Discuss
GE refrigerators (GS* & PS* models), the evaporator fan motor test and replacement.
 in
Refrigerator & Freezer Repair
That support is too confusing one and not working fine for me
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » GE refrigerators (GS* & PS* models), the evaporator fan motor test and replacement.
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #211 (permalink)
Old 04-21-2016, 01:02 AM
Junior Member
hamish05064 is on a distinguished road
Default
  #212 (permalink)
Old 08-03-2016, 07:53 AM
Junior Member
defurr is on a distinguished road
Angry Fan or coils?
I gather from the fact that this is the #2 most popular post in this sub-forum that GE evaporator fans are pretty problematic? I have a GE Profile PFCS1PJZSS French door that I inherited. It can't be more than six years old. A year ago, I think the evap fan was getting bogged down by frost. A repairman told me the compressor was bad. I allowed the unit to sit for a few hours, plugged back in, and it worked like a champ for another year.
Then, last weekend, same symptoms (warm fridge/cold freezer), but no fan noise. Different tech comes out and proclaims the same thing: "Only 5% of evap coils working. $3K to replace sealed system. Need a new fridge!" And yet 24 hours after the guy left, freezer is once more at 0 degrees.
Granted that my evap coils might be under-performing a bit, but if fan isn't working at all (which is clearly the case, based on room temp fridge) then couldn't I just get that replaced and keep using this thing for at least a while longer?
  #213 (permalink)
Old 05-12-2018, 07:08 PM
Junior Member
Sean_Herrera is on a distinguished road
Default Brand new board and evap motor burned out
Hi. Iím new to this forum trying to find help for the problem I describe below. My GE Fridge is a DSS25KGRBBB side-by-side and is 14 yrs old.
About 2 weeks ago, we noticed the freezer section not being as cold as before with food starting to thaw and ice to melt. I observed the evap fan spinning very slowly - I thought too slow to pull sufficient air through the evap coils. You could barely feel any air coming out the vents. I checked the evap coils and they werenít iced up so blockage was not a reason for the low air flow. (Also please note that I changed the defrost thermostat, defrost heater and all 4 thermistors in the unit around 1 year ago as we were having issues with the evaporator icing up).
I checked the main board and it looked fine so I decided to replace the evap motor (WR60X100074). Upon turning the unit back on the fan was spinning fast (like I remember it doing) and the fridge and freezer worked fine for 1 week before the temp started to rise again at which point I noticed the evap fan was not coming on at all and upon checking the main board found the upper of the 2 fairly large resistors burnt out. I removed the 1-week old evap motor and found it to be burnt out (using an external DC source). With the board being the original 14 yr old one I decided to change it along with the burnt evap motor and I also changed the evap thermistor to be on the safe side - so all 3 parts were now brand new.
I re-installed everything and all was working fine - fan spinning strongly, freezer cold, ice maker working great, etc. This morning (so 5 days later) I woke up to find food in the freezer thawing again and the evap fan not coming on at all. I then checked the main board to find that the same resistor that had burnt on the original board had burned on this one too. Arghhhh!! I have not had the chance to check the evap motor but Iím quite sure Iím gonna find it was burned out just like the previous one.
So having changed the evap motor, thermistor and the board, I am totally stumped as to how the board and the motor have again burned out. And prior to all this happening, in the 14 years Iíve had the unit Iíve never had any issues with the evap fan.
Greatly looking forward to some expert opinions on this.
Many thanks in advance...
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Evaporator Motor GaryDolman Refrigerator & Freezer Repair 7 04-20-2012 02:51 PM
Evaporator motor doesn't run mtc2912 Refrigerator & Freezer Repair 3 12-07-2009 07:25 AM
Evaporator Motor Kit roseann Refrigerator & Freezer Repair 0 11-03-2009 07:27 AM
evaporator motor replacement TREX Refrigerator & Freezer Repair 7 06-18-2009 10:05 PM
evaporator fan motor billy morris Refrigerator & Freezer Repair 0 01-29-2009 04:23 PM
