Discuss
Freezer is fine, refrigerator is too warm.
 in
Refrigerator & Freezer Repair
Originally Posted by nicehose hey gene, seems you are the college of knowlege on this stuff..i am thankfull for that.
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer is fine, refrigerator is too warm.
  #1021 (permalink)
Old 09-29-2010, 07:45 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by nicehose View Post
hey gene,
ive got a GE DSS25PFMDWW..
HERE THE PROB..I AM A NOVICE WHEN IT COME TO CHECKING CONTINUITY OF THERMOSTAT AND HEATER...IM ABOUT CERTIAN MY PROBLEM IS MY ADAPTIVE DEFROST BOARD..(COLD FREEZER , WARM FRIDGE , ICED OVER COILS) DUE TO A NEIGHBORS LIGHTNING STRIKE (MY GARAGE DOOR OPENERS FRIED) IM SURE THIS IS 1 +1 STUFF , BUT WHERE DO I PUT MY LEADS FROM METER TO EVAL HEATER AND THERM...BEFOR I REPLACE $100 BOARD THX
You do not have to take apart anything in the freezer in order to check the heater and thermostat. You can do it from the main control board. The instructions are on the page 3 of this thread, in the reply addressed to bohemian.
Here are the breakdown diagrams and Replacement parts for General Electric DSS25PFMDWW Refrigerator | AppliancePartsPros.com
Ads By Google
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #1022 (permalink)
Old 09-29-2010, 07:56 PM
Junior Member
governor is on a distinguished road
Default
Quote:
Originally Posted by Gene View Post
John,
Did it cover the whole evaporator or just part of it?
Did you clean the condenser coils on the back of the refrigerator?
Are the both fans (in the freezer and next to the compressor) working?
Entire evaporator was covered with thin coat of frost, I cleaned the condenser coils under the fridge with a vacum and air compressor last week, they are spotless. Both fans are running when they run. I am thinking something is intermitent here, I just checked and temp in fridge down to 38 now but it is empty and I know for sure evaporator has no ice at present time.
John
  #1023 (permalink)
Old 09-29-2010, 08:18 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
John,
It's very hard to say what is wrong at this time. Very strange behavior.
You have to keep the thermometers in both compartment and monitor the temperatures twice a day for a few days. Try not to open the doors too often and make sure the doors are not ajar.
__________________
  #1024 (permalink)
Old 09-30-2010, 06:13 AM
Junior Member
Default
John,
I went a head and ordered new timer and thermostat from here, they were pretty inexpensive this way I will know everything has been replaced at least. Thanks for your help.
John
  #1025 (permalink)
Old 09-30-2010, 06:55 AM
Junior Member
abcblah is on a distinguished road
Default
There is no defrost timer in this refrigerator. Defrost cycle among all other futures controls by the main control board (#801 on the diagram). You can the instructions on the page 3 of this thread.
Here are the breakdown diagrams and Replacement parts for General Electric GSS25XSRESS Refrigerator | AppliancePartsPros.com
Thank you very much! I will definitely try out the instructions on page 3 =)
  #1026 (permalink)
Old 09-30-2010, 05:31 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by governor View Post
John
You are welcome John. Keep us posted.
__________________
  #1027 (permalink)
Old 09-30-2010, 08:41 PM
Junior Member
stevewong10 is on a distinguished road
Default GE fridge TBH18DATFRWH
Hi, I just found this forum and I'm trying to do these steps that are posted at the beginning of this thread:
"4). Using a flat screwdriver, slowly turn the shaft in the middle of the defrost timer clock wise until it clicks to switch from the cooling cycle to the defrost cycle."
"5). Wait about 10 to 15 minutes, open the freezer door and see if you can hear a sizzling noise. If you can, then the problem is the defrost timer which has to be replaced."
So, I did step 4 with no problem. The fridge stopped and I waited about 15 minutes. When I opened the freezer door, I don't think I heard the sizzling noise. I mean how loud is this noise suppose to be? I was expecting something like eggs frying or maybe Rice Crispies with milk and I didn't get that. So, I waited some more and checked about an hour later. I still didn't noticed the sizzling, but the fridge came back on and when I checked the defrost control, it had moved. Does that mean the problem is not with the defrost control and I should go to step 6? I did noticed that more water collected at the inside bottom of the fridge. Does that mean anything?
  #1028 (permalink)
Old 10-01-2010, 08:26 AM
Junior Member
If the defrost control is OK, how do I get access to the defrost heater and the defrost thermostat? I took a look at the back and everything except the bottom is sealed. Do I get access to them from inside the freezer? Thanks.
  #1029 (permalink)
Old 10-01-2010, 07:10 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
What is wrong with your refrigerator?
Why do you believe there is something wrong with the defrost?
Here are the breakdown diagrams and Replacement parts for General Electric TBH18DATFRWH Refrigerator | AppliancePartsPros.com
__________________
  #1030 (permalink)
Old 10-02-2010, 08:09 PM
Junior Member
Default
Hi, basically, my freezer is fine but the fridge is too warm. So, I'm following the steps in the sticky. I got up to the step about testing the defrost controller. Now that I know about it, I've been watching it and I see that it is turning. Does that mean it works?
Also, I get a puddle of water inside the bottom of the fridge. I use a sponge to soak it up whenever I see water spill over to the floor. Thanks.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
freezer fine refrigerator too warm cibao67 Refrigerator & Freezer Repair 5 07-10-2012 06:42 PM
Freezer is fine; refrigerator warm LaDonna357 Refrigerator & Freezer Repair 15 03-28-2012 04:55 AM
Freezer is fine, refrigerator is too warm amnhac81 Refrigerator & Freezer Repair 0 07-10-2009 02:48 PM
Freezer is fine, refrigerator is too warm. allemich Refrigerator & Freezer Repair 3 04-20-2009 07:08 PM
Freezer is fine, refrigerator is too warm. silvia28 Refrigerator & Freezer Repair 0 08-05-2008 10:16 AM
