Discuss
GE refrigerators (GS* & PS* models), the evaporator fan motor test and replacement.
 in
Refrigerator & Freezer Repair
You might have a refrigerant leak or a bad condensing fan motor or evaporator motor. Verify both motors are running,
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » GE refrigerators (GS* & PS* models), the evaporator fan motor test and replacement.
  #21 (permalink)
Old 05-07-2009, 01:12 PM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
Verify both motors are running, if so, remove the back panel in the freezer and check the frost pattern. If tottaly frosted, you have a defrost problem, if partially frosted, you either have a refrigerant leak or a bad compressor.
Ads By Google
__________________
  #22 (permalink)
Old 05-07-2009, 04:16 PM
Junior Member
RB47 is on a distinguished road
Smile
Quote:
Originally Posted by RB47 View Post
I have an Eterna model # ESS25XGMB CC, serial # HA 266281. The freezer is not cold enough (currently about 12 degrees F) and the vegetables in the bottom bin of the refrigerator compartment are frozen. The refrigerator (compressor?) is running constantly.
Follow up: I took the evaporator coil cover off this morning. The fan was running, but the coil was frozen solid. After running my wife's hair dryer for an hour and a half, the coil was clean and dry. Freezer temp's down to 2 degrees and dropping. Problem solved (unless it freezes up again.)
  #23 (permalink)
Old 05-07-2009, 04:25 PM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Default
Go ahead richappy. All yours dude. Tom
  #24 (permalink)
Old 07-16-2009, 11:49 AM
Junior Member
Question Defrost problem
OK, I have a defrost problem. The evaporator coil freezes up every couple weeks and requires manual defrosting. I followed the troubleshooting guide at acmehowto.com - How To Fix a Refrigerator. The defrost heater appears to be good (resistance = 22 ohms). I can't measure the resistance of the defrost thermistor or defrost thermostat because they are hard wired into the wiring harnesses and I can't trace the wires to the plug without major disassembly. By then the thermostat is warm and may be properly open. Is there any way to test resistance of these components at the motherboard? Is there a wiring diagram available anywhere? (Couldn't find one behind the toe grill or anywhere else on the fridge.)
  #25 (permalink)
Old 07-16-2009, 01:24 PM
Senior Expert
APP Volunteer
Default
Remove the cover of the motherboard, unplug the 4 pin power connector, and stick a jumper between the line pin and def. pin as printed on the motherboard. If you now get defrost current as measured on the jumper, you have a bad motherboard AP4297272. If no current, probably a bad defrost thermostat.
There is a schematic in the "sticky" above with the South Jersey group I found that you can refer to.
This is the "manual defrost initiaton proceedure.
__________________
  #26 (permalink)
Old 07-18-2009, 12:08 PM
Junior Member
Default
Rich, Excuse my caution, but I don't want to make a dumb mistake and fry something. With the connector unplugged, do I jumper between the pins on the motherboard or between the corresponding contacts on the connector? (Without a wiring diagram, I'm flying blind.)
I found the "junk GE GSS20IEMbww new motherboard" thread, but the schematic seems to have been removed. There's a red X in post #8 where it used to be. Is there another way to get this schematic?
  #27 (permalink)
Old 07-18-2009, 05:39 PM
Senior Expert
APP Volunteer
Default
You unplug the connector from the board and jumper the connector pins I mentioned.
I entered the Fixit now Samurai site and found the schematic no longer available, sorry. Good news is they have had good reliability with thermistors on these refrigerators, so you probably will have little trouble.Post back if you do
__________________
  #28 (permalink)
Old 07-19-2009, 01:02 PM
Senior Expert
APP Volunteer
Default Damper motor test
For the GE GS and PS models and all ones with the AP4297272 motherboard with damper door problems.
I believe the damper is controled by a simple on/off application of voltage cycling on the thermistor resistance.So, in normal operation, the door will open and close periodically.If the fridge is very warm, the door will remain open till the fridg. gets down to the control setting temperature.Precise control of the fridg. temperature is done by control of the fan speed; higher frequency, more airflow, lower frequency, less airflow. All thermisters are the same; 65kohm=-
-13 degrees, 12kohm=+40 degrees, 5kohm=+75 degrees. These are just typical readings. You can measure these at the J1 connector of the motherboard, upper right. Measure between common J1-pin5 and either J1-1 fresh food, J1-2 fresh food, J1-3 freezer and J1-4 evaporator, used to terminate defrost.
If your thermisters are reading close to these sort of normal values and the damper door remains open, or closed, and the damper motor is not blown out, you probably have a bad motherboard. The 12 volt dc motor resistances are red- yellow 430 ohm, blue-white 430 ohm. If either of these are shorted or way low in value, you will need to also buy a new damper assembly as it will blow out the motherboard. To check the motherboard output voltages to the damper, go to the upper middle connector J3. Measure between J3-1 and J3-2, then between J3-3 and J3-4 should be around 12 volts.
The South Jersey schematic was scubbed off the Samurai site, only available to pros, just refer to your service schematic. If it is missing, contact me for pin info.
__________________
  #29 (permalink)
Old 07-21-2009, 10:11 PM
Junior Member
Default
Rich, Thanks for your help. The evaporator thermistor is bad. Resistance is 1.5 Kohms, while the freezer thermistor is just under 50 kohms. Glad it isn't the motherboard.
BTW, I finally found the wiring diagram - inside the temperature control panel in the refrigerator compartment. Nobody suggested looking there until I talked with GE Customer Service again yesterday.
  #30 (permalink)
Old 07-22-2009, 01:43 AM
Senior Expert
APP Volunteer
Default
Very good work, I appreciate the feedback, you solved a "difficult" problem.
And I again thank the South Jersey group for publishing the info and schematic; this publication and customer complaints forced GE to include the schematic in future refrigerators.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Evaporator Motor GaryDolman Refrigerator & Freezer Repair 7 04-20-2012 02:51 PM
Evaporator motor doesn't run mtc2912 Refrigerator & Freezer Repair 3 12-07-2009 07:25 AM
Evaporator Motor Kit roseann Refrigerator & Freezer Repair 0 11-03-2009 07:27 AM
evaporator motor replacement TREX Refrigerator & Freezer Repair 7 06-18-2009 10:05 PM
evaporator fan motor billy morris Refrigerator & Freezer Repair 0 01-29-2009 04:23 PM
