Discuss
GE refrigerators (GS* & PS* models), the evaporator fan motor test and replacement.
 in
Refrigerator & Freezer Repair
Hello, Unplug the refrigerator. Remove the wire from the J9 terminal at the control board and check for continuity between
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » GE refrigerators (GS* & PS* models), the evaporator fan motor test and replacement.
  #201 (permalink)
Old 04-02-2013, 09:22 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hello,
Unplug the refrigerator. Remove the wire from the J9 terminal at the control board and check for continuity between this wire and the neutral wire connected to the J7-9. The normal reading suppose to be about 22 Ohms. If the reading is different, check the defrost heater and the overtemperature thermostat for continuity. Post the results.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #202 (permalink)
Old 04-03-2013, 05:20 AM
Junior Member
freddyrick is on a distinguished road
Default
Quote:
Originally Posted by Gene View Post
Hello,
OK, is there a wiring schematic diagram posted anywhere? Just want to be sure I get J9 and J7-9 correct. Thanks.
  #203 (permalink)
Old 04-03-2013, 12:51 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
I'm not sure how it can help you because all terminals and connectors are marked very clear but I attached it to the post.
__________________
  #204 (permalink)
Old 04-07-2013, 09:33 AM
Junior Member
Default
Got it. Thank you.
  #205 (permalink)
Old 06-29-2013, 07:27 PM
Junior Member
GBEARSS is on a distinguished road
Smile Frige keeps warming up.
I don't see anything else at this time.
Hi, Bought house with GE fridge Model; GSS20IETAWW that warms up second time in 3 wks. Bought new cond. fan motor last time ,havn't installed yet. New fridge 2K,not likely.What should I be looking for to test. Your experience base seems quit broad.thanks in advance. Glenn.
  #206 (permalink)
Old 07-22-2013, 01:37 PM
Junior Member
Smile
Quote:
Follwed test till it said contact a pro. Found a bad heater bulb,installed double heater bulb.He said pump unit working ok cause center door post warm. Will feel more confedent if I have trouble in the future. Thanks again. Glenn Bearss.
  #207 (permalink)
Old 08-10-2014, 02:15 PM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default New info on replacing evaporator motor and motherboards
If the evaporator motor fails it usually burns out the driver on the motherboard unless the motherboard is the new style with relays isolating the drivers from high current due to failing motors.
Very rarely will any motherboard damage an evaporator motor, the drivers are limited to the 12 volt supply level. If the internal dc supply should put out much higher voltage, internal electronics would probably fail before the motors. If not, all the motors would probably fail, not just the evaporator motor.
So, it is suggested to replace just the failed evaporator motor, unless you can see a burnt resistor on the board, or you have other motors that failed. This is even more justified if the motherboard is the new style with the extra 3 relays.
__________________
  #208 (permalink)
Old 08-20-2014, 08:30 AM
Junior Member
Susan24 is on a distinguished road
Default
I have a GE Profile model PSS27NGNABB. The refrigerator part is cool but the freezer is not cold. It normally makes ice fast but the ice bend has hardly any ice. How can I tell if the compressor is going on this refrigerator and would it be worth fixing, if it is the compressor? It sounds like a something bottomed out (clunk noise not whinning) it's kinda like the compressor is trying to work-would this be the problem?
  #209 (permalink)
Old 08-28-2014, 02:02 AM
Junior Member
smiley1989 is on a distinguished road
Default GE artica compressor fan or motherboard?
Hey I was hoping someone could help me with my ge fridge model#PSS26SGPASS /serial # SF413296... Im pretty sure I seen it on here before, but can't find it now.. Alright so the compressor/ condenser fan is not spinning very fast and the compressor is getting really hot... I have floor fan on compressor to help cool and it works. Both freezer and fridge are at right temps. So I think its the fan but I seen a diagram on here where you guys test the motherboard, so could someone send that diagram to me just so I could be 100% sure before I replace fan... Thanks in advance because I know you guys help me all the time.
  #210 (permalink)
Old 12-12-2015, 06:05 PM
Junior Member
joebob01 is on a distinguished road
Default
I have a psf26pgta ww and the evap fan doesn't always run causing my ice to melt a little then refreeze. I checked supply voltages (red wire) at the control board and they were at 18v instead of the 13.6 its supposed to be. and I get nothing checking the yellow. does that seem like a control board problem rathr than fan problem?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Evaporator Motor GaryDolman Refrigerator & Freezer Repair 7 04-20-2012 03:51 PM
Evaporator motor doesn't run mtc2912 Refrigerator & Freezer Repair 3 12-07-2009 08:25 AM
Evaporator Motor Kit roseann Refrigerator & Freezer Repair 0 11-03-2009 08:27 AM
evaporator motor replacement TREX Refrigerator & Freezer Repair 7 06-18-2009 11:05 PM
evaporator fan motor billy morris Refrigerator & Freezer Repair 0 01-29-2009 05:23 PM
