oonshadow
#1 Posted : Monday, February 20, 2012 2:36:17 PM(UTC)
oonshadow
Start relay clicks, compressor does not start.
OEM# 5300151531
replacement# AP3313863
Part is no longer available. My question:
Is there any way to substitute with another part (AP4503032 perhaps?)?
Or what other options do I have??
Thanks!
#2 Posted : Monday, February 20, 2012 2:52:54 PM(UTC)
Your overload device is cutting probably due to a failed start device.
Check and verify you have R12 refrigerant, should be on the model # tag.
Next, check the start device. Is it a coil relay type, or a small, plastic item? Post info.
If an R12 system, and assuming the compressor is not shorted, a universal start device can be used. To wire it up, the common pin is the top one, bottom left the start pin and bottom right the run pin.
oonshadow
#3 Posted : Monday, February 20, 2012 3:09:04 PM(UTC)
oonshadow
Yes R12
Coil type relay
#4 Posted : Tuesday, February 21, 2012 12:16:33 AM(UTC)
The coil type start relays are very reliable, but you can try a new start device AP4503418, cheap enough at $17 Before installing, it's best to check compressor for shorts to ground, a shorted compressor will make this device get dangerously hot.
oonshadow
#5 Posted : Tuesday, February 21, 2012 7:10:39 AM(UTC)
oonshadow
Thanks for the info, I will check the compressor for short. :)
