Discuss
GE refrigerators (GS* & PS* models), the evaporator fan motor test and replacement.
 in
Refrigerator & Freezer Repair
Originally Posted by mbrahmer ...fan over evap not running... Did the compressor run at that time? If it did not
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » GE refrigerators (GS* & PS* models), the evaporator fan motor test and replacement.
  #161 (permalink)
Old 05-29-2012, 03:28 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
If it did not then it's normal.
If the compressor was On, replace the evaporator fan motor and the main control board. It's recommended by GE to replace both of them.
Inspect the fan motor plug for the thermistor harness.
If the thermistor is wired into the plug then the evaporator motor Part number: WR60X10074
If it does not have a thermistor wired into it then the evaporator motor Part number: WR60X10185
The main control board Part number: WR55X10942
Ads By Google
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #162 (permalink)
Old 05-29-2012, 04:45 PM
Junior Member
mbrahmer is on a distinguished road
Default
Thanks Gene. I just ordered the parts!
Also found the RMA for the FF fan I ordered by mistake.
Thank you!
Mark
  #163 (permalink)
Old 05-29-2012, 04:59 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome Mark. Keep us posted.
__________________
  #164 (permalink)
Old 08-05-2012, 12:00 PM
Junior Member
bubbahotep is on a distinguished road
Default
Does anyone have an idea what the sustained amp draw of a good evaporator motor is? I was thinking of adding an inline fuse to keep a stalled motor from burning out another motherboard. Any suggestion on fuse speed type would be great too.
  #165 (permalink)
Old 08-06-2012, 01:24 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
I once designed an electronic circuit breaker,but it had to be re-set manually.
Not a good idea as you still would loose cooling and have spoiled food.
Best idea is to prevent the motor from running out of oil by drilling holes in the bottom enbell and adding oil to the lower bearing, then sealing it up. Adding oil to the top of the motor is not advised as it may gum up the armature.
__________________
  #166 (permalink)
Old 09-10-2012, 11:45 AM
Junior Member
Default
I still want to try and put a fuse in. Do you have any idea what amp rating/fuse type to get? If it fails I have a 2nd overflow fridge to move stuff into that is usually 1/2 empty.
  #167 (permalink)
Old 10-08-2012, 06:44 PM
Junior Member
gtiphil is on a distinguished road
Default
I need some help please. I have a GE PSS29NGPABB that no longer cools either the FF or Freezer side. All the lights still work. All the controls seem to work (they just dont produce results). The water dispenser works. The fan at the bottom back of the unit under the panel (condenser fan?) works and the fan inside the Freezer turns on and off when you open or close either door. I have tried unplugging the unit for an hour and plugging it back in and no change. I did clean off a fair amount of dust from under the unit and the coils near the fan at the bottom back of the unit. Any suggestions?
  #168 (permalink)
Old 10-09-2012, 01:18 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Does the compressor run? You should feel a vibration on a touch if it does.
Here are the breakdown diagrams and Parts for GE PSS29NGPABB Refrigerator - AppliancePartsPros.com
__________________
  #169 (permalink)
Old 10-09-2012, 07:00 PM
Junior Member
Default
The compressor is not running.
  #170 (permalink)
Old 10-10-2012, 01:38 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Unplug the refrigerator. Pull it out of the wall. Remove the cover from the main control board. Remove the wire from the J8 terminal at the control board. Plug the fridge back and measure the voltage between the J8 terminal and the wire connected to the J7-9 (neutral) pin. The fan next to the compressor should run at that time. The normal reading suppose to be about 120 VAC.
If the reading is incorrect, replace the main control board.
If the reading is correct, post the result and we'll proceed further.
- The main control board Part number: WR55X10942
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Evaporator Motor GaryDolman Refrigerator & Freezer Repair 7 04-20-2012 02:51 PM
Evaporator motor doesn't run mtc2912 Refrigerator & Freezer Repair 3 12-07-2009 07:25 AM
Evaporator Motor Kit roseann Refrigerator & Freezer Repair 0 11-03-2009 07:27 AM
evaporator motor replacement TREX Refrigerator & Freezer Repair 7 06-18-2009 10:05 PM
evaporator fan motor billy morris Refrigerator & Freezer Repair 0 01-29-2009 04:23 PM
