Discuss
GE refrigerators (GS* & PS* models), the evaporator fan motor test and replacement.
 in
Refrigerator & Freezer Repair
You are welcome. But I do not think the voltage over 13 VDC is a good reading. You may want
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » GE refrigerators (GS* & PS* models), the evaporator fan motor test and replacement.
  #191 (permalink)
Old 01-31-2013, 01:41 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome. But I do not think the voltage over 13 VDC is a good reading. You may want to check it at the control board too.
Ads By Google
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #192 (permalink)
Old 02-04-2013, 05:51 AM
Junior Member
freddyrick is on a distinguished road
Default
[quote=Gene;797641]You are welcome. But I do not think the voltage over 13 VDC is a good reading. You may want to check it at the control board too.
Gene, you are correct and thank you. The voltage output at R and Y was up to 19.5vdc. I bought a new motor, but instead of installing it, I tested the resistance and it read the same as the old motor, although each reading was polarity specific. I got two different readings on R/W at the new motor when I reversed polarity of the ohmmeter. Why is this? Also, the old motor still runs for a couple of seconds when first plugged in. So, I'm guessing its the motherboard. Wish I knew better how to test the motherboard before buying a new one.
  #193 (permalink)
Old 02-04-2013, 11:04 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
[quote=freddyrick;798121]
Quote:
Originally Posted by Gene View Post
...although each reading was polarity specific. I got two different readings on R/W at the new motor when I reversed polarity of the ohmmeter...
I never heard about such things. Check how is your ohmmeter set.
__________________
  #194 (permalink)
Old 02-11-2013, 05:34 AM
Junior Member
Default
Everything is set correctly. Could it be because this is a variable speed induction motor?
  #195 (permalink)
Old 02-11-2013, 04:09 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
What kind of meter did you use?
__________________
  #196 (permalink)
Old 02-12-2013, 09:14 AM
Junior Member
Default
Basic digital ohmmeter.
  #197 (permalink)
Old 02-12-2013, 06:36 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by freddyrick View Post
...I got two different readings on R/W at the new motor when I reversed polarity of the ohmmeter...
What was the difference?
How good is the battery in your meter?
Have you replaced the main control board yet?
__________________
  #198 (permalink)
Old 02-13-2013, 12:28 PM
Junior Member
Default
I just got a new board to go with the new motor, and will install them together and hope for the best. Thanks.
  #199 (permalink)
Old 02-13-2013, 07:57 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome. Both new parts together should fix it.
__________________
  #200 (permalink)
Old 04-02-2013, 07:50 AM
Junior Member
Default
Hello again. Installed both parts and it worked fine for over a month. Yesterday I found the evaporator coil all frosted up. Defrosted with the blow dryer, seems to be working OK again. Any ideas what might have caused the coil to frost up? Thanks.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Evaporator Motor GaryDolman Refrigerator & Freezer Repair 7 04-20-2012 02:51 PM
Evaporator motor doesn't run mtc2912 Refrigerator & Freezer Repair 3 12-07-2009 07:25 AM
Evaporator Motor Kit roseann Refrigerator & Freezer Repair 0 11-03-2009 07:27 AM
evaporator motor replacement TREX Refrigerator & Freezer Repair 7 06-18-2009 10:05 PM
evaporator fan motor billy morris Refrigerator & Freezer Repair 0 01-29-2009 04:23 PM
