Discuss
GE refrigerators (GS* & PS* models), the evaporator fan motor test and replacement.
 in
Refrigerator & Freezer Repair
Ok. I'll order a mainboard and we'll see how it goes. Thank you very much for the help. Ads By
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » GE refrigerators (GS* & PS* models), the evaporator fan motor test and replacement.
  #181 (permalink)
Old 10-12-2012, 09:43 PM
Junior Member
gtiphil is on a distinguished road
Default
Ads By Google
  #182 (permalink)
Old 12-08-2012, 03:45 PM
Junior Member
amathrawala is on a distinguished road
Default GE refrigerator making humming noise
Hi Lisa,
I have the same issue. did you ever get an answer to your question ? I would be very interested. It looks like my evaporator fan is making the humming noise.
  #183 (permalink)
Old 12-10-2012, 08:42 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by amathrawala View Post
...It looks like my evaporator fan is making the humming noise...
What is the complete model number of the refrigerator?
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #184 (permalink)
Old 01-27-2013, 06:58 PM
Junior Member
freddyrick is on a distinguished road
Default Evaporator fan voltage tests
Quote:
Hello Gene, I have a GE gsh25sgpass. Evaporator fan motor works intermittently, currently not running. Voltages measure as follows: RW 13.6, YW 13.6, BlueW 4.6 volts DC. Is this a multispeed motor, and what does BlueW run, and is 4.6 OK?
  #185 (permalink)
Old 01-28-2013, 08:37 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hello,
The following article on our forum will explain in detail how this fan motor works and what to do to fix it - Replacing GE refrigerator evaporator motors and motherboards
There are two different kind of motors used by GE. You have to determine by yourself which one is used for your fridge before you will order it.
- The evaporator fan motor with a thermistor wired into the connecting harness Part number: WR60X10074
- The evaporator fan motor without the thermistor Part number: WR60X10185
- The main control board Part number: WR55X10942
Here are the breakdown diagrams and Parts for GE GSH25SGPASS Refrigerator - AppliancePartsPros.com
__________________
  #186 (permalink)
Old 01-30-2013, 07:52 AM
Junior Member
Default
Hello,
I'll try the resistance test, but Richappy says that test doesn't help. Is the low voltage of 4.6vdc at the Blu White plug an issue, is there another way to test the motherboard?
  #187 (permalink)
Old 01-30-2013, 04:47 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I understand your point. It's expensive repair but there are no any other choices. In order to fix the problem you have to replace both parts. It is pretty standard procedure in such situation. Unless GE will take of it. Try to call them.
__________________
  #188 (permalink)
Old 01-30-2013, 07:00 PM
Junior Member
Default
Now I am totally confused. Are there any specs on the voltage outputs at the plug-in to verify the motherboard? I've always tried not to throw expesive parts at a problem without verifying a fault. Although, when I cut out the motor I will test the resistance and report back to you for future reference. the motor was $30 or so. Thanks.
  #189 (permalink)
Old 01-30-2013, 09:56 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You can find the voltage specs on the first page of this thread in the article written by Richappy..
The blue wire is the motor RPM feedback input - no sense for voltage test.
__________________
  #190 (permalink)
Old 01-31-2013, 06:36 AM
Junior Member
Default
OK, thanks, I read that, and I have over 13vdc at both red and yellow, so for now I am going to assume the motherboard is OK. My concern was that maybe the Blu/white needed 13vdc as well. I appreciate your help with this problem, thank you.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Evaporator Motor GaryDolman Refrigerator & Freezer Repair 7 04-20-2012 02:51 PM
Evaporator motor doesn't run mtc2912 Refrigerator & Freezer Repair 3 12-07-2009 07:25 AM
Evaporator Motor Kit roseann Refrigerator & Freezer Repair 0 11-03-2009 07:27 AM
evaporator motor replacement TREX Refrigerator & Freezer Repair 7 06-18-2009 10:05 PM
evaporator fan motor billy morris Refrigerator & Freezer Repair 0 01-29-2009 04:23 PM
