Discuss
GE refrigerators (GS* & PS* models), the evaporator fan motor test and replacement.
 in
Refrigerator & Freezer Repair
Hello, I have a GE PSS26LRESS, In the last couple of weeks I find a lot frozen water all over
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » GE refrigerators (GS* & PS* models), the evaporator fan motor test and replacement.
  #101 (permalink)
Old 03-12-2011, 11:15 AM
Junior Member
reecedjr is on a distinguished road
Default Icemaker leaking + fridge bottom freezing
Hello,
I have a GE PSS26LRESS, In the last couple of weeks I find a lot frozen water all over my food in the freezer. I see a frozen drop on the bottom of the icemaker tray. It is making ice.
The other problem I have is that the refrigerator is freezing my vegetables (the bottom 3 drawers). I removed the rear panel inside the freezer and the coils were pretty much frozen over.
I would appreciate your sugestions.
thanks in advance.
Reece
St Charles Il
  #102 (permalink)
Old 03-12-2011, 03:47 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Reece,
The model number you posted does not come up. Verify and repost it please.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #103 (permalink)
Old 03-13-2011, 07:47 AM
Junior Member
Default
Morning Gene,
The model number is PSS26LSRESS. Sorry I just realized that I transposed a letter.
I appreciate your response.
  #104 (permalink)
Old 03-14-2011, 07:14 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Remove the damper assembly (#460 on the diagram) and check the air gate inside.
Pour some water into the ice maker and check if the ice maker is leaking.
If it's not locate the water inlet valve on the back of the refrigerator. Disconnect the wires from the brown solenoid and watch a frozen water in the freezer for a day or two.
Post the results.
Here the breakdown diagrams and Replacement parts for General Electric PSS26LSRESS Refrigerator | AppliancePartsPros.com
__________________
  #105 (permalink)
Old 03-18-2011, 11:49 AM
Junior Member
Default
Post the results.
Thanks Gene, I am sorry I didnt reply sooner. I will study the diagram and follow your suggestions. I turned off the ice maker and I have no leak on to my food. Does that tell you anything?
Also what about the food in the refrigerator side? The bottom 2 drawers are freezing my vegetables. I removed the panel in the freezer and the coils were full of snow(not frozen, but covered with snow, maybe it is the samething).
Thanks again Gene
  #106 (permalink)
Old 03-18-2011, 05:54 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
As I said you have to check the damper assembly.
__________________
  #107 (permalink)
Old 03-21-2011, 01:57 PM
Junior Member
Default
Hi Gene,
How do I remove the gate assembly cover (number 207)? seems like it is attached by a screw but I dont see it on the back of the fridge, should I just pull it out towards me?
Never mind. I was able to pull it off.
  #108 (permalink)
Old 03-21-2011, 06:20 PM
Junior Member
Default
Hi Gene,
I removed the damper, and I cant tell whether it is open or closed. Please see picture.
I also added water to the icemaker and it did not leak. I dont see the brown solenoid? Can you point it out in the attached 2nd picture?
Thank you Gene
  #109 (permalink)
Old 03-21-2011, 06:31 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You have to take the damper assembly apart to check if the air gate is not broken.
The "brown" solenoid is one on the left side.
__________________
  #110 (permalink)
Old 03-23-2011, 07:06 PM
Junior Member
Default
Hello Gene,
I took the damper assembly apart, and the air gate was stuck open, but not broken. I then plugged the fridge and the gate opened. I then unplugged it and it stayed open? not sure if it was supposed to close.
I also removed the freezer cover to expose the coils and they had frost on them again. All day today the freezer was warm and the the frozen food was thawing. I took a picture of it and one of the heater under the coils. Not sure if you can tell but both ends of the glass are a little burnt.
Please advise
Thank you very much!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Evaporator Motor GaryDolman Refrigerator & Freezer Repair 7 04-20-2012 02:51 PM
Evaporator motor doesn't run mtc2912 Refrigerator & Freezer Repair 3 12-07-2009 07:25 AM
Evaporator Motor Kit roseann Refrigerator & Freezer Repair 0 11-03-2009 07:27 AM
evaporator motor replacement TREX Refrigerator & Freezer Repair 7 06-18-2009 10:05 PM
evaporator fan motor billy morris Refrigerator & Freezer Repair 0 01-29-2009 04:23 PM
