Discuss
Leak At Rear Of Ice Maker
 in
Refrigerator & Freezer Repair
i HAVE AMANA BX21TW P1196515WW BOTTOM FREEZER REFRIGERATOR THAT IS LEAKING FROM THE UPPER WATER ENTRY POINT TO THE ICE
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Leak At Rear Of Ice Maker
  #1 (permalink)
Old 07-26-2009, 07:01 PM
Victor Madge Victor Madge is offline
Junior Member
Victor Madge is on a distinguished road
Exclamation Leak At Rear Of Ice Maker
Model Number: BX21TW   Brand: -other-   Age: 5 - 10 years
i HAVE AMANA BX21TW P1196515WW BOTTOM FREEZER REFRIGERATOR THAT IS LEAKING FROM THE UPPER WATER ENTRY POINT TO THE ICE MAKER. THE ICEMAKER DOES NOT FILL WITH WATER, AND I SUSPECT THAT A VALVE IN MALFUNCTIONING SOMEHERE. THE ROTATOR BLADES SEEM TO WORK JUST FINE, BUT NO WATER IS ENTERING THE ICE TROUGH. DOES THIS INDICATE ANYTHING TO YOU?
THANKS SO MUCH!
VICTOR MADGE
Related Models
Amana BX21TW Ref - Bottom Mounts
Amana BX21V1C Ref - Bottom Mounts
Amana BX21V1E Ref - Bottom Mounts
Amana BX21V1W Ref - Bottom Mounts
Amana BX21V2C Ref - Bottom Mounts
Amana BX21V2E Ref - Bottom Mounts
Amana BX21V2W Ref - Bottom Mounts
Amana BX21VC Ref - Bottom Mounts
Amana BX21VE Ref - Bottom Mounts
Amana BX21VL Ref - Bottom Mounts
Amana BX21VW Ref - Bottom Mounts
Amana BX22A2E Ref - Bottom Mounts
Amana BX22A2L Ref - Bottom Mounts
Amana BX22A2W Ref - Bottom Mounts
Amana BX22A5L Ref - Bottom Mounts
Amana BX22A5W Ref - Bottom Mounts
Amana BX22R3E Ref - Bottom Mounts
Amana BX22R3L Ref - Bottom Mounts
Amana BX22R3W Ref - Bottom Mounts
Amana BX22RE Ref - Bottom Mounts
Amana BX22RL Ref - Bottom Mounts
Amana BX22RW Ref - Bottom Mounts
Amana BX22S5E Ref - Bottom Mounts
Amana BX22S5L Ref - Bottom Mounts
Amana BX22S5W Ref - Bottom Mounts
Amana BX22TE Ref - Bottom Mounts
Amana BX22TL Ref - Bottom Mounts
Amana BX22TW Ref - Bottom Mounts
Amana BX518VE Ref - Bottom Mounts
Amana BX518VW Ref - Bottom Mounts
Amana BX521VCPER Ref - Bottom Mounts
Amana BX521VCPSR Ref - Bottom Mounts
Amana BX521VCPWR Ref - Bottom Mounts
Amana BX521VE Ref - Bottom Mounts
Amana BX521VW Ref - Bottom Mounts
Amana BXF19TL Ref - Bottom Mounts
Amana BXF19TW Ref - Bottom Mounts
Amana BXI21VE Ref - Bottom Mounts
Amana BXI21VL Ref - Bottom Mounts
Amana BXI21VW Ref - Bottom Mounts
Amana BXI22S5E Ref - Bottom Mounts
Amana BXI22S5L Ref - Bottom Mounts
Amana BXI22S5W Ref - Bottom Mounts
Whirlpool BYCCD3421W0
Whirlpool BYCCD3421W1
Whirlpool BYCCD3421W2
Whirlpool BYCCD3421W3
Whirlpool BYCCD3921W0
Whirlpool BYCD3722W0
Whirlpool BYCD3722W1
Whirlpool BYCD3723W0
Whirlpool BYCD3723W1
Whirlpool BYCD3723W2
Whirlpool BYCD4932W0
Whirlpool BYCD4933W0
Whirlpool BYCW4271W0
Whirlpool BYCW6292W0
Whirlpool BYCWD6274W0
Whirlpool BYCWD6274W1
Whirlpool BYCWD6274W2
Whirlpool BYCWD6274W3 Washer/dryer Laundry System
Whirlpool BYCWD6274W4 Washer/dryer Laundry System
Amana BZ20QE Ref - Bottom Mounts
Amana BZ20QG Ref - Bottom Mounts
Amana BZ20QL Ref - Bottom Mounts
Amana BZ20QW Ref - Bottom Mounts
Amana BZ20R Ref - Bottom Mounts
Amana BZ20RE Ref - Bottom Mounts
Amana BZ20RG Ref - Bottom Mounts
Amana BZ20RL Ref - Bottom Mounts
Amana BZ20RW Ref - Bottom Mounts
Amana BZ22QE Ref - Bottom Mounts
Amana BZ22QL Ref - Bottom Mounts
Amana BZ22QW Ref - Bottom Mounts
Amana BZ22R3E Ref - Bottom Mounts
Amana BZ22R3L Ref - Bottom Mounts
Amana BZ22R3W Ref - Bottom Mounts
Amana BZ22R5L Ref - Bottom Mounts
Amana BZ22R5W Ref - Bottom Mounts
Amana BZ22RE Ref - Bottom Mounts
  #2 (permalink)
Old 07-27-2009, 05:12 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Default
Check the water feeding tube connection to the line and to the ice maker.
Here are the breakdown diagrams and Replacement parts for AMANA BX21TW | AppliancePartsPros.com
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana Ice Maker Leak leakie2 Refrigerator & Freezer Repair 0 02-02-2010 06:25 AM
Ice maker leak into freezer modelajack Refrigerator & Freezer Repair 0 10-06-2009 07:08 AM
Right fr and rear control triggers igniter for left rear burner edmccar Oven Repair (including Ranges and Cooktops) 3 07-25-2009 11:41 AM
Water leak in ice maker Beverly5471 Refrigerator & Freezer Repair 6 03-02-2009 05:00 PM
Water leak in ice maker Brown4repair Refrigerator & Freezer Repair 2 12-23-2007 03:27 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
