Discuss
GE refrigerators (GS* & PS* models), the evaporator fan motor test and replacement.
 in
Refrigerator & Freezer Repair
How do I determine why the compressor isnt running? Looking back on it I think things stopped pretty suddenly. We
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » GE refrigerators (GS* & PS* models), the evaporator fan motor test and replacement.
  #171 (permalink)
Old 10-10-2012, 02:03 PM
Junior Member
gtiphil is on a distinguished road
Default
How do I determine why the compressor isnt running? Looking back on it I think things stopped pretty suddenly. We noticed some water on the floor under the freezer and assumed the kids must have left the door ajar. The next day we figured out that it wasn't cooling at all and the temp was slowly rising in both freezer and FF areas. I believe the water was from the ice melting in the tray cause when I removed it it made a mess everywhere. I have a multimeter and am pretty handy but I dont know where to start or exactly what to look for. It seems to me that either the compressor motor isnt being told to turn on (motherboard or temp sensor) of something in its circuit is bad (relay, motor etc.). If the coolant leaked out wouldnt the compressor still run? And if it was a slow leak wouldnt we have noticed things getting warmer over a longer period of time?
Phil
Ads By Google
  #172 (permalink)
Old 10-10-2012, 02:04 PM
Junior Member
Default
We were posting at the same time. I will check what you asked now and be back with an answer shortly.
Thank you.
  #173 (permalink)
Old 10-10-2012, 02:38 PM
Junior Member
Default
Gene,
The mainboard in my unit looks somewhat different than the link/picture you send. Also, the connector for J8, J9 and J11 is completely different and it is not clear how to get it disconnected. I have tried but I dont want to force anything. Here is a picture of what the connector I have. There seem to be 3 "L shaped blades" that come out of the mainboard and a plastic connector with the wires attached to it.
  #174 (permalink)
Old 10-10-2012, 03:53 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
If you will look at the picture closer, you can see exactly the same terminals on the right side. Just pull out the wire connected to the J8 terminal, holding for the plastic piece.
If you don't feel comfortable to do it, then you have to call a pro to do it for you.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #175 (permalink)
Old 10-10-2012, 04:45 PM
Junior Member
Default
Gene,
I will give it a try. Does the wire come loose from the plastic connector (leaving the other wires connected to the plastic connector and therefore to the mainboard)? Or do I have to remove the plastic connector (and all 3 wires) and then remove the single wire?
  #176 (permalink)
Old 10-10-2012, 05:18 PM
Junior Member
Default
Gene,
I have made some progress. I simply removed the mainboard from its mounts and there is a burn spot on the back. I traced it to the J11 terminal. On the front it is the black "box" that is just below the "thing" with the copper wires wrapped around it.
So the main board needs to be replaced, but what caused it and do I need to look for something else too?
  #177 (permalink)
Old 10-10-2012, 07:05 PM
Junior Member
Default
Gene,
I still cant figure out how to get the J8, J9 and J11 wires disconnected from the mainboard. All the others were a piece of cake but these are a completely different connection. Can you tell me if the plastic connector comes off with all 3 wires attached (which is what I assume)? Most connectors seem to have some kind of latch or catch you have to manipulate and then they come apart. I cant find one on this.
  #178 (permalink)
Old 10-11-2012, 12:41 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Usually these 3 wires are separated but in your refrigerator they are combined in a single plug. Hold the plug and pull it out. The old board is piece of junk so don't worry to damage it.
This control board has been redesigned a few times by GE. The control board in your refrigerator is the very first version and that's why it looks different.
__________________
  #179 (permalink)
Old 10-11-2012, 07:39 PM
Junior Member
Default
Gene,
Thank you very much for helping me with this. Is it only the control board that needs to be replaced or do I need to check something else as well?
  #180 (permalink)
Old 10-12-2012, 05:02 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I don't see anything else at this time.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Evaporator Motor GaryDolman Refrigerator & Freezer Repair 7 04-20-2012 02:51 PM
Evaporator motor doesn't run mtc2912 Refrigerator & Freezer Repair 3 12-07-2009 07:25 AM
Evaporator Motor Kit roseann Refrigerator & Freezer Repair 0 11-03-2009 07:27 AM
evaporator motor replacement TREX Refrigerator & Freezer Repair 7 06-18-2009 10:05 PM
evaporator fan motor billy morris Refrigerator & Freezer Repair 0 01-29-2009 04:23 PM
