Discuss
Freezer is fine, refrigerator is too warm.
 in
Refrigerator & Freezer Repair
Hi Gene et al, I've got a Maytag PSB2151GRW, and I think I've got a bad defrost heater. It is
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer is fine, refrigerator is too warm.
  #1011 (permalink)
Old 09-15-2010, 03:16 PM
Junior Member
LNav.VNav is on a distinguished road
Default
Hi Gene et al,
I've got a Maytag PSB2151GRW, and I think I've got a bad defrost heater. It is melting ice, but I don't hear the sizzling sound you talk about. It will be good for a while but it seems to get behind when the humidity is high and the door doesn't get closed. The timer seems to be working okay (I hear it ticking and it does kick on periodically on its own, but I was debating on replacing it also since I'm working on it. I know they aren't co-located :-(
Does it sound like I'm on the right track?
Jim
Ads By Google
  #1012 (permalink)
Old 09-17-2010, 01:28 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by LNav.VNav View Post
Hi Gene et al,
Jim
Jim,
I do not think the heater is bad as long as it's melting ice. If there is not much snow or ice, that sizzling sound can not be heard.
A frost build up inside the freezer during the high humidity time is pretty normal, especially if the door is not closed properly. You have to keep the doors under control.
According to the information you posted I do not think it needs any repairs so far.
Here are the breakdown diagrams and Replacement parts for MAYTAG PSB2151GRW Ref - Sxs | AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #1013 (permalink)
Old 09-18-2010, 04:37 PM
Junior Member
Uncas is on a distinguished road
Default Gts18fbsarww
I have a GE model GTS18FBSARWW. The fridge is not cold but the freezer is. I have heavy frosting on the evaporator.
The defrost timer is working. I have ordered a new heater and thermostat while I defrost the unit. Any tips for replacing the heater elemtent? I appears to be behind the evaporator. I don't want to damage anything taking it out. What has to be disconnected to remove the evaporator?
Thanks,
Uncas
  #1014 (permalink)
Old 09-26-2010, 11:34 AM
Junior Member
Default
There is a heat shield that was above the heater that fell out when I removed the heater. It is not on the parts diagram. Where does this shield clip in?
Thanks,
Uncas
  #1015 (permalink)
Old 09-26-2010, 04:52 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Thanks,
Uncas
Unfortunately I did not work with such models. Maybe someone else on the forum can help you better.
__________________
  #1016 (permalink)
Old 09-29-2010, 08:08 AM
Junior Member
abcblah is on a distinguished road
Default
Hey Gene!
I have a GE GSS25XSRESS model. The refridgerator would frost up in the back and I guess that is whats making the fridge not cold enough. But then it comes back on again whenever it feels like and turns off again whenever. I am just having a little trouble finding the defrost timer that you have mentioned. So I was wondering it you can help me locate it so I can test it right away.
Thank you
  #1017 (permalink)
Old 09-29-2010, 09:05 AM
Junior Member
governor is on a distinguished road
Default
Hi Gene
I have to give you credit, the ammount of help and time you give here is commendable! great work.
I have a 2 year old whirlpool ET1PHKXPQ07 Top Freezer with added icemaker, freezer is 5 degrees and fridge between 40-47. Seems like Very little air flowing into fridge, defrost circuit does work(when I was checking it), when compressor and fan shuts off I hear whining sounds and water dripps into evaporator pan under fridge(about 1/2 inch of water in pan). I replaced the cold control thermostat and waited 24 hours..same temps. It seems like everything is working the way it should (at least when I watched it) is it possible I have an intermittent defrost problem? Not sure what else could be going on? Any suggestions? One other note..I changed the thermostat because when I tapped on control knob i could get the compressor and fan to turn on but I see the defrost timer is inside that cover also, could the contacts be sticking inside it stopping the compressor circuit from turning on?
edit: Just to be sure, tonight I removed the back panel of the freezer and checked for frost, there was only a light covering of frost so I turned the timer clockwise and on the first click nothing happened so I kept turning it, on the second click the fan and compressor shut off and the heating element came on and melted all the frost from the coils, I must say this thing gets REALLY hot! Anyway I know for sure my defrost heating element is working ok, is it normal for nothing to happen on the first click of the timer? The heating element actually heated up the entire freezer it got so hot? is it supposed to get this hot? even though heating element does come on and eventually shust off could the thermostat on it be bad?
John
  #1018 (permalink)
Old 09-29-2010, 09:10 AM
Junior Member
nicehose is on a distinguished road
Default Gene!!
hey gene,
seems you are the college of knowlege on this stuff..i am thankfull for that.
ive got a GE DSS25PFMDWW..
HERE THE PROB..I AM A NOVICE WHEN IT COME TO CHECKING CONTINUITY OF THERMOSTAT AND HEATER...IM ABOUT CERTIAN MY PROBLEM IS MY ADAPTIVE DEFROST BOARD..(COLD FREEZER , WARM FRIDGE , ICED OVER COILS) DUE TO A NEIGHBORS LIGHTNING STRIKE (MY GARAGE DOOR OPENERS FRIED) IM SURE THIS IS 1 +1 STUFF , BUT WHERE DO I PUT MY LEADS FROM METER TO EVAL HEATER AND THERM...BEFOR I REPLACE $100 BOARD THX
  #1019 (permalink)
Old 09-29-2010, 07:33 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by abcblah View Post
Hey Gene!
Thank you
There is no defrost timer in this refrigerator. Defrost cycle among all other futures controls by the main control board (#801 on the diagram). You can find the instructions on the page 3 of this thread.
Here are the breakdown diagrams and Replacement parts for General Electric GSS25XSRESS Refrigerator | AppliancePartsPros.com
__________________
  #1020 (permalink)
Old 09-29-2010, 07:40 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by governor View Post
...there was only a light covering of frost...
John,
Did it cover the whole evaporator or just part of it?
Did you clean the condenser coils on the back of the refrigerator?
Are the both fans (in the freezer and next to the compressor) working?
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
freezer fine refrigerator too warm cibao67 Refrigerator & Freezer Repair 5 07-10-2012 06:42 PM
Freezer is fine; refrigerator warm LaDonna357 Refrigerator & Freezer Repair 15 03-28-2012 04:55 AM
Freezer is fine, refrigerator is too warm amnhac81 Refrigerator & Freezer Repair 0 07-10-2009 02:48 PM
Freezer is fine, refrigerator is too warm. allemich Refrigerator & Freezer Repair 3 04-20-2009 07:08 PM
Freezer is fine, refrigerator is too warm. silvia28 Refrigerator & Freezer Repair 0 08-05-2008 10:16 AM
