator & Freezer warm GaryS Refrigerator & Freezer Repair 1 11-14-2007 12:34 PM
Warm Refrigerator and Freezer chuckmielke Refrigerator & Freezer Repair 0 11-10-2007 12:36 PM
Freezer works fine but refrigerator does not hold temperature mikel500 Refrigerator & Freezer Repair 0 10-16-2007 06:57 AM
freezer fine, refrigerator compartment not michael dykstra Refrigerator & Freezer Repair 0 08-20-2007 11:23 AM
freezer fine, refrigerator not cold fargnoli Refrigerator & Freezer Repair 0 08-08-2007 10:24 PM
