| » GE refrigerators (GS* & PS* models), the evaporator fan motor test and replacement. |
I have a TPS24BPDABS with a freezer that is cold at the bottom and not so cold at the top. Frig side also not cold enough. Also, ice maker stopped working and ice melted.
Upon removel of evaporator panel, frost was found at the top coils, but frost free at the bottom coils. Defroster element happened to come on and appeared to be working fine. However, evaporator fan never appears to run. So, I suspect this is the problem. Does this sound right to you? And does this motor test procedure also apply to my model? Also, the test procedure in step shows diconnecting the motor before proceeding to the evap motor test procedures. Is that correct? Thanks in advance for whatever help you might be able to provide. Steve |
Don't have a full model #, but if it has a mother board, that is the problem. Tom ********************************************
Quote:
Hi, I think I need a new freezer (evap.?) fan motor, i have tested it and there is no resistance. The volts as measured by the refridge. service test 12.9 (test doesn't turn fan on). I have read above that i will need to replace the fan and evaporator thermistor. How do you replace the evaporator thermistor? Do you cut the old one out and solder the new one in place? I have a Kenmore Elite, model # 596.76502500. I posted on one of your other threads but i think this thread answers my problem better. Thanks! |
hello~
I am trying to see if i can repair my refrig on my own. I had to replace the motor evap fan 2yrs ago..i'm thinking it might be the same thing thats causing it not to work now. Th e temp is not correct in the refrig..and the ice maker will not work? |
Quote:
What is the complete model number of the refrigerator? Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Hi Gene~
the problem is 2 things...me fridge will not keep the correct temp it is not cold enough...have it up to 7 and its not correct temp. also i noticed that the ice maker is not working. i do not hear the fridge clicking off and on? it seems to be the same thing when 2 yrs ago i had to replace the motor evap fan? model #GTS18KBMDRWW THANKS |
What exactly are temperatures in the freezer and in the refrigerator?
Do you see a frost on the rear panel in the freezer? Remove the cover on the back of the fridge and make sure the fan motor next to the compressor is running. Clean the condenser coil from the back and from the front. Here are the breakdown diagrams and Replacement parts for GE GTS18KBMDRWW | AppliancePartsPros.com Gene.
__________________
I have an Eterna model # ESS25XGMB CC, serial # HA 266281. The freezer is not cold enough (currently about 12 degrees F) and the vegetables in the bottom bin of the refrigerator compartment are frozen. The refrigerator (compressor?) is running constantly.
From other problem reports I've read, I suspect that the evaporator fan is not working. Is this likely? Can I use the procedure at the top of this thread on my model? Thanks. |
| Display Modes | |
| Evaporator Motor | GaryDolman | Refrigerator & Freezer Repair | 7 | 04-20-2012 02:51 PM |
| Evaporator motor doesn't run | mtc2912 | Refrigerator & Freezer Repair | 3 | 12-07-2009 07:25 AM |
| Evaporator Motor Kit | roseann | Refrigerator & Freezer Repair | 0 | 11-03-2009 07:27 AM |
| evaporator motor replacement | TREX | Refrigerator & Freezer Repair | 7 | 06-18-2009 10:05 PM |
| evaporator fan motor | billy morris | Refrigerator & Freezer Repair | 0 | 01-29-2009 04:23 PM |
