| » Freezer fan makes a rattleing sound |
Model Number: 10660992991 Brand: Kenmore Age: 1 - 5 years
The freezer fan makes a loud rattling sound when it stops running. I inspected the fan and found ice build up around the fan bracket opening. When the fan runs, it clears the ice build up, but when it stops the fan blade moves back slightly, hits the ice, and rattles until it stops running. Clearing the ice with a hair dryer stopped the problem for 2 months. Now it requires deicing almost daily. The fridge works well otherwise. Where should I start to troubleshoot further? Where is my defrost timer located, and can the timer be manually controlled?
Ben,
Check out this diagram. The defrost timer is #4. What you have is a standard Whirlpool defrost timer (your fridge was made by Whirlpool for Sears/Kenmore). Yes, you can manually cycle it for testing purposes. Just don't turn the shaft too fast or you'll need a new timer whether it was bad before or not. |
TNX TEAM AND GENE: Did as you suggested, but came away with no solution to my problem: 1-Switched off breaker. 2-dismanteled freezer and waited until power was off 20 minutes. 3-Switched on power, advanced timer to defrost position, and observed defrost cycle: The heater got hot ,the frost melted in the drain hole, and the heater cooled down after all the frost melted; the timer advanced and started the compressor after 29 minutes. I then assembled freezer and put it back in to service. What do I check next??
PLEASE HELP |
| Display Modes | |
| dryer makes knocking sound | rmwalker41 | Dryer Repair | 5 | 01-13-2010 05:53 AM |
| Dryer does not start, makes no sound | Pennell | Dryer Repair | 1 | 11-13-2009 03:45 AM |
| Microwave Makes Buzzing Sound | todpin | Microwave Repair | 1 | 06-19-2009 03:29 PM |
| makes a humming sound when on | angel4022 | Oven Repair (including Ranges and Cooktops) | 1 | 01-27-2009 11:10 AM |
| GE washer makes clicking sound | Kyle | Washer Repair | 5 | 01-13-2008 01:41 AM |
