Discuss
GE refrigerators (GS* & PS* models), the evaporator fan motor test and replacement.
 in
Refrigerator & Freezer Repair
will do, we turned fridge to 4 setting and all seems well, a guy at my work said keeping settings
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » GE refrigerators (GS* & PS* models), the evaporator fan motor test and replacement.
  #51 (permalink)
Old 02-06-2010, 09:06 AM
Junior Member
SpartanRookie is on a distinguished road
Default
will do, we turned fridge to 4 setting and all seems well, a guy at my work said keeping settings at 5/5 avoids failing motherboard/fans, but not sure he has the same model/motherboard.
Ads By Google
  #52 (permalink)
Old 02-07-2010, 03:00 PM
Junior Member
asmyles is on a distinguished road
Default
Quote:
Did all of the above and Yes the board is shot along with the Fan motor. Steps to replace the Board? Any help would be great!!!!
  #53 (permalink)
Old 02-08-2010, 01:53 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
For SpartanRooky, factory control settings of midrange have NO effect on the motherboard reliability.
To replace the motherboard, just follow the directions with the new board. I am sure you are aware that the motherboard has the same weak drivers for all the devices in the fridg, so just make sure your condensing fan motor and auger motor are ok befor pluging in the new board. Also use a surge protector as I suggested before.
__________________
  #54 (permalink)
Old 02-08-2010, 02:22 AM
Junior Member
Default
Thanks a ton!!!
  #55 (permalink)
Old 03-25-2010, 07:11 PM
Junior Member
Default
Ok, finally got a chance to check out your suggestions, and here is what I found.
J1 doesn't have pin 2 connected, I am assuming pin 1 is on the right side of the connector on mine since the left side is not wired.
Ohming pin 1 to pin 5 yields 0 ohms. If I assume that the right side is pin 1, then pin 1 connected to pin 2 not connected is 6 ohms.
I am still having problems with things in the fridge freezing, and I did verify the light is coming through the opening between them, so the opening looks good.
  #56 (permalink)
Old 03-26-2010, 01:35 AM
Senior Expert
APP Volunteer
Default
I would check your fresh food thermisters, if your wiring is different, then try to locate the service sheet under the kick panel. If none, I would locate the thermisters and check them with a meter. Seems like your damper door is either stuck open or driven open by faulty thermisters.
__________________
  #57 (permalink)
Old 03-26-2010, 05:19 AM
Junior Member
Default
I couldn't find any service sheets or thermistors. I do think the damper door may be faulty, it seems always open wide. I do have a little valve in the lower fridge part to adjust the temperature, and when I turn it up or down all the way I don't see the damper door closing. I will check later tonight for thermistors as I still have food in it, so not easy to check all locations. Is the damper door compartment replaceable?
  #58 (permalink)
Old 03-26-2010, 05:52 AM
Senior Expert
APP Volunteer
Default
Damper door is replaceable, rather expensive while thermisters are cheap. Best replace them first.
__________________
  #59 (permalink)
Old 03-26-2010, 07:23 AM
Junior Member
Default
Ok, I will hunt those down, I did look a bit more and found this though.
My fridge has 3 possible openings between freezer and fridge (side by side).
1 is the damper door up top, another is similar but smaller down at the bottom, and the other is a little lever that will open or close a small hole by the drawers at the bottom.
I did verify if I set the temp to 0 on fridge, no air comes through damper door, so I'm guessing the door does work, it appears no matter what setting I use to me the air feels the same pressure, so my gut is that it thinks it needs to always be cooling it, hopefully the thermisters are the culprit. Did my check on the J1 between 1 and 5 of 0 ohms confirm thermister is shorted, or not for sure?
I will find those, any idea where they put them in GE models, or does it just depend?
  #60 (permalink)
Old 03-26-2010, 09:28 AM
Junior Member
Default
I am not having any luck finding any references to thermistors on the fridge side of dss25pfmd ge fridge. anybody help?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Evaporator Motor GaryDolman Refrigerator & Freezer Repair 7 04-20-2012 02:51 PM
Evaporator motor doesn't run mtc2912 Refrigerator & Freezer Repair 3 12-07-2009 07:25 AM
Evaporator Motor Kit roseann Refrigerator & Freezer Repair 0 11-03-2009 07:27 AM
evaporator motor replacement TREX Refrigerator & Freezer Repair 7 06-18-2009 10:05 PM
evaporator fan motor billy morris Refrigerator & Freezer Repair 0 01-29-2009 04:23 PM
